Hi guys,
I have connected my esp32 with my hc12 like this:
HC12 RX --> ESP32 TX2
HC12 TX --> ESP32 RX2
HC12 VCC --> ESP32 3V3
HC12 GND --> ESP32 GND
I post my entire code if is not a problem:
#include <ArduinoJson.h>
//#include <SoftwareSerial.h>
#include <WiFi.h>
#include <esp_adc_cal.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "icons.h"
#include <HTTPClient.h>
#define LM35_Sensor1 35
#define RXD2 16 //(RX2)
#define TXD2 17 //(TX2)
#define HC12 Serial2 //Hardware serial 2 on the ESP32
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
//SoftwareSerial HC12(8, 7); // HC-12 TX Pin, HC-12 RX Pin
const char* ssid = "V = R * I";
const char* password = "blablabla";
int LM35_Raw_Sensor1 = 0;
float LM35_TempC_Sensor1 = 0.0;
float LM35_TempF_Sensor1 = 0.0;
float Voltage = 0.0;
bool giorno = true;
int ritenta = 0;
String desc = "default", wid = "default", type = "nointernet", rec = "";
String tempEsterna = "--.-'C", tempInterna = "--.-'C", pressioneEsterna = "--%";
float arrayTI[3]; int posATI = 0;
void task1(void * parameters){
bool nuovo = false;
for(;;){
while (HC12.available()) { // If HC-12 has data
rec += HC12.read();
Serial.println("There are some data incoming!");
Serial.println(rec);
nuovo = true;
if (nuovo == true){
int temp;
for (int i = 0; rec[i] != '@'; i++){
tempEsterna += rec[i];
temp = i;
for(int i = temp + 1; rec[i] != NULL; i++){
pressioneEsterna += rec[i];
nuovo = false;
rec = "";
//Serial.println("temperatura: " + tempEsterna + ", umidità : " + pressioneEsterna);
//display.fillRect(5, 61, 118, 2, BLACK);
//display.display();
//startBar();
vTaskDelay(100 / portTICK_PERIOD_MS);
Serial.println("searching signal");
Serial.begin(9600); // Serial port to computer
HC12.begin(9600, SERIAL_8N1, RXD2, TXD2); // Serial port to HC12
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
display.clearDisplay(); // Clear the buffer.
display.setTextSize(1);
display.setTextColor(WHITE);
WiFi.begin(ssid, password);
int cont = 0;
display.setCursor(5, 32);
display.println("<connection attempt>");
//display.println(5-cont);
display.display();
cont++;
setIcon("sole");
xTaskCreate(
task1,
"Task 1",
1000,
NULL,
1,
NULL
UpdateFromAPI();
display.fillRect(0, 49, 128, 11, BLACK);
display.display();
display.setCursor(5, 50);
display.print(desc);
display.display();
setIcon(type);
display.drawFastHLine(4, 60, 120, WHITE);
display.drawFastHLine(4, 63, 120, WHITE);
display.drawFastVLine(4, 60, 4, WHITE);
display.drawFastVLine(124, 60, 4, WHITE);
//display.drawCircle(64, 32, 3, WHITE);
updateLM35();
display.fillRect(60, 5, 68, 44, BLACK);
display.display();
display.setCursor(64, 8);
display.print(tempEsterna);
display.setCursor(64, 23);
display.print(tempInterna + "'C");
display.setCursor(64, 38);
display.print(pressioneEsterna);
display.display();
startBar();
//Serial.println("end time wait");
void startBar(){
for (int i = 1; i < 60; i+=2){
display.fillRect(5, 61, i*2, 2, WHITE);
display.display();
//updateLM35();
//display.fillRect(60, 5, 68, 44, BLACK);
//display.setCursor(64, 23);
//display.print(tempInterna + "'C");
delay(2000);
display.display();
uint32_t readADC_Cal(int ADC_Raw)
esp_adc_cal_characteristics_t adc_chars;
esp_adc_cal_characterize(ADC_UNIT_1, ADC_ATTEN_DB_11, ADC_WIDTH_BIT_12, 1100, &adc_chars);
return(esp_adc_cal_raw_to_voltage(ADC_Raw, &adc_chars));
void updateLM35(){
