Hi to all,
have a small project reading water flow sensor and send data on one hour base to remote winsock server. I add wifi manager and elegant OTA as well as web server to ESP32. All works well until I add FIX IP to wifi manager. After that winsock client could not connect to server. Test program is herewith bellow. I appreciate any help.
primjer config.json
"lokacija_uredjaja": "xxxxxxxxtesica",
"broj_uredjaja": "1",
"server_na_koji_se_spaja": "jaxxxxxxxxs.net",
"password_za_server": "xxxxxxxdaj1!*",
"ip": "192.168.1.12",
"gateway": "192.168.1.1",
"subnet": "255.255.255.0"
// Import required libraries
#include "WiFi.h"
#include "ESPAsyncWebServer.h"
#include "SPIFFS.h"
#include <SPI.h>
#include <Wire.h>
#include <ESPmDNS.h>
#include <ESPAsyncWebServer.h>
#include <ESPAsyncWiFiManager.h> //https://github.com/tzapu/WiFiManager
#include <ArduinoJson.h> //https://github.com/bblanchon/ArduinoJson
#include <AsyncElegantOTA.h>
//#include <WebSocketClient.h>
// Replace with your network credentials
const char* ssid = "xxxx";
const char* password = "xxxxxxxxx";
String remDev = "";
String serPsswd = "";
//String remDev = "xxxxxxxxatesica-1";
//String serPsswd = "xxxxxxxxrdaj1!*";
//const char *ssid = "kuci"; // replace with your wifi ssid and wpa2 key
//const char *pass = "kucikuci01";
//const char *server1 = "jadrand.ddns.net";
//char host[] = "jadrand.ddns.net";
#define LED_BUILTIN 16
#define SENSOR 2
long currentMillis = 0;
long previousMillis = 0;
int interval = 1000;
boolean ledState = LOW;
float calibrationFactor = 4.5;
volatile byte pulseCount;
byte pulse1Sec = 0;
float flowRate;
unsigned long flowMilliLitres;
unsigned int totalMilliLitres;
float flowLitres;
float totalLitres;
int pressCO2;
bool shouldSaveConfig = false; //manipulira se iz WiFi Mangera
char lokacija_uredjaja[20];
char broj_uredjaja[2];
char server_na_koji_se_spaja[20];
char password_za_server[20];
//default custom static IP
char static_ip[16] = "192.168.1.22";
char static_gw[16] = "192.168.1.1";
char static_sn[16] = "255.255.255.0";
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
DNSServer dns;
// Set LED GPIO
const int ledPin = 13;// croduino ESP32 led IO
// Stores LED state
//String ledState;
void IRAM_ATTR pulseCounter()
pulseCount++;
//callback notifying us of the need to save config
void saveConfigCallback () {
Serial.println("Should save config");
shouldSaveConfig = true;
String processor(const String& var) {
Serial.print("Processor: ");Serial.print("VAR ");Serial.println(var);
if (var == "STANJE") { // umjesto %STANJE% na index.html bit ce broj litara.
//za svaku varijablu koja pocinje sa % treba ovdje napisati dio program akoji ce ju promijeniti
String ukupno_litara="10";
return ukupno_litara;
}//end processor
bool loadConfig() {
Serial.println("loadconfig:");
Serial.println(SPIFFS.exists("/index.html"));// ispisuje 1 ako file postoji ili 0 ako ne postoji
Serial.println(SPIFFS.exists("/style.css"));// ispisuje 1 ako file postoji ili 0 ako ne postoji
File configFile = SPIFFS.open("/config.json", "r");
if (!configFile) {
Serial.println("Failed to open config file");
return false;
Serial.println("loadconfig: config file exist");
size_t size = configFile.size();
if (size > 1024) {
Serial.println("Config file size is too large");
return false;
// Allocate a buffer to store contents of the file.
std::unique_ptr<char[]> buf(new char[size]);
// We don't use String here because ArduinoJson library requires the input
// buffer to be mutable. If you don't use ArduinoJson, you may as well
// use configFile.readString instead.
