As in the topic. I was just trying to make a simple midi-dual-merger and then i thought that the ESP32 has 3 hwSerial ports, every time i call midi.begin() on UART1 the esp crashes. Anybody know why ?
the code.(sorry for the mess and commented stuff.)
#include <WiFi.h>
#include <ESPmDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <MIDI.h>
#define LED 2
#define DEBUG_SERIAL 0
#define RXD1 12
#define TXD1 14
// This example shows how to create two instances of the library to create a merger.
// There are two MIDI couples of IO, A and B, each using thru and merging with the
// input from the other node. The result is the following:
// A out = A in + B in
// B out = B in + A in
struct Serial1MIDISettings : public midi::DefaultSettings
static const long BaudRate = 31250;
static const int8_t TxPin = TXD1;
static const int8_t RxPin = RXD1;
MIDI_CREATE_INSTANCE(HardwareSerial, Serial, midiA);
MIDI_CREATE_CUSTOM_INSTANCE(HardwareSerial, Serial1, midiB, Serial1MIDISettings);
MIDI_CREATE_INSTANCE(HardwareSerial, Serial2, midiC);
WiFiServer server(80);
const char* ssid = "LAB";
const char* password = "Page22Air";
pinMode(LED, OUTPUT);
digitalWrite(LED, LOW);
if (DEBUG_SERIAL) {
Serial.begin(250000);
Serial.println("Starting Midi-Merger");
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
if (DEBUG_SERIAL) Serial.print(".");
if (WiFi.status() != WL_CONNECTED) {
if (DEBUG_SERIAL) Serial.println("Connection Failed! Rebooting...");
delay(5000);
ESP.restart();
ArduinoOTA.setHostname("MiDiTriple");
ArduinoOTA.setPassword("admin");
ArduinoOTA
.onStart([]() {
String type;
if (ArduinoOTA.getCommand() == U_FLASH)
type = "sketch";
else // U_SPIFFS
type = "filesystem";
// NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
//Serial.println("Start updating " + type);
.onEnd([]() {
//Serial.println("\nEnd");
.onProgress([](unsigned int progress, unsigned int total) {
//Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
.onError([](ota_error_t error) {
//Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) ;// Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR); // Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR); // Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR); // Serial.println("Receive Failed");
else if (error == OTA_END_ERROR); // Serial.println("End Failed");
ArduinoOTA.begin();
if (DEBUG_SERIAL) {
Serial.println("Ready");
Serial.print("IP address: ");
if (!MDNS.begin("esp32")) {
if (DEBUG_SERIAL) Serial.println("Error setting up MDNS responder!");
while (1) {
if (DEBUG_SERIAL) Serial.println("mDNS responder started");
// Start TCP (HTTP) server
server.begin();
if (DEBUG_SERIAL) Serial.println("TCP server started");
// Add service to MDNS-SD
//MDNS.addService("http", "tcp", 80);
//delay(1000);
// Initiate MIDI communications, listen to all channels
//Serial1.begin(31250,SERIAL_8N1,RXD1,TXD1);
midiA.begin(MIDI_CHANNEL_OMNI);
// midiB.begin(MIDI_CHANNEL_OMNI); // This line -------------------------
midiC.begin(MIDI_CHANNEL_OMNI);
digitalWrite(LED, HIGH);
if (DEBUG_SERIAL) Serial.println("Midi started");
ArduinoOTA.handle();
/*if (midiA.read()) {
// Thru on A has already pushed the input message to out A.
// Forward the message to out B as well.
midiB.send(midiA.getType(),
midiA.getData1(),
midiA.getData2(),
midiA.getChannel());
midiC.send(midiA.getType(),
midiA.getData1(),
midiA.getData2(),
if (midiB.read()) {
// Thru on B has already pushed the input message to out B.
// Forward the message to out A as well.
midiA.send(midiB.getType(),
midiB.getData1(),
midiB.getData2(),
midiB.getChannel());*/
/* midiC.send(midiB.getType(),
midiB.getData1(),
midiB.getData2(),
}if (midiC.read()) {
midiB.send(midiC.getType(),
midiC.getData1(),
midiC.getData2(),
midiC.getChannel());
midiA.send(midiC.getType(),
midiC.getData1(),
midiC.getData2(),
HandleClient();
if ((millis() % 1000) / 500) {
else {
void HandleClient() {
WiFiClient client = server.available();
if (!client) {
return;
if (DEBUG_SERIAL) {
Serial.println("");
Serial.println("New client");
// Wait for data from client to become available
uint32_t timeout = millis();
while ((client.connected() && !client.available()) && (millis() - timeout < 200)) {
delay(1);
// Read the first line of HTTP request
String req = client.readStringUntil('\r');
// First line of HTTP request looks like "GET /path HTTP/1.1"
// Retrieve the "/path" part by finding the spaces
int addr_start = req.indexOf(' ');
int addr_end = req.indexOf(' ', addr_start + 1);
if (addr_start == -1 || addr_end == -1) {
if (DEBUG_SERIAL) {
Serial.print("Invalid request: ");
Serial.println(req);
return;
req = req.substring(addr_start + 1, addr_end);
if (DEBUG_SERIAL) {
Serial.print("Request: ");
String s;
if (req == "/")
IPAddress ip = WiFi.localIP();
String ipStr = String(ip[0]) + '.' + String(ip[1]) + '.' + String(ip[2]) + '.' + String(ip[3]);
s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>Hello from ESP32 at ";
s += ipStr;
s += "</html>\r\n\r\n";
//Serial.println("Sending 200");
s = "HTTP/1.1 404 Not Found\r\n\r\n";
//Serial.println("Sending 404");
client.print(s);
client.stop();
if (DEBUG_SERIAL) Serial.println("Done with client");
delay(200);
I've been trying to reassign the GPIO pins, cause i thought that may be the issue, but still no luck.
