hi im having problem uploading my latest data of my flex sensor to thingspeak. and whenever I bend my flex sensor it will show no difference or change in my graph and I received this error in my serial monitor "Problem updating channel. HTTP error code 200'
pls help cause this is a huge project for my final year and I'm trying out one flex sensor at first before I include another 4 in it to see if this works.
this is my code:
#include <WiFi.h>
#include "ThingSpeak.h"
const int flexPin0 = 25;
const char* ssid = "xxx"; // your network SSID (name)
const char* password = "xxx"; // your network password
WiFiClient client;
unsigned long myChannelNumber = xxxxxxx;
const char * myWriteAPIKey = "xxx";
// Timer variables
unsigned long lastTime = 0;
unsigned long timerDelay = 30000;
// Variable to hold temperature readings
//float temperatureC;
//uncomment if you want to get temperature in Fahrenheit
//float temperatureF;
// Create a sensor object
//Adafruit_BME280 bme; //BME280 connect to ESP32 I2C (GPIO 21 = SDA, GPIO 22 = SCL)
Serial.begin(115200); //Initialize serial
//initBME();
WiFi.mode(WIFI_STA);
ThingSpeak.begin(client); // Initialize ThingSpeak
if ((millis() - lastTime) > timerDelay) {
// Connect or reconnect to WiFi
if(WiFi.status() != WL_CONNECTED){
Serial.print("Attempting to connect");
while(WiFi.status() != WL_CONNECTED){
WiFi.begin(ssid, password);
delay(5000);
Serial.println("\nConnected.");
// Get a new temperature reading
int flexValue = analogRead(25);
flexValue = flexPin0;
//flexValue = analogRead(flexPin0);
/*temperatureF = 1.8 * bme.readTemperature() + 32;
Serial.print("Temperature (ºC): ");
Serial.println(temperatureF);*/
// Write to ThingSpeak. There are up to 8 fields in a channel, allowing you to store up to 8 different
// pieces of information in a channel. Here, we write to field 1.
int x = ThingSpeak.writeField(myChannelNumber, 1, flexValue, myWriteAPIKey);
//int y = ThingSpeak.writeField(myChannelNumber, 1, value1, myWriteAPIKey);
//int x = ThingSpeak.writeField(myChannelNumber, 1, temperatureF, myWriteAPIKey);
if(x == flexValue){
Serial.println("Channel update successful.");
else{
Serial.println("Problem updating channel. HTTP error code " + String(x));
lastTime = millis();
