ESP32 Sunton ESP32-3248S035 I2C
Hello,
I'm trying to add an FuelGauge on to my project Sunton ESP32-3248S035.
With testsketch from MAX17043 he finds the device adress 0x32 and FG connected to 21 and 22
(SDA and SCL)
In combination with my project sketch the MAX17043 is not recognised, put in on serveral places in my setup part, before and after touch en tft init.
It does work when its before the touch init, but then no touch available.
So, how to get this thing working on my project?
(Any suggestions to improve my script are also welcome.)
Camper electra besturing voor EBL109 en Sunlight T66 2019
Gemaakt in jaar 2023
C. van Huis
opm: werkt met TFT_eSPI versie 2.4.79
#include <TFT_eSPI.h>
#include <TAMC_GT911.h>
///FG///////
//#include "MAX1704X.h"
#include <esp_now.h>
#include <WiFi.h>
#include <esp_wifi.h>
#include "NotoSansBold36.h"
#include "NotoSansMonoSCB20.h"
////////////////////////////////test for LCD brightness//////////
//#include <Pangodream_18650_CL.h>
//Pangodream_18650_CL BL;
////sprite testen
// Pause in milliseconds between screens, change to 0 to time font rendering
#define WAIT 500
//end sprite test
touch_pad_t touchPin;
#define Threshold 50 /* Greater the value, more the sensitivity ESP sleep */
//Timeout scherm instellingen
const unsigned long eventInterval = 20000;
const unsigned long eventInterval_Sleep = 50000;
unsigned long previousTime = 0;
unsigned long currentTime = 0;
#define MAX_IMAGE_WDITH 100  // Sets rendering line buffer lengths, adjust for your images
// Position variables must be global (PNGdec does not handle position coordinates)
int16_t xpos = 0;
uint16_t *ptr;
//button toggle
int lastButton_1_State;     // the previous state of button
int currentButton_1_State;  // the current state of button
int lastButton_2_State;     // the previous state of button
int currentButton_2_State;  // the current state of button
int lastButton_3_State;     // the previous state of button
int currentButton_3_State;  // the current state of button
int lastButton_4_State;     // the previous state of button
int currentButton_4_State;  // the current state of button
int lastEblState;
int currentEblState;
int textColor;
int textColor_uit;
int textColor_hum;
int contact_Stand;
unsigned long drawTime = 0;
unsigned long myTime;
#define TOUCH_SDA 33
#define TOUCH_SCL 32
#define TOUCH_INT 25
#define TOUCH_RST 25
#define TOUCH_WIDTH 480
#define TOUCH_HEIGHT 320
//Werkende instellingen
int ledBacklight = 80;
#define USE_LINE_BUFFER  // Enable for faster rendering PNG
TAMC_GT911 tp = TAMC_GT911(TOUCH_SDA, TOUCH_SCL, TOUCH_INT, TOUCH_RST, TOUCH_WIDTH, TOUCH_HEIGHT);
TFT_eSPI tft = TFT_eSPI();
TFT_eSprite buttonSprite = TFT_eSprite(&tft);
TFT_eSprite imageSprite = TFT_eSprite(&tft);
TFT_eSprite txtSprite = TFT_eSprite(&tft);
TFT_eSprite txt2Sprite = TFT_eSprite(&tft);
TFT_eSprite txt3Sprite = TFT_eSprite(&tft);
TFT_eSprite roundSprite = TFT_eSprite(&tft);
//TFT_eSprite blockSprite   = TFT_eSprite(&tft);
int backLightBrightness = 0;
// voor het tonen van JPG en PNG plaatjes /////
// Include the jpeg decoder library
#include <TJpg_Decoder.h>
//voor PNG
//#include </Users/corvanhuis/Documents/Arduino/Camper_TFT_scherm_esp/support_functions.h>
//#include </Users/corvanhuis/Documents/Arduino/Camper_TFT_scherm_esp/pngle.h>