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
//StaticJsonBuffer<200> jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
if (!json.success()) {
Serial.println("Failed to parse config file");
return false;
else {
strcpy(lokacija_uredjaja, json["lokacija_uredjaja"]);
strcpy(broj_uredjaja, json["broj_uredjaja"]);
strcpy(server_na_koji_se_spaja, json["server_na_koji_se_spaja"]);
strcpy(password_za_server, json["password_za_server"]);
Serial.println("procitao sam config file");
Serial.print("lokacija_uredjaja= "); Serial.println(lokacija_uredjaja);
Serial.print("broj_uredjaja= "); Serial.println(broj_uredjaja);
Serial.print("server_na_koji_se_spaja= "); Serial.println(server_na_koji_se_spaja);
Serial.print("password_za_server= "); Serial.println(password_za_server);
if(json["ip"]) {
Serial.println("setting custom ip from config");
strcpy(static_ip, json["ip"]);
strcpy(static_gw, json["gateway"]);
strcpy(static_sn, json["subnet"]);
Serial.print("static_ip= ");Serial.println(static_ip);
Serial.print("static_gw= ");Serial.println(static_gw);
Serial.print("static_sn= ");Serial.println(static_sn);
}//end loadconfiguration
bool saveConfiguration() {
//save the custom parameters to FS
Serial.println("saveConfiguration:");
JsonObject& json = jsonBuffer.createObject();
json["lokacija_uredjaja"] = lokacija_uredjaja;
json["broj_uredjaja"] = broj_uredjaja;
json["server_na_koji_se_spaja"] = server_na_koji_se_spaja;
json["password_za_server"] = password_za_server;
json["ip"] = WiFi.localIP().toString();
json["gateway"] = WiFi.gatewayIP().toString();
json["subnet"] = WiFi.subnetMask().toString();
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
return false;
Serial.println("saveconfig: upisujem u config.json");
json.prettyPrintTo(Serial);
json.printTo(configFile);
configFile.close();
Serial.println("");
Serial.println("saveconfig: zatvorio config.json");
return true;
}//end save
void setup(){
// Serial port for debugging purposes
pinMode(LED_BUILTIN, OUTPUT);
pinMode(SENSOR, INPUT_PULLUP);
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin,LOW);
pulseCount = 0;
flowRate = 0.0;
pressCO2 = 0;
flowMilliLitres = 0;
totalMilliLitres = 0;
previousMillis = 0;
attachInterrupt(digitalPinToInterrupt(SENSOR), pulseCounter, FALLING);
// Initialize SPIFFS
if (SPIFFS.begin(true)) {
Serial.println("mounted file system");
loadConfig(); // procitaj config.json
Serial.println("An Error has occurred while mounting SPIFFS");
return;
//end read
// The extra parameters to be configured (can be either global or just in the setup)
// After connecting, parameter.getValue() will get you the configured value
// id/name placeholder/prompt default length
// id, name, placeholder, length
AsyncWiFiManagerParameter custom_server_na_koji_se_spaja("server_na_koji_se_spaja", "server na koji se spaja", server_na_koji_se_spaja, 20);
AsyncWiFiManagerParameter custom_password_za_server("password_za_server", "password za server", password_za_server, 16);
AsyncWiFiManagerParameter custom_lokacija_uredjaja("lokacija_uredjaja", "adresa uredjaja", lokacija_uredjaja, 20);
AsyncWiFiManagerParameter custom_broj_uredjaja("broj_uredjaja", "broj uredjaja", broj_uredjaja, 2);
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
AsyncWiFiManager wifiManager(&server, &dns);
//set config save notify callback
wifiManager.setSaveConfigCallback(saveConfigCallback);
//--------------------kad ovoga nema onda se spaja na remote server ali nema fixIP-------------------------------------------
/* //when this is included in program program stop to connect to client
//set static ip
IPAddress _ip,_gw,_sn;
_ip.fromString(static_ip);
_gw.fromString(static_gw);
_sn.fromString(static_sn);
wifiManager.setSTAStaticIPConfig(_ip, _gw, _sn);
wifiManager.addParameter(&custom_server_na_koji_se_spaja);
wifiManager.addParameter(&custom_password_za_server);
wifiManager.addParameter(&custom_lokacija_uredjaja);
wifiManager.addParameter(&custom_broj_uredjaja);
//u slucaju da treba brisati podatke o wifi mrezi i passwordu upisanim u flash ESP32
//treba startati resetSettings jednom i opet maskirati
//tada se starta WiFi Manager
//reset settings - for testing
//wifiManager.resetSettings();
//set minimu quality of signal so it ignores AP's under that quality
//defaults to 8%
wifiManager.setMinimumSignalQuality();
//fetches ssid and pass and tries to connect
//if it does not connect it starts an access point with the specified name
//here "AutoConnectAP"
//and goes into a blocking loop awaiting configuration
if (!wifiManager.autoConnect("VODA","password")) { // (!wifiManager.autoConnect("AutoConnectAP", "password")) {
Serial.println("failed to connect and hit timeout");
delay(3000);
//reset and try again, or maybe put it to deep sleep
//ESP.reset(); - work on ESP8266
