I have two files: helloworld.bin and firmwareLarge.bin. The first one is small and all it does - prints "Hello world" every second. The second one has wi-fi client, BLE and other stuff. The code below works ok with helloworld.bin, but fails on firmwareLarge.bin.
Please note that firmwareLarge.bin file's size in SPIFF is smaller than the actual file size (http client) for some reason. Are there some size limitations? Also, why if I restart ESP32 and try to read small "helloworld.bin", its size is 81920 and not actually saved 208288? Does ESP32 compress it or what?
The code I'm using.
#include <WiFi.h>
#include <HTTPClient.h>
#include <Arduino.h>
#include "FS.h"
#include "SPIFFS.h"
#include <HTTPUpdate.h>
#include <Update.h>
#define FORMAT_SPIFFS_IF_FAILED true
char *ssid = "*****";
char *pass = "****";
#pragma region SETUP
if (!SPIFFS.begin(FORMAT_SPIFFS_IF_FAILED))
Serial.println("SPIFFS Mount Failed");
return;
if (SPIFFS.remove("/firmware.bin"))
Serial.println("− file deleted");
Serial.println("− delete failed");
WiFi.begin(ssid, pass);
int startTimeForConnection = millis();
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
if ((millis() - startTimeForConnection) > 30 * 1000)
Serial.println("");
Serial.println("Cannot connect with such credentials or wifi is not available");
Serial.println("Connected to WiFi network with IP Address: ");
#pragma endregion
#pragma region DownloadSPIFF
if (WiFi.status() == WL_CONNECTED)
Serial.println("Start calling");
HTTPClient client;
//client.begin("https://kwater.kelectronics.net/api/getfirmware/helloworld.bin");
client.begin("https://kwater.kelectronics.net/api/getfirmware/firmwareLarge.bin");
client.addHeader("Content-Type", "application/json");
int httpResponseCode = client.GET();
if (httpResponseCode == 200)
Serial.println("200");
int len = client.getSize();
Serial.printf("FW Size: %u\n", len);
uint16_t sizeOfBuffer = 4096;
uint8_t buff[sizeOfBuffer] = {0};
WiFiClient *stream = client.getStreamPtr();
Serial.println("Download firmware...");
File fileWrite = SPIFFS.open("/firmware.bin", "w");
ulong numberOfBytesWritten = 0;
if (!fileWrite)
Serial.println("Error opening file for writing");
return;
int initialProgress = len / sizeOfBuffer + 1;
int progress = initialProgress;
while (client.connected() && (len > 0 || len == -1))
size_t size = stream->available();
if (size)
int c = stream->readBytes(buff, ((size > sizeof(buff)) ? sizeof(buff) : size));
for (int i = 0; i < ((size > sizeof(buff)) ? sizeof(buff) : size); i++)
fileWrite.write((uint16_t)buff[i]);
numberOfBytesWritten++;
progress--;
double progressPercent = static_cast<double>(progress) / initialProgress * 100;
Serial.print(progressPercent);
Serial.print("% ");
if (len > 0)
len -= c;
delay(1);
fileWrite.close();
Serial.println("DownLoadFirmWareToSpiff Done!!!!!!!!!!!!!!!!!!!!!!!!!");
Serial.print("Written=");
Serial.print(numberOfBytesWritten);
// Serial.println(httpResponseCode);
Serial.println("Not connected");
#pragma endregion
#pragma region UpdateFirmware
File fileUpdate = SPIFFS.open("/firmware.bin");
if (!fileUpdate)
Serial.println("Failed to open file for reading");
return;
Serial.println("Starting update..");
size_t fileSize = fileUpdate.size();
Serial.print("fileSize=");
Serial.print(fileSize);
Serial.println("");
if (!Update.begin(fileSize))
Serial.println("Cannot do the update");
return;
Serial.println("Update.writeStream start");
Update.writeStream(fileUpdate);
Serial.println("Update.writeStream end");
if (Update.end())
Serial.println("Successful update");
Serial.println("Error Occurred: " + String(Update.getError()));
return;
fileUpdate.close();
Serial.println("Reset in 4 seconds...");
delay(4000);
ESP.restart();
#pragma endregion
helloworld.bin works fine
.......Connected to WiFi network with IP Address:
192.168.2.58
Start calling
200
FW Size: 208288
98.04% 96.08% 94.12% ............ 1.96% 0.00% -1.96%
Written=208288
Starting update..
fileSize=208288
Successful update
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:12784
load:0x40080400,len:3032
entry 0x400805e4
Hello world
Hello world
Hello world
Hello world
firmwareLarge.bin fails (not all bytes are there)
192.168.2.58
Start calling
200
FW Size: 1592160
99.74% 99.49% .......... 0.26% 0.00% -0.26%
Written=1592160
Starting update..
fileSize=1065984 ***////Why??? Why its not 1065984???***
E (656711) bootloader_mmap: spi_flash_mmap failed: 0x102
E (656712) esp_image: bootloader_mmap(0x2c6720, 0x20c000) failed
Error Occurred: 9
