so i am building my first weather station using the esp32 sim800l bme280 sensor and the davis anemometer. i got it working with the wifi module but with the sim module it is a little tricky and i am new to arduino and coding. so if anybody can help putting lets say anemometer data on the weathercloud via sim card i would appreciate it. i took this code from the http://cactus.io page.
#include <math.h>
#define WindSensorPin (2) // The pin location of the anemometer sensor
volatile unsigned long Rotations; // cup rotation counter used in interrupt routine
volatile unsigned long ContactBounceTime; // Timer to avoid contact bounce in interrupt routine
float WindSpeed; // speed miles per hour
pinMode(WindSensorPin, INPUT);
attachInterrupt(digitalPinToInterrupt(WindSensorPin), isr_rotation, FALLING);
Serial.println("Davis Wind Speed Test");
Serial.println("Rotations\tMPH");
Rotations = 0; // Set Rotations count to 0 ready for calculations
sei(); // Enables interrupts
delay (3000); // Wait 3 seconds to average
cli(); // Disable interrupts
// convert to mp/h using the formula V=P(2.25/T)
// V = P(2.25/3) = P * 0.75
WindSpeed = Rotations * 0.75;
Serial.print(Rotations); Serial.print("\t\t");
Serial.println(WindSpeed);
// This is the function that the interrupt calls to increment the rotation count
void isr_rotation () {
if ((millis() - ContactBounceTime) > 15 ) { // debounce the switch contact.
Rotations++;
ContactBounceTime = millis();
and also i need to include my api key on the weathercloud and info.
char server [] = "http://api.weathercloud.net";;
char ID [] = "72389dd447e00ec0";
char Key [] = "693ac7924969c7e86304f63973d23c15";