ESP.restart();
delay(5000);
//***************************************************************ODAVDE POCINJE MOJ WEB AKO JE SPOJEN*******************************
//if you get here you have connected to the WiFi
Serial.println("connected to choosed WiFi ;)");
//kao znak da WiFi radi na mrezi na koju je odabran svijetli LED na IO13
digitalWrite(ledPin,HIGH);
Serial.print("WiFi Connected to: ");
Serial.println(WiFi.SSID());
Serial.print("WiFi Signal strength: ");
Serial.println(WiFi.RSSI());
Serial.print("WiFi connected with IP: ");
//read updated parameters
Serial.println("SETUP: uzimanje vrijednosti iz upisanog podatka sa wifi manager stranice ");
strcpy(lokacija_uredjaja,custom_lokacija_uredjaja.getValue());
strcpy(broj_uredjaja,custom_broj_uredjaja.getValue());
strcpy(server_na_koji_se_spaja,custom_server_na_koji_se_spaja.getValue());
strcpy(password_za_server,custom_password_za_server.getValue());
Serial.println("SETUP: kopirani podaci sa web portala u varijable: ");
Serial.print("lokacija_uredjaja = ");Serial.println(lokacija_uredjaja);
Serial.print("broj_uredjaja = ");Serial.println(broj_uredjaja);
Serial.print("server_na_koji_se_spaja = ");Serial.println(server_na_koji_se_spaja);
Serial.print("password_za_server = ");Serial.println(password_za_server);
if (shouldSaveConfig) {
saveConfiguration();
// Print ESP32 Local IP Address
Serial.println("local ip");
Serial.println(WiFi.gatewayIP());
Serial.println(WiFi.subnetMask());
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(SPIFFS, "/index.html", String(), false, processor);
// Route to load style.css file
server.on("/style.css", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(SPIFFS, "/style.css", "text/css");
char DNS[10];
DNS[0]='\0';
strcat(DNS,"VODA-");
strcat(DNS,broj_uredjaja);
Serial.print("DNS= ");Serial.println(DNS);
if (!MDNS.begin (DNS)){ //("VODA")) { // Start the mDNS responder for esp8266.local
Serial.println("Error setting up MDNS responder!");
Serial.println("mDNS responder started");
AsyncElegantOTA.begin(&server); // Start ElegantOTA
// Start server
server.begin();
void loop(){
WiFiClient client;
currentMillis = millis();
L1: if (currentMillis - previousMillis > interval)
pulse1Sec = pulseCount;
pulseCount = 0;
// Because this loop may not complete in exactly 1 second intervals we calculate
// the number of milliseconds that have passed since the last execution and use
// that to scale the output. We also apply the calibrationFactor to scale the output
// based on the number of pulses per second per units of measure (litres/minute in
// this case) coming from the sensor.
flowRate = ((1000.0 / (millis() - previousMillis)) * pulse1Sec) / calibrationFactor;
previousMillis = millis();
// Divide the flow rate in litres/minute by 60 to determine how many litres have
// passed through the sensor in this 1 second interval, then multiply by 1000 to
// convert to millilitres.
flowMilliLitres = (flowRate / 60) * 1000;
flowLitres = (flowRate / 60);
// Add the millilitres passed in this second to the cumulative total
totalMilliLitres += flowMilliLitres;
totalLitres += flowLitres;
// Print the flow rate for this second in litres / minute
Serial.print("Flow rate: ");
Serial.print(float(flowRate)); // Print the integer part of the variable
Serial.print("L / min");
Serial.print("\t"); // Print tab space
// Print the cumulative total of litres flowed since starting
Serial.print("Output Liquid Quantity: ");
Serial.print(totalMilliLitres);
Serial.print("mL / ");
Serial.print(totalLitres);
Serial.println("L");
int i = 0;
Serial.print("server_na_koji_se_spaja= ");Serial.println(server_na_koji_se_spaja);
//(client.connect('jadrand.ddns.net' ,27015))
L: if (client.connect(server_na_koji_se_spaja, 27015)){
//lokacija i broj uredjaja u jedan string za slanje
remDev="";
remDev+=lokacija_uredjaja;
remDev+="-";
remDev+=broj_uredjaja;
serPsswd=password_za_server;
Serial.print("ispis remDev i serPsswd");
Serial.print("remDev= ");Serial.println(remDev);
Serial.print("serPsswd= "); Serial.println(serPsswd);
String postStr = remDev;
postStr += "*";
postStr += String(flowRate);
postStr += "*";
postStr += String(totalLitres);
postStr += "*";
postStr += String(pressCO2);
postStr += "#";
postStr += postStr;
postStr = serPsswd + postStr;
postStr = postStr + "\0";
Serial.print("postStr = ");Serial.println(postStr);
char c; int j = 0;
while ((c = postStr.charAt(j)) != '\0' ){
if ((j/2*2) == j) postStr.setCharAt(j, c + 3);
else postStr.setCharAt(j, c + 5);
j++;
Serial.print("postStr_nakon_kodiranja = ");Serial.println(postStr);
client.print(postStr);
else {
if (i < 3){
i++;
Serial.print("Not connected to server !\n");
delay(5000);
goto L;
}//L:
else goto L1;
client.stop();
delay(1800000);
//delay(3600000);
}//end loop