#include </Users/corvanhuis/Documents/Arduino/Camper_TFT_scherm_esp/kraan_groen.h>
#include </Users/corvanhuis/Documents/Arduino/Camper_TFT_scherm_esp/kraan_rood.h>
// Include the array
#include </Users/corvanhuis/Documents/Arduino/Camper_TFT_scherm_esp/camper_t66.h>
#include </Users/corvanhuis/Documents/Arduino/Camper_TFT_scherm_esp/maxxfan_groen.h>
#include </Users/corvanhuis/Documents/Arduino/Camper_TFT_scherm_esp/maxxfan_rood.h>
#include </Users/corvanhuis/Documents/Arduino/Camper_TFT_scherm_esp/vuilwatertank_groen.h>
#include </Users/corvanhuis/Documents/Arduino/Camper_TFT_scherm_esp/vuilwatertank_rood.h>
#include </Users/corvanhuis/Documents/Arduino/Camper_TFT_scherm_esp/Binnen_temp.h>
#include </Users/corvanhuis/Documents/Arduino/Camper_TFT_scherm_esp/Buiten_temp.h>
#define USE_DMA
#ifdef USE_DMA
uint16_t dmaBuffer1[16 * 16];  // Toggle buffer for 16*16 MCU block, 512bytes
uint16_t dmaBuffer2[16 * 16];  // Toggle buffer for 16*16 MCU block, 512bytes
uint16_t *dmaBufferPtr = dmaBuffer1;
bool dmaBufferSel = 0;
#endif
//TFT parameters
#define TS_MINX 9    //  150
#define TS_MINY 18   //  120
#define TS_MAXX 315  //  920
#define TS_MAXY 475  //  940
#define MINPRESSURE 20
#define MAXPRESSURE 100
long lastTouch = millis();  // last touch time for minimum delay between touches
long tThresh = 2000;        // minimum time between touches
float lastTemp = 0;  //we willen alleen temp update als deze binnengekomen is
float lastTemp_uit = 0;
// The font names are arrays references, thus must NOT be in quotes ""
//#define AA_FONT_SMALL NotoSansBold15
//#define AA_FONT_LARGE NotoSansBold36
#define AA_FONT_MONO NotoSansMonoSCB20
#define AA_FONT_BOLD NotoSansBold36
//#define AA_FONT_24 FreeSansBold24pt
// This next function will be called during decoding of the jpeg file to render each
// 16x16 or 8x8 image tile (Minimum Coding Unit) to the TFT.
bool tft_output(int16_t x, int16_t y, uint16_t w, uint16_t h, uint16_t *bitmap) {
  // Stop further decoding as image is running off bottom of screen
  if (y >= tft.height()) return 0;
    // STM32F767 processor takes 43ms just to decode (and not draw) jpeg (-Os compile option)
    // Total time to decode and also draw to TFT:
    // SPI 54MHz=71ms, with DMA 50ms, 71-43 = 28ms spent drawing, so DMA is complete before next MCU block is ready
    // Apparent performance benefit of DMA = 71/50 = 42%, 50 - 43 = 7ms lost elsewhere
    // SPI 27MHz=95ms, with DMA 52ms. 95-43 = 52ms spent drawing, so DMA is *just* complete before next MCU block is ready!
    // Apparent performance benefit of DMA = 95/52 = 83%, 52 - 43 = 9ms lost elsewhere
#ifdef USE_DMA
  // Double buffering is used, the bitmap is copied to the buffer by pushImageDMA() the
  // bitmap can then be updated by the jpeg decoder while DMA is in progress
  if (dmaBufferSel) dmaBufferPtr = dmaBuffer2;
  else dmaBufferPtr = dmaBuffer1;
  dmaBufferSel = !dmaBufferSel;  // Toggle buffer selection
  //  pushImageDMA() will clip the image block at screen boundaries before initiating DMA
  tft.pushImageDMA(x, y, w, h, bitmap, dmaBufferPtr);  // Initiate DMA - blocking only if last DMA is not complete
  // The DMA transfer of image block to the TFT is now in progress...
