I code freeRTOS all the time in the Arduino IDE:
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h" // include the connection infor for WiFi and MQTT
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
//#include <Wire.h>
#include <SPI.h> // ada fruity needs this ...
#include <Adafruit_Sensor.h> // and this ...
#include <Adafruit_BME280.h> // to run this library
Adafruit_BME280 bme280( GPIO_NUM_5 ); // use hardware SPI, set GPIO pin to use
WiFiClient wifiClient; // do the WiFi instantiation thing
PubSubClient MQTTclient( mqtt_server, mqtt_port, wifiClient ); do the MQTT instantiation thing
* This semaphore is used to stop or prevent a publish from happening during client.loop()
SemaphoreHandle_t sema_MQTT_KeepAlive;
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
switch (event) {
case SYSTEM_EVENT_STA_CONNECTED:
log_i("Connected to access point");
case SYSTEM_EVENT_STA_DISCONNECTED:
log_i("Disconnected from WiFi access point");
case SYSTEM_EVENT_AP_STADISCONNECTED:
log_i("WiFi client disconnected");
default: break;
xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 20000, NULL, 3, NULL, 1 ); // create and start the two tasks to be used, set those task to use 20K stack
xTaskCreatePinnedToCore( DoTheBME280Thing, "DoTheBME280Thing", 20000, NULL, 4, NULL, 1);
} //void setup()
void DoTheBME280Thing( void *pvParameters )
SPI.begin(); // initialize the SPI library
bme280.begin(); // begin the BME280 show
float temperature = 0.0f;
float pressure = 0.0f;
float humidity = 0.0f;
//wait for a mqtt connection
while ( !MQTTclient.connected() )
vTaskDelay( 250 );
for (;;)
temperature = ( 1.8f * bme280.readTemperature() ) + 32.0f;
pressure = bme280.readPressure() / 133.3223684f; // mmHg
humidity = bme280.readHumidity();
log_i( " temperature %f, Pressure %f, Humidity %f", temperature, pressure, humidity);
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
if ( MQTTclient.connected() )
MQTTclient.publish( topicInsideTemp, String(temperature).c_str() );
vTaskDelay( 2 ); // gives the Raspberry Pi 4 time to receive the message and process
MQTTclient.publish( topicInsideHumidity, String(humidity).c_str() );
vTaskDelay( 2 ); // no delay and RPi is still processing previous message
MQTTclient.publish( topicInsidePressure, String(pressure).c_str() );
xSemaphoreGive( sema_MQTT_KeepAlive );
vTaskDelay( 1000 * 15 );
log_i( "DoTheBME280Thing high watermark %d", uxTaskGetStackHighWaterMark( NULL ) );
vTaskDelete ( NULL );
Important to not set vTaskDelay to less then 10. Errors begin to develop with the MQTT and network connection.
makes the initial wifi/mqtt connection and works to keeps those connections open.
void MQTTkeepalive( void *pvParameters )
sema_MQTT_KeepAlive = xSemaphoreCreateBinary();
xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
// setting must be set before a mqtt connection is made
MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
for (;;)
//check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
MQTTclient.loop();
else {
log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
if ( !(WiFi.status() == WL_CONNECTED) )
connectToWiFi();
connectToMQTT();
vTaskDelay( 250 ); //task runs approx every 250 mS
void connectToMQTT()
// create client ID from mac address
byte mac[6];
WiFi.macAddress(mac);
log_i( "mac address %d.%d.%d.%d.%d", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5] );
String clientID = String(mac[0]) + String(mac[5]) ;
log_i( "connect to mqtt as client %s", clientID );
MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
log_i( "connecting to MQTT" );
vTaskDelay( 250 );
log_i("MQTT Connected");
void connectToWiFi()
log_i( "connect to wifi" );
while ( WiFi.status() != WL_CONNECTED )
WiFi.disconnect();
WiFi.begin( SSID, PASSWORD );
log_i(" waiting on wifi connection" );
vTaskDelay( 4000 );
log_i( "Connected to WiFi" );
WiFi.onEvent( WiFiEvent );
void loop() { }
Works well, lasts a long time.
The Arduino IDE only uses freeRTOS when you program the Arduino IDE to use freeRTOS.
