I wanted to treat the timer ISR from my ESP32 as a separate module. So I wanted to put the ISR declaration in a header file. Now I want to increase the variable count every time the timer gives an interrupt. But when building the project the compiler gives the error count not declared in this scope. I already tried declaring it with "extern" but the error remains.
Can someone help me get on the right track?
Here is the code:
timersettings.h
timersettings.h
#ifndef timersettings_h
#define timersettings_h
#endif
#include <Arduino.h>
#define HALF_SEC (count*50)
extern int count;
// --------------- Setup Timer1:
hw_timer_t *timer1 = NULL;
hw_timer_t *timer2 = NULL;
void IRAM_ATTR onTimer1ISR();
void IRAM_ATTR onTimer2ISR();
timersettings.c
#include <timersettings.h>
unsigned int timer1Flag, timer2Flag;
// What to do when the timer ticks out.
timer1Flag = 1;
count++;
timer2Flag = 1;
and the main.c
#include <stdbool.h>
#include <stdio.h>
#include <stdlib.h>
#include <Wire.h>
#include <SPI.h>
#include "Adafruit_PWMServoDriver.h"
#include <joysticks.h>
unsigned long buttonTime = 0, prevButtonTime = 0, startTime = 0;
unsigned int prevState, curState = 0;
unsigned int buttonFlag = 0;
unsigned int freq = 0;
unsigned int buttonState;
extern int count = 0;
// --------------- Setup Button Interrupt
void IRAM_ATTR isrButton()
buttonTime = millis();
if (buttonTime - prevButtonTime > 50)
prevButtonTime = buttonTime;
curState = 1;
//startTime = millis();
Serial.println("Serial Port Initialised");
freq = getCpuFrequencyMhz();
Serial.printf("CPU FREQ: %dMHz \n",freq);
freq = getApbFrequency();
Serial.printf("APB FREQ: %dMHz \n",(freq/1000000));
// hardware interrupt init
pinMode(JOY_LEFT_BUT, INPUT_PULLDOWN);
attachInterrupt(JOY_LEFT_BUT, isrButton, ONHIGH);
// timer1 init
timer1 = timerBegin(0, 80, true); // timer0 (from 0 to 3), 80 prescaler(80MHZ/PRESCALER), counting up (true, down=false)
timerAttachInterrupt(timer1, &onTimer1ISR, false); // attach ISR to timer (true edge triggered, false level triggered)
timerAlarmWrite(timer1, 10000, true); // Set countvalue to 10 milliseconds autoreload(true)
timerAlarmEnable(timer1); // Enable timer
joystick joystickL;
joystickL.curButState = false;
joystickL.prevButState = false;
// button state logic
if( (curState == 1) && (prevState == 0) ) // button is pressed
if( (curState == 1) && (count >= 50 ) ) // button is held for at least 0.5 seconds
buttonState = HELD;
else if( (curState ==1) && (count < 0) ) // button is pushed but not held
buttonState = PRESSED;
else if( (curState == 0) && (prevState == 1) )// button is released
buttonState = RELEASED;
buttonState = INITIAL;
// end button state logic
switch (buttonState)
case PRESSED:
Serial.printf("Button: %s\n",buttonState);
prevState = curState;
case RELEASED:
case HELD:
default:
curState = 0;
prevState = 0;
I'm still debugging the rest of the program so don't mind the buttons etc. I just need to know how to solve this:
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: arduino)
----------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32doit-devkit-v1.html
PLATFORM: Espressif 32 (6.6.0) > DOIT ESP32 DEVKIT V1
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
- framework-arduinoespressif32 @ 3.20014.231204 (2.0.14)
- tool-esptoolpy @ 1.40501.0 (4.5.1)
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 36 compatible libraries
Scanning dependencies...
Dependency Graph
|-- Adafruit PWM Servo Driver Library @ 3.0.2
|-- SPI @ 2.0.0
|-- Wire @ 2.0.0
Building in release mode
Compiling .pio\build\esp32doit-devkit-v1\src\main.cpp.o
Compiling .pio\build\esp32doit-devkit-v1\src\timersettings.c.o
src/main.cpp:20:12: warning: 'count' initialized and declared 'extern'
Linking .pio\build\esp32doit-devkit-v1\firmware.elf
c:/users/td/.platformio/packages/toolchain-xtensa-esp32@8.4.0+2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32doit-devkit-v1\src\timersettings.c.o:C:\Users\TD\Documents\PlatformIO\Projects\Remote/include/timersettings.h:16: multiple definition of `timer2'; .pio\build\esp32doit-devkit-v1\src\main.cpp.o:C:\Users\TD\Documents\PlatformIO\Projects\Remote/include/timersettings.h:16: first defined here
c:/users/td/.platformio/packages/toolchain-xtensa-esp32@8.4.0+2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32doit-devkit-v1\src\timersettings.c.o:C:\Users\TD\Documents\PlatformIO\Projects\Remote/include/timersettings.h:15: multiple definition of `timer1'; .pio\build\esp32doit-devkit-v1\src\main.cpp.o:C:\Users\TD\Documents\PlatformIO\Projects\Remote/include/timersettings.h:15: first defined here
c:/users/td/.platformio/packages/toolchain-xtensa-esp32@8.4.0+2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32doit-devkit-v1\src\main.cpp.o:(.literal._Z5setupv+0x2c): undefined reference to `onTimer1ISR()'
collect2.exe: error: ld returned 1 exit status
*** [.pio\build\esp32doit-devkit-v1\firmware.elf] Error 1
========================================= [FAILED] Took 20.44 seconds =========================================