#else
  // Non-DMA blocking alternative
  tft.pushImage(x, y, w, h, bitmap);  // Blocking, so only returns when image block is drawn
#endif
  // Return 1 to decode next block.
  return 1;
#define BLACK 0x0000
#define WHITE 0xFFFF
#define BLUE 0x001F
#define RED 0xF800
#define CP_BROWN 0xE5B0
#define CP_L_BROWN 0x9D7C
#define GREEN 0x2685
#define DarkBLUE 0x298B
#define ORANGE 0xFBA0
#define YELLOW 0xFFE0
#define CYAN 0x07FF
#define LIME 0x5FE0
#define MAGENTA 0xF81F
#define TURQUOISE 0x0F1B
#define PINK 0xF813
#define SKY 0x667F  // nice light blue
#define GREY 0xE73C
#define DarkTURQUOISE 0x3491
#define DarkGREY 0x39C7
#define DarkRED 0x8986
#define DarkGREEN 0x3446
#define DarkMAGENTA 0x612F
#define DarkYELLOW 0x83E5
#define DarkORANGE 0xA347
#define DarkPINK 0xA1EF
#define GOLD 0xF3FF03  //  nice yellow
#define SALMON 0xFB2C  //  nice red
int gedrukt_1 = 0;
int gedrukt_2 = 0;
int gedrukt_3 = 0;
int gedrukt_4 = 0;
///ESP NOW instellingen //////
// REPLACE WITH THE MAC Address of your receiver
uint8_t broadcastAddress[] = { 0xC8, 0xF0, 0x9E, 0xF6, 0xE8, 0x5C };
// Define variables to store incoming readings
float incomingTemp;
float incomingTemp_uit;
float incomingHum;
//float incomingPres;
int relais_1_stand;
int relais_2_stand;
int relais_3_stand;
int relais_4_stand;
int voeding_EBL_stand;
int contact_Aan;
//Define variables to store relais readings to be sent
int sturing_relais_1;
int sturing_relais_2;
int sturing_relais_3;
int sturing_relais_4;
// Variable to store if sending data was successful
String success;
//Structure example to send data
//Must match the receiver structure
typedef struct struct_message {
  float temp;
  float temp_uit;
  float hum;
  //float pres;
  int relais_1_stand;
  int relais_2_stand;
  int relais_3_stand;
  int relais_4_stand;
  int contact_Aan;
} struct_message;
// Create a struct_message called outgoingReadings to hold sensor readings
struct_message outgoingReadings;
// Create a struct_message to hold incoming sensor readings
struct_message incomingReadings;
esp_now_peer_info_t peerInfo;
// Callback when data is sent
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
  Serial.print("\r\nLast Packet Send Status:\t");
  Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
  if (status == 0) {
    success = "Delivery Success :)";
    success = "Delivery Fail :(";
// Callback when data is received
void OnDataRecv(const uint8_t *mac, const uint8_t *incomingData, int len) {
  memcpy(&incomingReadings, incomingData, sizeof(incomingReadings));
  Serial.print("Bytes received: ");
  Serial.println(len);
  incomingTemp = incomingReadings.temp;
  incomingTemp_uit = incomingReadings.temp_uit;
  incomingHum = incomingReadings.hum;
  //incomingPres = incomingReadings.pres;
  relais_1_stand = incomingReadings.relais_1_stand;
  relais_2_stand = incomingReadings.relais_2_stand;
  relais_3_stand = incomingReadings.relais_3_stand;
  relais_4_stand = incomingReadings.relais_4_stand;
  voeding_EBL_stand = incomingReadings.voeding_EBL_stand;
  contact_Stand = incomingReadings.contact_Aan;
  if (lastEblState == 1 && voeding_EBL_stand == 0) {  //Relais 1,2 en 3 uit als EBL uit is, werkt toch niet meer zonder voeding EBL
    if (relais_1_stand == 1) {
      outgoingReadings.sturing_relais_1 = 0;
    if (relais_2_stand == 1) {
      outgoingReadings.sturing_relais_2 = 0;
    if (relais_3_stand == 1) {
      outgoingReadings.sturing_relais_3 = 0;
    send_message();
  if (lastEblState == 0 && voeding_EBL_stand == 1) {  //Als relais 4 aan is (BYPASS),dan mag deze switchen naar relais 1 als EBL weer aan is//
    if (relais_4_stand == 1) {
      outgoingReadings.sturing_relais_4 = 0;
      outgoingReadings.sturing_relais_1 = 1;
      send_message();
  lastEblState = voeding_EBL_stand;
  updateDisplay();
// END ESP NOW instellingen ///
  // Init Serial Monitor
  //pinMode(27, OUTPUT);
  //digitalWrite(27, HIGH);
  // Touchscreen starten
  tp.begin();
  tp.setRotation(ROTATION_INVERTED);
  ////start fuelgauge ///////////////////////
  // Initialize the fuel gauge without an address.
