I've been searching for "ESP32 Arduino SPI slave example" with no results.
I've found git libraries without examples.
I wonder if "SPI slave" has been implemented yet for ESP32?
Gammons great SPI tutorial Gammon Forum : Electronics : Microprocessors : SPI - Serial Peripheral Interface - for Arduino seems to apply to ESP8266 only.
When compiling his SPI slave sketch for ESP32 it looks like ESP32 understands nothing about:
ISR (SPI_STC_vect)
SPCR |= _BV(SPE);
#define _BV(b) (1UL << (b))
etc....
Is it possible to implement SPI slave for ESP32 with Arduino? How?
Thanks,
tipo
pylon
August 30, 2018, 11:35am
2
Wrong, it applies to AVR Arduinos only. All ESPs don't support SPI slave functionality in hardware to my knowledge.
It might be possible with a software emulation but probably only at lower frequencies.
Thanks, pylon.
How about ESP32 SPI master: can that be done with Arduino?
I need to get some bytes from ESP32 to ESP8266.
Earlier I found out that it can't be done with I2C because of ESP32 limitations.
If SPI doesn't work either, what's left to try...?
pylon
August 30, 2018, 4:10pm
4
Yes, just use the SPI library include in the corresponding Arduino core.
Use UART. Or WiFi.
