Esp32 wifi excessive computing time
I am trying to send data to thingspeak via wifi but the ThingSpeak.writeFields() function of ThingSpeak Library takes 1 second when I need it to be less than 100ms so as not to interfere with measurements . What can I do to solve this problem?
What sensor (s) are there with your ESP32? Is it ESP32/ESP32S/ESP32S2?
Please, post your codes.
Have you tried this tutorial/example: ESP32 Publish Sensor Readings to ThingSpeak (easiest way).
Post links to technical information on all the hardware items, there are many different devices with the same name. While you are at it post an annotated schematic showing all connections, power, ground and power sources. You also need to remove the delay() statements in your code.
Well, interesting..
can't ping em, trace route dies, maybe some routing issues??
looks like it's hosted by Amazon in Ashburn, VA..
to get response times like you want, you should be in Ashburn..
good luck.. ~q