  Serial.println("Initializing the fuel gauge instance.");
  _fuelGauge.begin(DEFER_ADDRESS);
  // Find a connected fuel gauge on the i2c bus.
  Serial.println("Searching for device...");
  uint8_t deviceAddress = _fuelGauge.findFirstDevice();
  // If a device is NOT found, the address returned will be 0.
  if (deviceAddress > 0)
    // Set the device address.
    _fuelGauge.address(deviceAddress);
    Serial.print("A MAX17043 device was found at address 0x"); Serial.println(_fuelGauge.address(), HEX);
    // Reset the device.
    Serial.println("Resetting device...");
    _fuelGauge.reset();
    delay(250);
    // Issue a quickstart command and wait
    // for the device to be ready.
    Serial.println("Initiating quickstart mode...");
    _fuelGauge.quickstart();
    delay(125);
    // Display an initial reading.
    Serial.println("Reading device...");
    //displayReading();
    //displayMenu();
    Serial.println("A MAX17043 device was not found!");
    //while (true);
  // TFT scherm starten
  tft.init();
  tft.setRotation(3);
  tft.setSwapBytes(true);
  tft.fillScreen(DarkBLUE);
  // UIt slaap reden
  print_wakeup_reason();
  print_wakeup_touchpad();
  // Set device as  Wi-Fi Station
  WiFi.mode(WIFI_STA);
  Serial.println("WIFI starten");
  delay(2000);
  // tft.fillScreen(DarkBLUE);
  // Opstartscherm tonen
  StartupScreen();  //  Display Startup Screen em starten WIFI
  delay(2000);
  esp_sleep_enable_timer_wakeup(10 * 1000 * 1000);
  imageSprite.createSprite(100, 100);
  buttonSprite.createSprite(100, 100);
  buttonSprite.setSwapBytes(true);
  txtSprite.setColorDepth(16);
  txtSprite.createSprite(350, 25);
  txt2Sprite.setColorDepth(16);
  txt2Sprite.createSprite(75, 25);
  Serial.println("fase 1");
  // Init ESP-NOW
  Serial.println("Init ESP Now");
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
  // Once ESPNow is successfully Init, we will register for Send CB to
  // get the status of Trasnmitted packet
  esp_now_register_send_cb(OnDataSent);
  // Register peer
  memcpy(peerInfo.peer_addr, broadcastAddress, 6);
  peerInfo.channel = 0;
  peerInfo.encrypt = false;
  // Add peer
  if (esp_now_add_peer(&peerInfo) != ESP_OK) {
    Serial.println("Failed to add peer");
    return;
  // Register for a callback function that will be called when data is received
  esp_now_register_recv_cb(OnDataRecv);
  // END ESP deel
  Serial.println("fase 2");
  //delay(5000);
  Serial.println("TAMC_GT911 Camper sturing: Ready");
  // delay(5000);
#ifdef USE_DMA
  tft.initDMA();  // To use SPI DMA you must call initDMA() to setup the DMA engine
#endif
  // The jpeg image can be scaled down by a factor of 1, 2, 4, or 8
  TJpgDec.setJpgScale(1);
  // The colour byte order can be swapped by the decoder
  // using TJpgDec.setSwapBytes(true); or by the TFT_eSPI library:
  // The decoder must be given the exact name of the rendering function above
  TJpgDec.setCallback(tft_output);
  // Must use startWrite first so TFT chip select stays low during DMA and SPI channel settings remain configured
  tft.startWrite();
  // Draw the image, top left at 0,0 - DMA request is handled in the call-back tft_output() in this sketch
