ESP32 starts connecting and disconnecting when I try to connect to WIFI
Im trying to do a project with ThingSpeak and as soon as the microcontroller executes the instruction WiFi.begin(ssid, pass); ( on the setup function) it starts connecting and disconnecting from the pc all the time.
I don't know what to do. I am using the same way of connecting to the wifi as in other projects.
Could be a bad board. Have you tried this exact code on other boards with the exact same, if any, attachments and cable(s)?
i dont have any other board but I tried the program on another computer and it still does not work. When I run wifi.begin it goes crazy
Common symtom of an inadequate power supply.
The other programs without wifi connection work without problem and I had run this same sketch before without problem. Does it make sense that it is a power supply problem ? If so, should I replace the board?
I have an ESP32S which works fine except WiFI connectivity. I collected a new board and its WiFi works well.
It is better to keep two boards of the same type.
Yes. Power supplies can go bad over time.
