Hello, I'm trying to program my ESP32 in Visual Studio Code with PlatformIO. Every time I try to upload code, I get this error. The port that the ESP32 is connected to is found and I am pressing down the boot button to upload. Here is the code and error...
#include <Arduino.h>
#include <FastLED.h>
#define NUM_LEDS 6
#define DATA_PIN 17
CRGB leds[NUM_LEDS];
FastLED.addLeds<WS2812B, DATA_PIN, RGB>(leds, NUM_LEDS);
for(int i = 0; i < 6; i++) {
leds[0] = CRGB::Red;
FastLED.show();
leds[0] = CRGB::Black;
FastLED.show();
Connecting.........
Chip is ESP32-D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: ec:94:cb:4c:b2:f0
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Traceback (most recent call last):
File "/Users/jeremywon/.platformio/packages/tool-esptoolpy/esptool.py", line 34, in <module>
esptool._main()
File "/Users/jeremywon/.platformio/packages/tool-esptoolpy/esptool/__init__.py", line 1004, in _main
main()
File "/Users/jeremywon/.platformio/packages/tool-esptoolpy/esptool/__init__.py", line 790, in main
esp.flash_set_parameters(flash_size_bytes(args.flash_size))
File "/Users/jeremywon/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 1108, in flash_set_parameters
self.check_command(
File "/Users/jeremywon/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 406, in check_command
val, data = self.command(op, data, chk, timeout=timeout)
File "/Users/jeremywon/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 375, in command
p = self.read()
File "/Users/jeremywon/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 307, in read
return next(self._slip_reader)
StopIteration
*** [upload] Error 1
Is anyone familiar with this error. Thanks in advance.
