Greatings! I have been programming a keyboard using ILI9341 2.4", this program can some data in the Memory of the ESP32 (SSID, Pasword, Device Name, Firebase URL and Firebase Key), also I include some Icon to perform the UX, and I want to share this code with arduino community but I have some problems related with the stack overflow.
**Explanation: ** When I press the uppercase/lowercase button for 34 times I recive this error message:
***ERROR*** A stack overflow in task loopTask has been detected.
Backtrace:0x400836c5:0x3ffb0a700x4008c9dd:0x3ffb0a90 0x4008fab9:0x3ffb0ab0 0x4008e58d:0x3ffb0b30 0x4008caec:0x3ffb0b60 0x4008ca9c:0x00000000 |<-CORRUPTED
ELF file SHA256:
Backtrace:0x4008145c:0x3ffb08a00x400f0080:0x3ffb08c0 0x400f039b:0x3ffb0940 0x40083765:0x3ffb0990 0x400847ac:0x3ffb09b0 0x400836c5:0x3ffb0a70 0x4008c9dd:0x3ffb0a90 0x4008fab9:0x3ffb0ab0 0x4008e58d:0x3ffb0b30 0x4008caec:0x3ffb0b60 0x4008ca9c:0x00000000 |<-CORRUPTED
ELF file SHA256: 0000000000000000
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13864
load:0x40080400,len:3608
entry 0x400805f0
And here is my code:
#include "SPI.h"
#include "TFT_eSPI.h"
#include "Free_Fonts.h" // Include the header file attached to this sketch
#include "icons.h"
#include <WiFi.h>
#include <Preferences.h>
#include <Firebase_ESP_Client.h>
//Provide the token generation process info.
#include "addons/TokenHelper.h"
//Provide the RTDB payload printing info and other helper functions.
#include "addons/RTDBHelper.h"
#define BUZZER_PIN 32 // ESP32 GIOP21 pin connected to Buzzer's pin
#define KEYBOARD_BG tft.color565(153, 217, 234)
#define ACTIONB_BG tft.color565(195, 195, 195)
#define SPACE_BG tft.color565(143, 167, 248)
#define DEL_BG tft.color565(248, 7, 7)
#define TEXT_COLORM tft.color565(36, 150, 149)
#define BTN_COLORM tft.color565(141, 217, 143)
#define TFT_GREY 0x5AEB
//========================== USER INTERFACE VARIABLES =====================
String text;
uint8_t optionToSave = 0;
bool typeKeyboard = true;
bool transKeyboard = false;
int start_ypoint = 120;
String mainWifiSSID, mainWifiPSW, mainNameDevice, mainFirebaseKey, mainFirebaseURL;
bool changeSSID, changeSSIDPSW;
bool keyboard_stat = false; //Triger to print the keyboard
int countPRESSED = 0;
TFT_eSPI tft = TFT_eSPI();
Preferences preferences;
//Firebase configuration
//Define Firebase Data object
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig config;
unsigned long sendDataPrevMillis = 0;
int count = 0;
bool signupOK = false;
void printwrap(String msg, int x, int y)
tft.setTextColor(TFT_GREEN, TFT_BLACK);
tft.setFreeFont(FF1);
uint16_t auxCount = 0;
Serial.print("Length = "+msg.length());
int maxchars = 20;
if (msg.length() > maxchars or msg.length()-1 < maxchars or msg.length() < maxchars)
tft.fillRect(5, 10, 230, 15, TFT_BLACK);
String line1 = msg;
auxCount = line1.length()-maxchars;
line1.remove(maxchars, auxCount);
tft.drawString(line1, x, y);