  TJpgDec.drawJpg(0, 0, camper_t66, sizeof(camper_t66));
  TJpgDec.setJpgScale(2);
  // Must use endWrite to release the TFT chip select and release the SPI channel
  tft.endWrite();
  //EBL veld
  txt2Sprite.loadFont(AA_FONT_MONO);
  txt2Sprite.fillSprite(CP_BROWN);
  txt2Sprite.fillRoundRect(0, 0, 75, 25, 5, TFT_BROWN);
  txt2Sprite.setTextColor(TFT_YELLOW, TFT_BROWN);
  txt2Sprite.drawString("EBL", 3, 3);
  txt2Sprite.pushSprite(345, 270, CP_BROWN);  //eerste= L/R  tweede= Up/Down
  txtSprite.unloadFont();
  Serial.println("[APP] Free memory: " + String(esp_get_free_heap_size()) + " bytes");
  currentButton_1_State = 0;
  currentButton_2_State = 0;
  currentButton_3_State = 0;
  currentButton_4_State = 0;
  currentEblState = 0;
  String str;
  tp.read();
  currentTime = millis();
  //Serial.print("UpTime:");
  //Serial.println(currentTime);
  //////////Fuel Gauge test
  /////////////////////// einde test FG///////////
  if (currentTime < 13000) {  // na reboot alles op nul
    Serial.print("Time:");
    outgoingReadings.sturing_relais_1 = currentButton_1_State;  //= alles op nul sturen
    outgoingReadings.sturing_relais_2 = currentButton_2_State;  //= alles op nul sturen
    outgoingReadings.sturing_relais_3 = currentButton_3_State;  //= alles op nul sturen
    outgoingReadings.sturing_relais_4 = currentButton_4_State;  //= alles op nul sturen
    send_message();
  // Timout scherm test
  //currentTime = millis();
  if (currentTime - previousTime >= eventInterval && digitalRead(27) == 1) {
    Serial.println("SCREEN turning off now");
    digitalWrite(27, LOW);
  if (currentTime - previousTime >= eventInterval_Sleep) {
    Serial.println("Going to sleep now");
    esp_wifi_stop();
    esp_light_sleep_start();
    esp_wifi_start();
  //*********************vanaf hier gaan we de buttosn plaatsen ********************
  // MaxxFan button
  if (lastButton_1_State != currentButton_1_State || lastButton_4_State != currentButton_4_State) {
    buttonSprite.pushImage(0, 0, 100, 100, maxxfan_rood);
    if (voeding_EBL_stand == 0) {
      buttonSprite.setTextColor(TFT_BLACK, CP_BROWN);
      buttonSprite.loadFont(AA_FONT_MONO);
      buttonSprite.drawString("BYPASS", 19, 48);
    buttonSprite.pushSprite(80, 110, TFT_WHITE);
    buttonSprite.pushImage(0, 0, 100, 100, maxxfan_groen);
  //  Button Kraan
  if (lastButton_2_State != currentButton_2_State && voeding_EBL_stand == 1 && contact_Stand == 1) {
    buttonSprite.pushImage(0, 0, 100, 100, kraan_rood);
    buttonSprite.pushSprite(200, 110, TFT_WHITE);  //was 204
    buttonSprite.pushImage(0, 0, 100, 100, kraan_groen);
  // Vuilwatertank verwarming
  if (lastButton_3_State != currentButton_3_State && voeding_EBL_stand == 1) {
    buttonSprite.pushImage(0, 0, 100, 100, vuilwatertank_rood);
    buttonSprite.pushSprite(304, 110, TFT_WHITE);
    //buttonSprite.deleteSprite();
    buttonSprite.pushImage(0, 0, 100, 100, vuilwatertank_groen);
  //vastleggen voor "toggle" functie
  lastButton_1_State = outgoingReadings.sturing_relais_1;
  lastButton_2_State = outgoingReadings.sturing_relais_2;
  lastButton_3_State = outgoingReadings.sturing_relais_3;
  lastButton_4_State = outgoingReadings.sturing_relais_4;
