Hi everyone,
I want to be able to select the Wi-Fis ssid from Wi-Fi scan and just type the password but for some reasons i can select some Wi-Fis(goes trough Serial 1 and 2) and others get lost somewhere(goes trough Serial 1 only). Is there some kind of ssid symbols that are not allowed or something?
Thanks in advance,
DG_tao
//includes Display, NTP(time&date) and Wi-Fi library
#include <Adafruit_SSD1306.h>
#include <WiFi.h>
#include <NTPClient.h>
#include <WiFiUdp.h>
//defines Display width, height and at what pins are the buttons connected
#define OLED_WIDTH 128
#define OLED_HEIGHT 64
#define buttonOne 34
#define buttonTwo 35
#define buttonThree 32
#define buttonFour 33
//adds verables for time&date, ssid, password and keyboard
char* ssid = "";
char* password = "";
String ssid_s = "";
String password_s = "";
String writeBuffer = "";
String sendBuffer = "";
String formattedDate;
String dayStamp;
String timeStamp;
//adds verables for Caps Lock, Login and buttons if pressed
int setWiFi = 0;
int capsLock = 0;
int buttonState = 0;
int buttonOnePressed = 0;
int buttonTwoPressed = 0;
int buttonThreePressed = 0;
int buttonFourPressed = 0;
//sets the Display width and height
Adafruit_SSD1306 display(OLED_WIDTH, OLED_HEIGHT);
// define NTP Client to get time
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP);
//starts Serial and Display
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
//defines the modes of the buttons
pinMode(buttonOne, INPUT);
pinMode(buttonTwo, INPUT);
pinMode(buttonThree, INPUT);
pinMode(buttonFour, INPUT);
WiFiSet();
// initialize the NTPClient to get time and sets time GMT(GMT +3 = 10800)
timeClient.begin();
timeClient.setTimeOffset(10800);
timedate();
void WiFiSet()
//calls the function WiFiScan
WiFiScan();
//uses keyboard to select ssid
while (setWiFi != 1)
while (buttonFourPressed != 1)
keyboard();
ssid_s = sendBuffer;
int ssid_i = ssid_s.toInt();
char charBuf[50];
ssid_s.toCharArray(charBuf, 50);
if (isDigit(charBuf[0]))
setWiFi = 1;
String wifi_s = WiFi.SSID(ssid_i - 1);
ssid = const_cast<char*>(wifi_s.c_str());
sendBuffer = "";
display.clearDisplay();
display.display();
Serial.print("1: ");
Serial.println(ssid);
display.setCursor(0, 0);
display.print("Input is not a No.");
display.display();
sendBuffer = "";
delay(2000);
Serial.print("2: ");
delay(200);
//uses keyboaed to type password
keyboard();
setWiFi = 2;
password_s = sendBuffer;
password = const_cast<char*>(password_s.c_str());
sendBuffer = "";
display.display();
delay(200);
//connects to Wi-Fi
display.setTextSize(1);
display.setTextColor(WHITE);
display.println("Connecting to:");
display.println(ssid);
display.display();
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
display.print(".");
display.display();
display.println("");
display.println("WiFi connected.");
display.println("IP address: ");
display.print(WiFi.localIP());
display.display();
delay(5000);
display.display();
void WiFiScan()
//disconnects from Wi-Fi
WiFi.disconnect();
delay(100);
//searches and display if there were networks found or not
display.println("Scaning for networks");
display.display();
int n = WiFi.scanNetworks();
display.println("Scan done");
if (n == 0)
display.println("No networks found");
display.display();
display.print(n);
display.println(" Networks found");
display.display();
for (int i = 0; i < n; ++i)
display.print(i + 1);
display.print(": ");
display.print(WiFi.SSID(i));
display.print(" ");
display.println((WiFi.encryptionType(i) == WIFI_AUTH_OPEN)?" ":"*");
display.display();
delay(10);
void timedate()
//updates timeClient if update is available
while(!timeClient.update())
timeClient.forceUpdate();
// extracts date and time
formattedDate = timeClient.getFormattedDate();
Serial.println(formattedDate);
// displays date and time
int splitT = formattedDate.indexOf("T");
dayStamp = formattedDate.substring(0, splitT);
display.print("DATE: ");
display.println(dayStamp);
