[ESP32] when run two code together, it doesn't work
I write the code and cause some problems
when I run this code the motor is doesn't work ( I mean the speed of motor is change more slowly) and RGB light sensor doesn't work ( mean the light intensity value from sensor is incorrect) .
Then, I try to check by run the code separately and the motor and sensor are work.
The problem is when I combine both code (motor and sensor), turn out it doesn't work.
Code working:
1.The stepper motor rotate and green LED turn on
2.RGB light sensor start detect
3.If light intensity detect green color (light intensity = 65535 = green), the motor will stop
#include <Wire.h>
#include "SparkFunISL29125.h"
#include <Stepper.h>
SFE_ISL29125 RGB_sensor;
const int stepsPerRevolution = 12 ;
Stepper myStepper(stepsPerRevolution, 14, 12, 13, 15);
int stepCount = 0;
//Green
const byte ledg_gpio = 32;
//Blue
const byte ledb_gpio = 35;
  //Initialize serial communication
  //Initialize ISl29125
  RGB_sensor.init();
  //Green LED
  pinMode(ledg_gpio, OUTPUT);
  //Blue LED
  pinMode(ledb_gpio, OUTPUT);
  myStepper.setSpeed(500);
  myStepper.step(1);
  digitalWrite(ledg_gpio, HIGH);
  //Find green
  unsigned int green = RGB_sensor.readGreen();
  Serial.println(green,DEC);
  //Blue LED
  if(green = 65535)
    //Motor stop
    myStepper.step(0);
    digitalWrite(ledg_gpio, LOW);
if (green == 65535)
'uint16_t readGreen();'
ReadGreen returns a unit16. What is the highest number a 16 bit int can hold?
OMG Thank you
The the highest number is 65536.
But I try it several time, the maximum intensity value from sensor is 65535.
You have declared unsigned int green so the possible values range is from 0 to 65535
What is the highest number a unit16 can hold?
65536