  //  Binnen Temperatuur veld
  if (lastTemp != incomingTemp || lastTemp_uit != incomingTemp_uit) {
    Serial.print("IN temp ");
    Serial.println(incomingTemp);
    Serial.print("OUT temp ");
    Serial.println(incomingTemp_uit);
    if (incomingTemp < 18) {
      textColor = BLUE;
    } else if (incomingTemp >= 19 && incomingTemp <= 21) {
      textColor = GREEN;
    } else if (incomingTemp >= 22 && incomingTemp <= 24) {
      textColor = YELLOW;
    } else if (incomingTemp >= 25 && incomingTemp <= 27) {
      textColor = ORANGE;
    } else if (incomingTemp > 27) {
      textColor = RED;
    if (incomingTemp_uit < 18) {
      textColor_uit = BLUE;
    } else if (incomingTemp_uit >= 19 && incomingTemp_uit <= 21) {
      textColor_uit = GREEN;
    } else if (incomingTemp_uit >= 22 && incomingTemp_uit <= 24) {
      textColor_uit = YELLOW;
    } else if (incomingTemp_uit >= 25 && incomingTemp_uit <= 27) {
      textColor_uit = ORANGE;
    } else if (incomingTemp_uit > 27) {
      textColor_uit = RED;
    if (incomingHum < 18) {
      textColor_hum = RED;
    } else if (incomingHum >= 19 && incomingHum <= 30) {
      textColor_hum = ORANGE;
    } else if (incomingHum >= 31 && incomingHum <= 60) {
      textColor_hum = YELLOW;
    } else if (incomingHum >= 61 && incomingHum <= 80) {
    } else if (incomingHum > 80) {
    txtSprite.fillSprite(CP_BROWN);
    txtSprite.setTextColor(BLACK, CP_BROWN);
    txtSprite.loadFont(AA_FONT_MONO);
    //txtSprite.loadFont(AA_FONT_BOLD);
    txtSprite.setTextSize(2);
    int xpos = 0;
    xpos += txtSprite.drawString("In: ", 0, 0);
    txtSprite.setTextColor(textColor, CP_BROWN);
    xpos += txtSprite.drawFloat(incomingReadings.temp, 0, xpos, 0);
    xpos += txtSprite.drawChar(247, xpos, 0);
    xpos += txtSprite.drawString("C ", xpos, 0);
    xpos += txtSprite.drawString("|", xpos, 0);
    xpos += txtSprite.drawString("RV: ", xpos, 0);
    txtSprite.setTextColor(textColor_hum, CP_BROWN);
    xpos += txtSprite.drawFloat(incomingReadings.hum, 0, xpos, 0);
    xpos += txtSprite.drawString("% ", xpos, 0);
    xpos += txtSprite.drawString("|Out: ", xpos, 0);
    txtSprite.setTextColor(textColor_uit, CP_BROWN);
    xpos += txtSprite.drawFloat(incomingReadings.temp_uit, 0, xpos, 0);
    xpos += txtSprite.drawString("C", xpos, 0);
    xpos += txtSprite.drawString("100 ", xpos, 0);
    txtSprite.pushSprite(105, 30, TFT_WHITE);  //delay(WAIT);
    //maak een bredere rand
    int thick = 3;
    int radius = 5;
    for (int i = 0; i < thick; i++) {
      tft.drawRect(100 + i, 27 + i, 350 - i * 2, 25 - i * 2, TFT_BLACK);
      //tft.drawRect(200 + i, 41 + i, 90 - i*2, 27 - i*2, TFT_BLACK);
    lastTemp = incomingReadings.temp;
    lastTemp_uit = incomingReadings.temp_uit;
  //EBL status weergeven
  if (voeding_EBL_stand == 1) {
    tft.fillCircle(400, 283, 9, RED);
    tft.fillCircle(400, 283, 9, GREEN);
  //variabelen aanmaken
  float x;
  float y;
  float z;
  if (millis() - lastTouch > tThresh) {
    if (tp.isTouched) {
      for (int i = 0; i < tp.touches; i++) {
        // Serial.println("Touch ");
        x = (tp.points[i].x);
        y = (tp.points[i].y);
        z = (tp.points[i].size);
