Code:
#include<ESP32Servo.h>
Servo ServoPin
#define ServoPin = 2;
#include <WiFi.h>
#include <WiFiClient.h>
#include <WiFiAP.h>
// Set the GPIO pin where you connected your test LED or comment this line out if your dev board has a built-in LED
// Set these to your desired credentials.
const char *ssid = "xxxxxxx";
const char *password = "xxxxxxx";
WiFiServer server(80);
Serial.println("Configuring access point...");
pinMode(ServoPin,OUTPUT);
// You can remove the password parameter if you want the AP to be open.
WiFi.softAP(ssid, password);
IPAddress myIP = WiFi.softAPIP();
Serial.print("AP IP address: ");
Serial.println(myIP);
server.begin();
Serial.println("Server started");
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println("New Client."); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println();
// the content of the HTTP response follows the header:
client.print("<!DOCTYPE html>");
client.print("<html>");
client.print("<body>");
client.print("<p>Change the text of the text field, and then click the button below.</p>"); //
client.print("INPUT NUMBER: <input type='number' id='servo'>"); //in this area, I WILL TYPE number 0-255.
client.print("<button type='button' '>Go</button>");
ServoPin.attach(number); //the area where i will assign the servo to the angle i type.
// break out of the while loop:
} else { // if you got a newline, then clear currentLine:
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// close the connection:
client.stop();
Serial.println("Client Disconnected.");
Hi. i was trying to post create this kind of code where i can control servo wirelessly. while the servo is still incomplete(i dont know how to get the Input from an html but thats a question for another forum), im still trying to port but the common error is this:
Multiple libraries were found for "WiFi.h"
Used: C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi
Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
i wonder what went wrong. i have on my preferences http://arduino.esp8266.com/stable/package_esp8266com_index.json,https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json
Board:ESP32 Dev Module
Im using ESP32 Dev Kit hardware
im not sure why it is not connecting to wifi. whenever i try WiFiAccessPoint sample from File>Example> it is connecting but on this code it is not...
Is it an error or a warning? You didn't post the errors, so I would guess, warning. But your post title says "not found", which would be an error. But then you wouldn't have gotten the warning that multiple libraries were found.
ohh my bad. okay ill re-edit it.
but the error is multiple libraries idk how to resolve this. i tried renaming the esp Wifi(C:\Program Files (x86)\Arduino\libraries\WiFi) to ESPWiFi.h, ESP32WiFi.h foldder(and even without .h) but the problem persists even if i recode #include <WiFi.h> or <ESPWiFi.h> or ESP32WiFi.h
If you scroll up the error list you may see the first and 2nd errors listed, way before the multiple wifi issues. Copy and paste the first and 2nd error or the whole error message.
i still have the errors in my board fortunately. i need only to copy the red/errors right? other results doesnt have errors
here:
In file included from C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src/WiFi.h:29:0,
from C:\Users\ACER-PC\Documents\Arduino\sketch_jul03a\sketch_jul03a.ino:16:
C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/IPv6Address.h:29:1: error: expected initializer before 'class'
class IPv6Address: public Printable
In file included from c:\users\acer-pc\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0\xtensa-esp32-elf\include\c++\5.2.0\functional:53:0,
from C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src/WiFiGeneric.h:28,
from C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src/WiFiSTA.h:28,
from C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src/WiFi.h:32,
c:\users\acer-pc\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0\xtensa-esp32-elf\include\c++\5.2.0\typeinfo:39:37: error: expected declaration before end of line
Could you provide the entire error message and your code?
