ESP32 WiFi forceSleepBegin
Hey,
don't need WiFi at all, so I wanna turn it off, as much as possible.
Found some references that setting mode to OFF & forcing to sleep are doing the job.
Sadly I can't call the forceSleepBegin() method, as it's not found
Any ideas?
Thanks,
Recy
#include <WiFi.h>
// disable WiFi
    WiFi.mode(WIFI_OFF);
    WiFi.forceSleepBegin();
    delay(1);
error: 'class WiFiClass' has no member named 'forceSleepBegin'
Why load #include <WiFi.h>, if you do not want WiFi?
Here is the API to the ESP32 WiFi Networking APIs - ESP32 - — ESP-IDF Programming Guide latest documentation
You will find that the ESP32 API does not contain a forceSleepBegin() method.
I didn't found any reference about it would be guaranteed that, when not including WiFi.h, no power will be consumed. So, to be sure I'm running on a minimum power level, I'm trying to disable as much as possible.
ESP32 runs FreeRTOS, and the WiFi is always run on core number 1 (the other being 0).
It seems possible to force core 1 not to run, thus no WiFi, but not from the Arduino IDE. See here for (little) more.
Futher search leads here, so maybe it's possible after all:
/*Simple example of multi loop
* By Evandro Luis Copercini
* Based on pcbreflux video
* Public domain license 2017
#if CONFIG_FREERTOS_UNICORE
#define ARDUINO_RUNNING_CORE 0
#else
#define ARDUINO_RUNNING_CORE 1
#endif
void loop1(void *pvParameters) {
  while (1) {
     Serial.println("loop1");
void loop2(void *pvParameters) {
  while (1) {
     Serial.println("loop2");
     delay(300);
void loop3(void *pvParameters) {
  while (1) {
     Serial.println("loop3");
     delay(4000);
  xTaskCreatePinnedToCore(loop1, "loop1", 4096, NULL, 1, NULL, ARDUINO_RUNNING_CORE);
  xTaskCreatePinnedToCore(loop2, "loop2", 4096, NULL, 1, NULL, ARDUINO_RUNNING_CORE);
  xTaskCreatePinnedToCore(loop3, "loop3", 4096, NULL, 1, NULL, ARDUINO_RUNNING_CORE);
   Serial.println("loop0");
   delay(5000);
Tasks loop1, loop2 and loop3 are supposed to run on core 1. But if you set
maybe these tasks won't run at all and the serial monitor will only show "loop0"
Edit: no, it's not that simple...
But I think it is possible to set this option using the ESP IDF configuration menu. The guide for the ESP-IDF is here.