        /*Serial.print("  x: ");
      Serial.print(tp.points[i].x);
      Serial.print("  y: ");
      Serial.print(tp.points[i].y);
      Serial.print("  size: ");
      Serial.println(tp.points[i].size);
      return;
      Serial.print("Geen touch geregistreerd");
    if (z > MINPRESSURE && z < MAXPRESSURE) {
      Click();
    //  Button Maxfan  - RIGHT & LEFT EDGE & TOP & BOTTOM EDGE
    if (y > 330 && y < 370 && x > 120 && x < 180) {
        Serial.print("MaxxFan: ");
        if (gedrukt_1 == 0) {
          if (voeding_EBL_stand == 1) {  //Als EBL uit willen we toch ventilator aan, via ander EBL circuit met zekering
            Serial.println("gedrukt aan");
            gedrukt_1 = 1;
            tp.reset();
            //delay(300);
            Serial.println("gedrukt aan Bypass mode");
            outgoingReadings.sturing_relais_4 = 1;
            gedrukt_1 = 1;
            tp.reset();
            //delay(300);
          Serial.println("gedrukt uit");
          gedrukt_1 = 0;
          tp.reset();
          //delay(300);
        send_message();
        Click();
    //  Button Kraan  - RIGHT & LEFT EDGE & TOP & BOTTOM EDGE
    if (y > 230 && y < 260 && x > 120 && x < 165) {
      if (z > MINPRESSURE && z < MAXPRESSURE && voeding_EBL_stand == 1 && contact_Stand == 1) {
        Serial.println("Waterpomp ");
        if (gedrukt_2 == 0) {
          outgoingReadings.sturing_relais_2 = 1;
          gedrukt_2 = 1;
          tp.reset();
          //delay(200);
          gedrukt_2 = 0;
          tp.reset();
          //delay(200);
        send_message();
        Click();
    //  Button Vuilwatertank  - RIGHT & LEFT EDGE & TOP & BOTTOM EDGE
    if (y > 120 && y < 160 && x > 150 && x < 180) {
      if (z > MINPRESSURE && z < MAXPRESSURE && voeding_EBL_stand == 1) {
        Serial.println("Vuilwatertank ");
        if (gedrukt_3 == 0) {
          outgoingReadings.sturing_relais_3 = 1;
          gedrukt_3 = 1;
          tp.reset();
          //delay(200);
          gedrukt_3 = 0;
          tp.reset();
          //delay(200);
        send_message();
        Click();
void send_message() {
  // Send message via ESP-NOW
  esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *)&outgoingReadings, sizeof(outgoingReadings));
  if (result == ESP_OK) {
    Serial.println("Sent with success");
    Serial.println("Error sending the data");
  updateDisplay();
void updateDisplay() {
  // Display Readings in Serial Monitor
  Serial.println("INCOMING READINGS");
  Serial.print("Temperature in: ");
  Serial.print(incomingReadings.temp);
  Serial.println(" ºC");
  Serial.print("Temperature out: ");
  Serial.print(incomingReadings.temp_uit);
  Serial.print("Humidity: ");
  Serial.print(incomingReadings.hum);
  Serial.println(" %");
  Serial.print("Stand relais_1: ");
  Serial.println(incomingReadings.relais_1_stand);
  Serial.print("Stand relais_2: ");
  Serial.println(incomingReadings.relais_2_stand);
  Serial.print("Stand relais_3: ");
  Serial.println(incomingReadings.relais_3_stand);
  Serial.print("Stand relais_4: ");
  Serial.println(incomingReadings.relais_4_stand);
  Serial.print("Voeding EBL stand ");
  Serial.println(incomingReadings.voeding_EBL_stand);
