hi im making an lcd thats controlled by an esp32s2 devkitc-1
in short the display shows an image with som values that are clearly wrong but i dont really know how to fix it
#include <Arduino.h>
#include <SD.h>
#include <SPI.h>
#include <TFT_eSPI.h> // Hardware-specific library
TFT_eSPI tft = TFT_eSPI(); // Invoke custom library
#define TFT_WR 15 // Write strobe control pin - must use a pin in the range 0-31
#define TFT_DC 16 // Data Command control pin - must use a pin in the range 0-31 (LCD_RS on my display)
#define TFT_CS 17 // Chip select control pin
#define TFT_RST 18 // Reset pin
#define TFT_RD 7
#define TFT_D0 3 // Must use pins in the range 0-31 for the data bus
#define TFT_D1 8 // so a single register write sets/clears all bits
#define TFT_D2 14
#define TFT_D3 13
#define TFT_D4 12
#define TFT_D5 11
#define TFT_D6 10
#define TFT_D7 9
#define SD_CS 39
#define SD_MOSI 40
#define SD_MISO 41
#define SD_SCK 42
while (!Serial) { delay(10); }
tft.init();
tft.setRotation(1);
tft.fillScreen(TFT_GREEN);
delay(2000);
tft.fillScreen(TFT_BLUE);
delay(2000);
tft.fillScreen(TFT_RED);
Serial.println("Initializing SD card...");
// Manually define SPI pins
SPI.begin(SD_SCK, SD_MISO, SD_MOSI, SD_CS);
// Initialize SD card
if (!SD.begin(SD_CS, SPI)) {
Serial.println("SD Card initialization failed!");
return;
Serial.println("SD Card initialized successfully.");
// List files in the root directory
File root = SD.open("/");
printDirectory(root, 0);
void printDirectory(File dir, int numTabs) {
while (true) {
File entry = dir.openNextFile();
if (!entry) {
// No more files
for (int i = 0; i < numTabs; i++) {
Serial.print("\t");
Serial.print(entry.name());
if (entry.isDirectory()) {
Serial.println("/");
printDirectory(entry, numTabs + 1); // Recursive call for subdirectories
Serial.print("\t");
Serial.print(entry.size(), DEC);
Serial.println(" bytes");
entry.close();
void drawBMP(const char *filename, int x, int y) {
File bmpFile = SD.open(filename);
if (!bmpFile) {
Serial.println("File not found");
return;
uint32_t dataOffset;
bmpFile.seek(10);
bmpFile.read((uint8_t*)&dataOffset, 4); // Read the pixel data offset from the BMP header
uint16_t w = 480, h = 320; // Image dimensions
uint8_t row[w * 3]; // BMP stores pixels in 24-bit RGB format
uint16_t convertedRow[w]; // Converted to 16-bit color
tft.startWrite();
bmpFile.seek(dataOffset); // Move to the start of pixel data
for (int16_t rowIndex = h - 1; rowIndex >= 0; rowIndex--) {
bmpFile.read(row, w * 3);
for (int i = 0; i < w; i++) {
uint8_t b = row[i * 3]; // Blue channel
uint8_t g = row[i * 3 + 1]; // Green channel
uint8_t r = row[i * 3 + 2]; // Red channel
convertedRow[i] = tft.color565(b, r, g);
tft.pushImage(x, y + rowIndex, w, 1, convertedRow);
tft.endWrite();
bmpFile.close();
drawBMP("/Civic.bmp", 0, 0);
while (true); // Stop execution after drawing
right now wrong because i wanted to test if it would fix it (it did in fact not)
Perhaps r, g, b?
yeah i've tried but the image is still messed up
im dumb