if (msg.length() > maxchars*2 or msg.length()-1 < maxchars*2)
tft.fillRect(5, 25, 230, 15, TFT_BLACK);
String line2 = msg;
line2.remove(0, maxchars);
line2.remove(maxchars, line2.length());
tft.drawString(line2, x, y+15);
if (msg.length() > maxchars*3 or msg.length()-1 < maxchars*3)
tft.fillRect(5, 40, 230, 15, TFT_BLACK);
String line3 = msg;
line3.remove(0, maxchars*2);
line3.remove(maxchars, line3.length());
tft.drawString(line3, x, y+30);
if (msg.length() < maxchars*4 or msg.length()-1 < maxchars*4)
tft.fillRect(5, 55, 230, 15, TFT_BLACK);
String line3 = msg;
line3.remove(0, maxchars*3);
tft.drawString(line3, x, y+45);
void printKeys(const char *msg, int x, int y){ //I think the problem start here
tft.fillRect(0, 0+start_ypoint, 240, 96, KEYBOARD_BG);
tft.setTextColor(TFT_BLACK, KEYBOARD_BG);
//Horizontal Lines
tft.drawLine(0, 0+y, 240, 0+y, TFT_BLACK);
tft.drawLine(0, 96+y, 240, 96+y, TFT_BLACK);
tft.drawLine(0, 24+y, 240, 24+y, TFT_BLACK);
tft.drawLine(0, 47+y, 240, 47+y, TFT_BLACK);
tft.drawLine(0, 72+y, 240, 72+y, TFT_BLACK);
//Vertical Lines
tft.drawLine(0, 0+y, 0, 96+y, TFT_BLACK);
tft.drawLine(23, 0+y, 23, 96+y, TFT_BLACK);
tft.drawLine(47, 0+y, 47, 96+y, TFT_BLACK);
tft.drawLine(71, 0+y, 71, 96+y, TFT_BLACK);
tft.drawLine(95, 0+y, 95, 96+y, TFT_BLACK);
tft.drawLine(119, 0+y, 119, 96+y, TFT_BLACK);
tft.drawLine(143, 0+y, 143, 96+y, TFT_BLACK);
tft.drawLine(167, 0+y, 167, 96+y, TFT_BLACK);
tft.drawLine(191, 0+y, 191, 96+y, TFT_BLACK);
tft.drawLine(215, 0+y, 215, 96+y, TFT_BLACK);
tft.drawLine(240, 0+y, 240, 96+y, TFT_BLACK);
for ( int i = 0; i < 11; i++)
String keyPrint = String(msg[i]);
tft.drawString(keyPrint, (i*x)-17, 6+y);
for (int i = 10; i < 21; i++)
tft.drawString(keyPrint, ((i-10)*x)-17, 28+y);
for (int i = 20; i < 31; i++)
tft.drawString(keyPrint, ((i-20)*x)-17, 53+y);
for (int i = 31; i < 41; i++)
tft.drawString(keyPrint, ((i-30)*x)-17, 77+y);
detectPress(msg);
void draw_keyboard(uint16_t y, bool flag){
if (flag == true){
tft.fillScreen(TFT_BLACK);
//Text Area
tft.fillRect(0, 0, 240, 80, TFT_GREY);
tft.fillRect(5, 5, 230, 70, TFT_BLACK);
// tft.setTextColor(TFT_BLACK, KEYBOARD_BG);
tft.fillRoundRect(190, y-35, 50, 30, 4, TFT_RED); //DEL
tft.fillRoundRect(0, 100+y, 65, 30, 4, ACTIONB_BG); //SHIFT
tft.fillRoundRect(180, 100+y, 60, 30, 4, ACTIONB_BG); //Special characters
tft.fillRoundRect(73, 100+y, 100, 30, 4, SPACE_BG); //Space
tft.fillRoundRect(50, 140+y, 70, 30, 4, TFT_GREEN); //OK
tft.fillRoundRect(140, 140+y, 70, 30, 4, TFT_BLUE); //Back
tft.setTextColor(TFT_BLACK, ACTIONB_BG);
tft.drawString("abc", 15, 108+start_ypoint);
tft.drawString("?#!", 195, 110+y);
tft.setTextColor(TFT_BLACK, SPACE_BG);
tft.drawString("_____", 95, 110+y);
tft.setTextColor(TFT_BLACK, DEL_BG);
tft.drawString("DEL", 200, y-28);
tft.setTextColor(TFT_WHITE, TFT_GREEN);
tft.drawString("OK", 80-4, 147+y);
tft.setTextColor(TFT_WHITE, TFT_BLUE);
tft.drawString("Back", 155, 147+y);
dataSavePrint();
void setup(){
tft.begin();