  Serial.print("Contact stand ");
  Serial.println(incomingReadings.contact_Aan);
  Serial.print("Value from pin: ");
  Serial.println(analogRead(34));
  Serial.print("Average value from pin: ");
  Serial.println(BL.pinRead());
  Serial.print("Volts: ");
  Serial.println(BL.getBatteryVolts());
  Serial.print("Charge level: ");
  Serial.println(BL.getBatteryChargeLevel());
  Serial.println("");
  /// Fuelgauge test////////////////
void Click() {
  previousTime = currentTime;
  if (digitalRead(27) == LOW) {
    Serial.println("SCREEN turning on now");
//voor ESP sleep
void callback() {
  //placeholder callback function
  Serial.println("Awake now........");
void print_wakeup_reason() {
  esp_sleep_wakeup_cause_t wakeup_reason;
  Serial.println("wake_up_reason......");
  wakeup_reason = esp_sleep_get_wakeup_cause();
  switch (wakeup_reason) {
    case ESP_SLEEP_WAKEUP_EXT0: Serial.println("Wakeup caused by external signal using RTC_IO"); break;
    case ESP_SLEEP_WAKEUP_EXT1: Serial.println("Wakeup caused by external signal using RTC_CNTL"); break;
    case ESP_SLEEP_WAKEUP_TIMER: Serial.println("Wakeup caused by timer"); break;
    case ESP_SLEEP_WAKEUP_TOUCHPAD: Serial.println("Wakeup caused by touchpad"); break;
    case ESP_SLEEP_WAKEUP_ULP: Serial.println("Wakeup caused by ULP program"); break;
    default: Serial.printf("Wakeup was not caused by deep sleep: %d\n", wakeup_reason); break;
void print_wakeup_touchpad() {
  touchPin = esp_sleep_get_touchpad_wakeup_status();
  Serial.println("wake_up_touchpad......");
  switch (touchPin) {
    case 0: Serial.println("Touch detected on GPIO 4"); break;
    case 1: Serial.println("Touch detected on GPIO 0"); break;
    case 2: Serial.println("Touch detected on GPIO 2"); break;
    case 3: Serial.println("Touch detected on GPIO 15"); break;
    case 4: Serial.println("Touch detected on GPIO 13"); break;
    case 5: Serial.println("Touch detected on GPIO 12"); break;
    case 6: Serial.println("Touch detected on GPIO 14"); break;
    case 7: Serial.println("Touch detected on GPIO 27"); break;
    case 8: Serial.println("Touch detected on GPIO 33"); break;
    case 9: Serial.println("Touch detected on GPIO 32"); break;
    default: Serial.println("Wakeup not by touchpad"); break;
//////// Fuel gauge/////
/////// END //////////
This is a forum for the Nano ESP32.
I have moved your topic to Project Guidance.... Nano ESP32 is for the Arduino Nano ESP32 not general ESP32 discussion.
TX. I just moved it again i think, not knowing if that is the right topic??
Programming Questions is an all right fit for what you want, I just thought Project Guidance was better for you.
Just leave it in Programming Questions.
I have the 2,8 inch-version
ESP32-2432S028-320x240
I tested which IO-pins are available
GPIO 21 is connected to the backlight.
This might disturb the I2C-communication.
GPIO22 and GPIO 27 works.
See this thread
You could try to redirect one I2C-Pin to GPIO27
best regards Stefan
Tx for your response.
At my sunton 3.5" the BL is on port 27
according to the mapping must 21 and 22 be the SDA/SDL ports.
Is seems like that the touchscreen prefends connecting to the max17043