Im gonna post it 2x because my comment is beyond the limit
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\ACER-PC\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\ACER-PC\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\ACER-PC\Documents\Arduino\libraries -fqbn=esp32:esp32:node32s:PartitionScheme=default,FlashFreq=80,UploadSpeed=921600,DebugLevel=none -ide-version=10813 -build-path C:\Users\ACER-PC\AppData\Local\Temp\arduino_build_360863 -warnings=none -build-cache C:\Users\ACER-PC\AppData\Local\Temp\arduino_cache_680292 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -verbose C:\Users\ACER-PC\Documents\Arduino\sketch_jul03a\sketch_jul03a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\ACER-PC\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\ACER-PC\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\ACER-PC\Documents\Arduino\libraries -fqbn=esp32:esp32:node32s:PartitionScheme=default,FlashFreq=80,UploadSpeed=921600,DebugLevel=none -ide-version=10813 -build-path C:\Users\ACER-PC\AppData\Local\Temp\arduino_build_360863 -warnings=none -build-cache C:\Users\ACER-PC\AppData\Local\Temp\arduino_cache_680292 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -verbose C:\Users\ACER-PC\Documents\Arduino\sketch_jul03a\sketch_jul03a.ino
Using board 'node32s' from platform in folder: C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5
Using core 'esp32' from platform in folder: C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5
cmd /c if exist "C:\\Users\\ACER-PC\\Documents\\Arduino\\sketch_jul03a\\partitions.csv" copy /y "C:\\Users\\ACER-PC\\Documents\\Arduino\\sketch_jul03a\\partitions.csv" "C:\\Users\\ACER-PC\\AppData\\Local\\Temp\\arduino_build_360863\\partitions.csv"
cmd /c if not exist "C:\\Users\\ACER-PC\\AppData\\Local\\Temp\\arduino_build_360863\\partitions.csv" copy "C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\tools\\partitions\\default.csv" "C:\\Users\\ACER-PC\\AppData\\Local\\Temp\\arduino_build_360863\\partitions.csv"
1 file(s) copied.
Detecting libraries used...
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "C:\\Users\\ACER-PC\\AppData\\Local\\Temp\\arduino_build_360863\\sketch\\sketch_jul03a.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for ESP32Servo.h: [ESP32Servo@0.9.0]
ResolveLibrary(ESP32Servo.h)
-> candidates: [ESP32Servo@0.9.0]
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "C:\\Users\\ACER-PC\\AppData\\Local\\Temp\\arduino_build_360863\\sketch\\sketch_jul03a.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for WiFi.h: [WiFi@1.2.7 WiFi@1.0]
ResolveLibrary(WiFi.h)
-> candidates: [WiFi@1.2.7 WiFi@1.0]
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\ACER-PC\\AppData\\Local\\Temp\\arduino_build_360863\\sketch\\sketch_jul03a.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src\\ESP32PWM.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src\\ESP32Servo.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src\\ESP32Tone.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src\\analogWrite.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src\\ETH.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src\\WiFi.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src\\WiFiAP.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src\\WiFiClient.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
and the other half:
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src\\WiFiGeneric.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src\\WiFiMulti.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src\\WiFiSTA.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src\\WiFiScan.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src\\WiFiServer.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src\\WiFiUdp.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\ACER-PC\\AppData\\Local\\Temp\\arduino_build_360863\\sketch\\sketch_jul03a.ino.cpp" -o "C:\\Users\\ACER-PC\\AppData\\Local\\Temp\\arduino_build_360863\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\ACER-PC\\AppData\\Local\\Temp\\arduino_build_360863\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/config" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_trace" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/app_update" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/asio" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bootloader_support" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/bt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/coap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/console" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/driver" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/efuse" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-tls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_event" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_http_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_ota" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_https_server" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/espcoredump" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ethernet" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/expat" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fatfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freemodbus" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/freertos" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/heap" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/idf_test" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/jsmn" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/json" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/libsodium" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/log" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/lwip" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mbedtls" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mdns" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/micro-ecc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/mqtt" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/newlib" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nghttp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nimble" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/nvs_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/openssl" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protobuf-c" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/protocomm" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/pthread" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/sdmmc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/soc" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spi_flash" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/spiffs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcp_transport" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/ulp" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/unity" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/vfs" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wear_levelling" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp32-camera" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/esp-face" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_Node32s -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"Node32s\"" "-DARDUINO_VARIANT=\"node32s\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\cores\\esp32" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\variants\\node32s" "-IC:\\Users\\ACER-PC\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "-IC:\\Users\\ACER-PC\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.5\\libraries\\WiFi\\src" "C:\\Users\\ACER-PC\\AppData\\Local\\Temp\\arduino_build_360863\\sketch\\sketch_jul03a.ino.cpp" -o "C:\\Users\\ACER-PC\\AppData\\Local\\Temp\\arduino_build_360863\\sketch\\sketch_jul03a.ino.cpp.o"
In file included from C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src/WiFi.h:29:0,
from C:\Users\ACER-PC\Documents\Arduino\sketch_jul03a\sketch_jul03a.ino:16:
C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\cores\esp32/IPv6Address.h:24:1: error: expected initializer before 'class'
class IPv6Address: public Printable
In file included from c:\users\acer-pc\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0\xtensa-esp32-elf\include\c++\5.2.0\functional:53:0,
from C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src/WiFiGeneric.h:28,
from C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src/WiFiSTA.h:28,
from C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi\src/WiFi.h:32,
c:\users\acer-pc\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0\xtensa-esp32-elf\include\c++\5.2.0\typeinfo:39:37: error: expected declaration before end of line
Multiple libraries were found for "WiFi.h"
Used: C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi
Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
Using library ESP32Servo at version 0.9.0 in folder: C:\Users\ACER-PC\Documents\Arduino\libraries\ESP32Servo
Using library WiFi at version 1.0 in folder: C:\Users\ACER-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi
exit status 1
Multiple libraries is not an error, but a warning. It usually means nothing.