tft.setRotation(0);
uint16_t calData[5] = { 297, 3583, 426, 3470, 6 };
pinMode(BUZZER_PIN, OUTPUT);
digitalWrite(BUZZER_PIN, LOW);
tft.setTouch(calData);
getData();
draw_menu();
void loop(){}
void draw_menu(){
if (keyboard_stat == true)
else{
draw_icon(icon_BWifi, 65, 70, 2, 35);
draw_icon(icon_BFirebase, 65, 49, 14, 160);
//=================== BUTTONS ======================================
tft.fillRoundRect(85, 5, 140, 40, 4, BTN_COLORM); //SSID
tft.fillRoundRect(85, 50, 140, 40, 4, BTN_COLORM); //PASSWORD
tft.fillRoundRect(85, 95, 140, 40, 4, BTN_COLORM); //NAME DEVICE
tft.fillRoundRect(85, 150, 140, 40, 4, BTN_COLORM); //URL FB
tft.fillRoundRect(85, 195, 140, 40, 4, BTN_COLORM); //KEY KB
tft.fillRoundRect(20, 240, 90, 30, 4, TFT_GREEN);
tft.fillRoundRect(130, 240, 90, 30, 4, TFT_BLUE);
tft.setTextColor(TEXT_COLORM, BTN_COLORM);
tft.drawString("Set SSID", 105, 18);
tft.drawString("Set", 139, 55);
tft.drawString("Password", 114, 68);
tft.drawString("Set Name", 108, 107 );
tft.drawString("Set URL", 110, 163);
tft.drawString("Set Key", 110, 206);
tft.setTextColor(TFT_BLACK, TFT_GREEN);
tft.drawString("Save", 40, 247);
tft.setTextColor(TFT_BLACK, TFT_BLUE);
tft.drawString("Back", 150, 247);
tft.drawString("WiFi:", 3, 285);
tft.drawString("Firebase:", 3, 300);
system_diagnostic();
while (true)
// Serial.println("Waiting to press...");
uint16_t x = 0, y = 0; // To store the touch coordinates
// Pressed will be set true is there is a valid touch on the screen
bool pressed = tft.getTouch(&x, &y);
if (pressed) {
onBuzzer();
Serial.println("User press the screen");
tft.fillCircle(x, y, 2, TFT_WHITE);
if(85 < x && x < 225 && 5< y && y < 45 ){
effect_press("Set SSID", 105, 18, BTN_COLORM);
optionToSave = 1;
draw_keyboard(start_ypoint, true);
keyboard_stat = true;
printKeys(" 1234567890qwertyuiopasdfghjkl:zxcvbnm,.-", 24, start_ypoint);
if(85 < x && x < 225 && 50< y && y < 90 ){
tft.setTextColor(TFT_RED, BTN_COLORM);
delay(200);
tft.setTextColor(TFT_BLACK, BTN_COLORM);
optionToSave = 2;
if(85 < x && x < 225 && 95< y && y < 135 ){
optionToSave = 3;
effect_press("Set Name", 108, 107, BTN_COLORM);
if(85 < x && x < 225 && 150< y && y < 190 ){
effect_press("Set URL", 110, 163, BTN_COLORM);
optionToSave = 4;
if(85 < x && x < 225 && 195< y && y < 235 ){
effect_press("Set Key", 110, 206, BTN_COLORM);
optionToSave = 5;
if(20 < x && x < 110 && 240< y && y < 270 ){
// saveData();
connectWifi();
loginFirebase(mainFirebaseURL, mainFirebaseKey);
if(130< x && x < 220 && 240< y && y < 270 ){
// keyboard_stat = false;
// print_menu = false;
// print_text = false;
// template_load();
// plot_data_status = true;
// come_to_home = true;
// break;
void draw_icon(const uint16_t* icon, uint16_t w, uint16_t h, uint16_t x, uint16_t y){
int row, col, buffidx=0;
for (row=0; row<w; row++) { // For each scanline...
for (col=0; col<h; col++) { // For each pixel...
//To read from Flash Memory, pgm_read_XXX is required.
