ESP32 Wireguard
I want to send random data about temperature and humidity to a server via HTTP POST while using the WireGuard protocol. When I run my code in the Arduino IDE, I get the following error:
c:\Users\my_name\Downloads\libraries\WireGuard-ESP32\src\wireguardif.c:51:10: fatal error: tcpip_adapter.h: No such file or directory
   51 | #include "tcpip_adapter.h"
compilation terminated.
Alternatives for tcpip_adapter.h: []
ResolveLibrary(tcpip_adapter.h)
  -> candidates: []
exit status 1
Compilation error: exit status 1
Here is my code:
#include <WiFi.h>
#include <HTTPClient.h>
#include <ArduinoJson.h>
#include <WireGuard-ESP32.h>
#include <Wire.h>
const char* ssid="abc";
const char* password = "123456789";
WireGuard wg;
const char* server_public_key = "public key wireguard server";  // Public key from WireGuard server
const char* private_key = "private key esp32";      // Private key ESP32
const char* endpoint = "192.168.x`Teks terformat`.x:51820";        // Address of WireGuard server and port
IPAddress local_ip(192, 168, 43, 6);                // Local IP address of ESP32 on VPN
IPAddress allowed_ip(192, 168, 43, 0);
  //Serial.println(F("DHTxx test!"));
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
    int i=0;
    while(WiFi.status() != WL_CONNECTED){
      Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  delay(2000);
  wg.begin(local_ip, private_key, server_public_key, endpoint, allowed_ip);
  if(wg.is_initialized()){
    Serial.println("WireGuard initialized successfully.");
    Serial.println("WireGuard initialization failed.");
  .... // my code
Hi @kathryn11 ,
Welcome to the forum..
Never used WireGuard before..
I did find your issue also reported in the git, second in the list of issues..
The quick fix will probably be to downgrade your esp32 core to like 2.0.17..
More than likely you have auto updated to 3.0.x, which is the latest..
Sadly no work has been done to WireGuard in 3 years, so it has fallen behind..
tcpip_adapter_migration
good luck.. ~q