timeStamp = formattedDate.substring(splitT+1, formattedDate.length()-1);
display.print("HOUR: ");
display.println(timeStamp);
display.display();
void keyboard()
//reads the states of the buttons and writes them to variables
buttonOnePressed = digitalRead(buttonOne);
buttonTwoPressed = digitalRead(buttonTwo);
buttonThreePressed = digitalRead(buttonThree);
buttonFourPressed = digitalRead(buttonFour);
//if button one is pressed subtracts one from "buttonState"
if (buttonOnePressed == 1)
buttonState = buttonState - 1;
delay(150);
if(buttonState < -15)
buttonState = 26;
//if button one is pressed adds one to "buttonState"
if (buttonTwoPressed == 1)
buttonState = buttonState + 1;
delay(150);
if(buttonState > 26)
buttonState = -15;
//defines all symbols in the keyboard
switch (buttonState)
case -15:
writeBuffer = "_";
case -14:
writeBuffer = "!";
case -13:
writeBuffer = "?";
case -12:
if (capsLock == 0)
writeBuffer = "Caps Lock";
else if (capsLock == 1)
writeBuffer = "CAPS LOCK";
case -11:
writeBuffer = "<-";
case -10:
writeBuffer = "SPACE";
case -9:
writeBuffer = "9";
case -8:
writeBuffer = "8";
case -7:
writeBuffer = "7";
case -6:
writeBuffer = "6";
case -5:
writeBuffer = "5";
case -4:
writeBuffer = "4";
case -3:
writeBuffer = "3";
case -2:
writeBuffer = "2";
case -1:
writeBuffer = "1";
case 0:
writeBuffer = "0";
case 1:
if (capsLock == 0)
writeBuffer = "a";
writeBuffer = "A";
case 2:
if (capsLock == 0)
writeBuffer = "b";
writeBuffer = "B";
case 3:
if (capsLock == 0)
writeBuffer = "c";
writeBuffer = "C";
case 4:
if (capsLock == 0)
writeBuffer = "d";
writeBuffer = "D";
case 5:
if (capsLock == 0)
writeBuffer = "e";
writeBuffer = "E";
case 6:
if (capsLock == 0)
writeBuffer = "f";
writeBuffer = "F";
case 7:
if (capsLock == 0)
writeBuffer = "g";
writeBuffer = "G";
case 8:
if (capsLock == 0)
writeBuffer = "h";
writeBuffer = "H";
case 9:
if (capsLock == 0)
writeBuffer = "i";
writeBuffer = "I";
case 10:
if (capsLock == 0)
writeBuffer = "j";
writeBuffer = "J";
case 11:
if (capsLock == 0)
writeBuffer = "k";
writeBuffer = "k";
case 12:
if (capsLock == 0)
writeBuffer = "l";
writeBuffer = "L";
case 13:
if (capsLock == 0)
writeBuffer = "m";
writeBuffer = "M";
case 14:
if (capsLock == 0)
writeBuffer = "n";
writeBuffer = "N";
case 15:
if (capsLock == 0)
writeBuffer = "o";
writeBuffer = "O";
case 16:
if (capsLock == 0)
writeBuffer = "p";
writeBuffer = "P";
case 17:
if (capsLock == 0)
writeBuffer = "q";
writeBuffer = "Q";
case 18:
if (capsLock == 0)
writeBuffer = "r";
writeBuffer = "R";
case 19:
if (capsLock == 0)
writeBuffer = "s";
writeBuffer = "S";
case 20:
if (capsLock == 0)
writeBuffer = "t";
writeBuffer = "T";
case 21:
if (capsLock == 0)
writeBuffer = "u";
writeBuffer = "U";
case 22:
if (capsLock == 0)
writeBuffer = "v";
writeBuffer = "V";
case 23:
if (capsLock == 0)
writeBuffer = "w";
writeBuffer = "W";
case 24:
if (capsLock == 0)
writeBuffer = "x";
writeBuffer = "X";
case 25:
if (capsLock == 0)
writeBuffer = "y";
writeBuffer = "Y";
case 26:
if (capsLock == 0)
writeBuffer = "z";
writeBuffer = "Z";
default:
//makes Wi-Fi setting screen and displays selected sybbols/functions
if (setWiFi == 0)
display.drawRect(0, 53, 128, 11, WHITE);
display.setCursor(2, 55);
display.print(writeBuffer);
display.setCursor(0, 9);
display.print(sendBuffer);
display.print("Connect to Wi-Fi No.:");
display.display();
else if (setWiFi == 1)
display.print("Wi-Fi password:");
display.display();
else if (setWiFi == 2)
display.display();
//if button three is pressed the displayed symbol/function is written/performed
if (buttonThreePressed == 1)
if (writeBuffer == "<-")
int L = sendBuffer.length();
sendBuffer = sendBuffer.substring(0,L - 1);
writeBuffer = "";
else if (writeBuffer == "SPACE")
writeBuffer = " ";
else if (writeBuffer == "Caps Lock")
capsLock = 1;
writeBuffer = "";
else if (writeBuffer == "CAPS LOCK")
capsLock = 0;
writeBuffer = "";
sendBuffer = sendBuffer + writeBuffer;
writeBuffer = "";
delay(150);