//Since image is stored as uint16_t, pgm_read_word is used as it uses 16bit address
tft.drawPixel(col+x, row+y, pgm_read_word(icon + buffidx));
buffidx++;
} // end pixel
void system_diagnostic(){
tft.fillRect(60, 285, 250, 15, TFT_BLACK);
tft.fillRect(97, 285, 265, 15, TFT_BLACK);
if (WiFi.status() == WL_CONNECTED )
String ip_host = String(WiFi.localIP()[0])+"."+String(WiFi.localIP()[1])+"."+String(WiFi.localIP()[2])+"."+String(WiFi.localIP()[3]);
tft.drawString(ip_host, 60, 285);
else{
tft.setTextColor(TFT_RED, TFT_BLACK);
tft.drawString("Not connected", 60, 285);
if(signupOK == true){
tft.drawString("Login OK", 100, 300);*/
else{
tft.drawString("Login Fail", 100, 300);
void onBuzzer(){
digitalWrite(BUZZER_PIN, HIGH);
delay(50);
void dataSavePrint(){
switch (optionToSave)
case 1:
printwrap(mainWifiSSID, 8, 10);
text = mainWifiSSID;
case 2:
printwrap(mainWifiPSW, 8, 10);
case 3:
printwrap(mainNameDevice, 8, 10);
text = mainNameDevice;
case 4:
printwrap(mainFirebaseURL, 8, 10);
text = mainFirebaseURL;
case 5:
printwrap(mainFirebaseKey, 8, 10);
text = mainFirebaseKey; //DEVELOPMENT ONLY!
default:
void prepareDataToSave(String textToSave){
case 1:
if (mainWifiSSID != textToSave)
mainWifiSSID = textToSave;
changeSSID = true;
saveData("ssid", mainWifiSSID);
case 2:
if (mainWifiPSW != textToSave)
changeSSIDPSW = true;
mainWifiPSW = textToSave;
saveData("password", mainWifiPSW);
case 3:
if (mainNameDevice != textToSave)
mainNameDevice = textToSave;
saveData("device", mainNameDevice);
case 4:
if (mainFirebaseURL != textToSave)
mainFirebaseURL = textToSave;
saveData("api_url", mainFirebaseURL);
case 5:
if (mainFirebaseKey != textToSave)
mainFirebaseKey = textToSave;
saveData("api_key", mainFirebaseKey);
default:
void saveData(String param, String data){
const char* dataSave = data.c_str();
const char* paramSave = param.c_str();
preferences.begin("settings", false);
preferences.putString(paramSave, data);
Serial.println("Settings Saved!");
preferences.end();
void getData(){
mainWifiSSID = preferences.getString("ssid", "");
delay(400);
mainWifiPSW = preferences.getString("password", "");
delay(400);
mainNameDevice = preferences.getString("device", "");
delay(400);
mainFirebaseURL = preferences.getString("api_url", "");
delay(400);
mainFirebaseKey = preferences.getString("api_key", "");
delay(400);
Serial.println("SSID: "+mainWifiSSID+" Password:"+mainWifiPSW+" Device name:"+mainNameDevice+" Firebase URL:"+mainFirebaseURL+ " FirebaseKey:"+mainFirebaseKey);
Serial.println("SSID: "+String(mainWifiSSID.length())+" Password:"+String(mainWifiPSW.length())+" Device name:"+String(mainNameDevice.length())+" Firebase URL:"+String(mainFirebaseURL.length())+ " FirebaseKey:"+String(mainFirebaseKey.length()));
preferences.end();
void connectWifi(){
if (changeSSID == true or changeSSIDPSW == true)
changeSSID = false;
changeSSIDPSW = false;
WiFi.disconnect();
if (WiFi.status() == WL_CONNECTED){
// tft.fillRect(60, 285, 250, 15, TFT_BLACK);
tft.drawString(String(WiFi.localIP()[0])+"."+String(WiFi.localIP()[1])+"."+String(WiFi.localIP()[2])+"."+String(WiFi.localIP()[3]), 60, 285);
if (WiFi.status() != WL_CONNECTED)
if (mainWifiSSID.length() > 0)
WiFi.begin(mainWifiSSID.c_str(), mainWifiPSW.c_str());
int get_timeout = 0;
//check wi-fi is connected to wi-fi network
while (true) {
tft.drawString(".", 60+(get_timeout*10), 285);
if (get_timeout == 15){
get_timeout++;
if (mainWifiSSID.length() == 0)