On the other hand, the errors do look like you may be using the wrong library. Go into the library manager and make sure you are using the most recent version.
Which board are you using?
im using [ESP-32 DevKitC ESP32 Nodemcu]
and [ESP-32 Nodemcu] hardwares and both of them causing errors.
as for Tools>Board i used Node32, ESP32 Dev Module. even NodeMCU-32S but each causing errors on both
as for the versions. im using the latest <WiFi.h> as i checked there is no "update" button.
as for the other ESPWiFi. i found it here and i cant find it on Library Manager: Using Servo Motors with the ESP32
Leocann:
ESP-32 DevKitC
I've never used this board. Sorry.
"I found it here"? Found what where?
The issues starts with your selection of a Servo library. Would you PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASEPLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE PLEASE post your code?
ahh sorry i linked wrong one. this is the ESP WiFi i found.
sorry my mind is bit mixed up when i was typing.
what i mean is i cant find this on Library Manager. i mean i need to manually download this to the github then manually move it to the library folder.
Uh, post #1 ?
I suspect that he is using the wrong library. If I recall, WiFi.h is specifically for the WiFi shield on the Arduino. I've never used the ESP-32 DevKitC ESP32 Nodemcu board, so I don't know what library he should be using.
the main post/my first post/#1 post is the entire code im using
just to be sure, is there a way to command or make my arduino choose the ESP32 WiFi library than the regular WiFi or choosing WiFi than ESP32WiFi when im running the code? because base on my experience i never used wifi.h i only did bluetooth and now this ESP thing so i dont think i will need that. i do use Wemos D1 R1 few times but i prefer NodeMCU ESPs and im going to use it moreover for my personal projects, i dont know why but the program is automatically taking the regular WiFi.h instead of the ESP32 WiFi i got from gihub
I'm not certain I understand your issue. The compiler/linker has used the esp32 version of WiFi.h. which is contained within the ESP32 core of which you are using 1.0.5.
It would be good idea to update to the latest core 1.0.6.
Use the regular WiFi.h file. If you dig into it you will find WiFi.h routes to the ESP32 API.
Have you fixed the servo problem you are having?
I'd comment out everything. Then bring one system on line one at a time to find out the issue starting point.
pert
July 4, 2021, 1:21am
21
Here's the culprit:
Leocann:
Servo ServoPin
You forgot the semicolon at the end of the line.
After that, you're going to find there are some new, unrelated errors. You should study the error messages and see if you can spot the problem. If not, we're happy to help out.
So as mentioned before, this 'Multiple libraries were found for "WiFi.h"' was acting as a red herring and had absolutely nothing to do with the problem. This is not an error or a warning. It's only some useful information provided by the Arduino IDE. When multiple libraries match the filename in an #include
directive, the Arduino IDE must guess which one should be used. It usually gets it right, but every once in a while it picks the wrong one. This is why it shows this message. As long as you see that the expected library was used, you can safely ignore the message.
In this case, the correct one was used. The library at C:\Program Files (x86)\Arduino\libraries\WiFi
is for the long since retired Arduino WiFi Shield, which used a completely different hardware from the ESP32. So that library could never work for ESP32 and the IDE was right to not use it.