tft.drawString("Not configured", 60, 285);
void loginFirebase(String apiURL, String apiKey){
//Authenticate to Firebase
/* Assign the api key (required) */
config.api_key = apiKey.c_str();
/* Assign the RTDB URL (required) */
config.database_url = apiURL.c_str();
Firebase.reconnectWiFi(true);
/* Sign up */
if (Firebase.signUp(&config, &auth, "", "")){
// if (Firebase.ready()){
Serial.println("ok");
/* Assign the callback function for the long running token generation task */
// config.token_status_callback = tokenStatusCallback; //see addons/TokenHelper.h
// Firebase.begin(&config, &auth);
// Firebase.reconnectWiFi(true);
signupOK = true;
tft.fillRect(97, 300, 265, 15, TFT_BLACK);
tft.drawString("Login Ok", 100, 300);
else{
Serial.printf("%s\n", config.signer.signupError.message.c_str());
signupOK = false;
tft.fillRect(97, 300, 265, 15, TFT_WHITE);
void detectPress(const char *abc){
uint8_t showKeyboard = 0;
while (true)
if (keyboard_stat == false){ break;}
else{
if (pressed && 0+start_ypoint<y && y<96+start_ypoint) {
uint16_t char_pass = 0;
for (uint8_t iy = 0; iy < 4; iy++)
for (uint8_t ix = 0; ix <10; ix++)
// Serial.println("Range x1: "+String(23*ix)+" x2:"+String(23 +(23*ix))+" y1:" + String(iy*24)+" y2:"+String(24+(24*iy)));
if(24*ix< x && x < 24 +(24*ix) && (iy*24)+start_ypoint < y && y < 24+(24*iy)+start_ypoint){
Serial.println("PRESSED: "+String(abc[char_pass+1]));
effect_press(String(abc[char_pass+1]), (24*ix)+7, (24*iy)+5+start_ypoint, KEYBOARD_BG);
text += String(abc[char_pass+1]);
printwrap(text,8, 10);
onBuzzer();
char_pass++;
if (pressed)
//=============================Function Buttons
if(100 < x && x < 190 && 100+start_ypoint < y && y < start_ypoint+130){ //Space key
text += " ";
effect_press("_____", 95, 110+start_ypoint, SPACE_BG);
if(0 < x && x < 65 && 100+start_ypoint < y && y < start_ypoint+130){ //ABC key
if (typeKeyboard == true)
showKeyboard = 1;
typeKeyboard = false;
if (typeKeyboard == false)
showKeyboard = 0;
if(180 < x && x < 240 && 100+start_ypoint < y && y < start_ypoint+130){ //Special Char key
if (transKeyboard == true)
effect_press("?#!", 195, 110+start_ypoint, ACTIONB_BG);
delay(400);
if (transKeyboard == false)
transKeyboard = true;
delay(400);
printKeys(" 1234567890|!#$%&/()=?+{}:_[]<>;:,.-", 24, start_ypoint);
if(190 < x && x < 240 && start_ypoint-35 < y && y < start_ypoint-5){ //Del key
int len;
len = text.length();
text.remove(len-1,1);
effect_press("DEL", 200, start_ypoint-28, DEL_BG);
if(50 < x && x < 120 && 140+start_ypoint < y && y < start_ypoint+170){ //Ok key
prepareDataToSave(text);
text = "";
draw_menu();
if(140 < x && x < 210 && 140+start_ypoint < y && y < start_ypoint+170){ //Back key
text = ""; //Clear global variable
draw_menu();
if (showKeyboard == 0)
tft.fillRoundRect(0, 100+start_ypoint, 65, 30, 4, ACTIONB_BG);
countPRESSED++;
Serial.println("Count "+String(countPRESSED));
if (showKeyboard == 1)
countPRESSED++;
tft.fillRoundRect(0, 100+start_ypoint, 65, 30, 4, ACTIONB_BG); //SHIFT
tft.drawString("ABC", 15, 108+start_ypoint);
printKeys(" 1234567890QWERTYUIOPASDFGHJKL@ZXCVBNM,.-", 24, start_ypoint);
void effect_press(String key_press, int x, int y, int color){
tft.setTextColor(TFT_RED, color);
tft.drawString(key_press, x, y);
delay(200);
tft.setTextColor(TFT_BLACK, color);
I think the problem is the function printKeys(); but honestly I'm not sure.
Any help will be helpfully. Thank you so much ![]()