LM35_Raw_Sensor1 = analogRead(LM35_Sensor1);
Voltage = readADC_Cal(LM35_Raw_Sensor1);
tempInterna = (Voltage / 10) - 3;
String tmp = String(tempInterna[0]) + "" + String(tempInterna[1]) + "" + String(tempInterna[2]) + "" + String(tempInterna[3]);
if(posATI == 0){
arrayTI[posATI] = tmp.toFloat();
posATI = 1;
} else if (posATI == 1){
posATI = 2;
} else if (posATI == 2){
posATI = 0;
float temp = (arrayTI[0] + arrayTI[1] + arrayTI[2]) / 3;
String tempDiNuovo = String(temp);
tempInterna = String(tempDiNuovo[0]) + "" + String(tempDiNuovo[1]) + "" + String(tempDiNuovo[2]) + "" + String(tempDiNuovo[3]);
void setIcon(String meteo){
if(meteo == "alba"){
display.fillRect(10, 15, 36, 33, BLACK);
display.drawBitmap(10, 15, alba, 36, 33, WHITE);
display.display();
} else if (meteo == "Thunderstorm"){
display.drawBitmap(10, 15, fulmini, 36, 33, WHITE);
display.display();
} else if (meteo == "Clouds" && wid == "801" && giorno == false){
display.drawBitmap(10, 15, notte_nuvolosa, 36, 33, WHITE);
display.display();
} else if (meteo == "Clear" && giorno == false){
display.drawBitmap(10, 15, notte, 36, 33, WHITE);
display.display();
} else if (meteo == "Clouds"){
display.drawBitmap(10, 15, nuvoloso, 36, 33, WHITE);
display.display();
} else if (meteo == "Drizzle" || meteo == "Rain"){
display.drawBitmap(10, 15, pioggia, 36, 33, WHITE);
display.display();
} else if (meteo == "Clouds" && wid == "801" && giorno == true){
display.drawBitmap(10, 15, sole_nuvoloso, 36, 33, WHITE);
display.display();
} else if (meteo == "Clear" && giorno == true){
display.drawBitmap(10, 15, sole, 36, 33, WHITE);
display.display();
} else if (meteo == "tramonto"){
display.drawBitmap(10, 15, tramonto, 36, 33, WHITE);
display.display();
} else if (meteo == "Snow"){
display.drawBitmap(10, 15, neve, 36, 33, WHITE);
display.display();
display.drawBitmap(10, 15, nointernet, 36, 33, WHITE);
display.display();
void UpdateFromAPI(){
if ((WiFi.status() == WL_CONNECTED)) { //Check the current connection status
//setIcon("sole");
HTTPClient http;
DynamicJsonDocument doc(1024);
http.begin("http://api.openweathermap.org/data/2.5/weather?lat=45.96&lon=12.60&appid=e703cc05c5ab1ba3e0906bcdb542a143&lang=it"); //Specify the URL
int httpCode = http.GET(); //Make the request
String payload;
if (httpCode > 0) { //Check for the returning code
String payload = http.getString();
Serial.println(httpCode);
Serial.println(payload);
DeserializationError error = deserializeJson(doc, payload);
if (error) {
Serial.print(F("deserializeJson() failed: "));
Serial.println(error.c_str());
delay(120000);
return;
bool cicle = true;
for(int i = 0; cicle == true; i++){ //get id
if(payload[i] == 'i' && payload[i+1] == 'd'){
cicle = false;
wid = String(payload[i+4]) + "" + String(payload[i+5]) + "" + String(payload[i+6]);
//Serial.println("id: " + wid);
cicle = true;
desc = "";
for(int i = 0; cicle == true; i++) { //get short desc
if(payload[i] == 'd' && payload[i+10] == 'n'){
cicle = false;
int j = i;
while(payload[j+14] != ','){
if (payload[j+14] != '"')
desc += payload[j+14];
j++;
//Serial.println("short desc: " + desc);
if(desc.length() >= 17){
int temp = 0;
String tmp = "";
for (int h = 0; h <= 17; h++){
tmp += desc[h];
desc = tmp + "...";
cicle = true;
type = "";
for(int i = 0; cicle == true; i++){ //get type weather
if(payload[i] == 'm' && payload[i+3] == 'n'){
cicle = false;
int j = i;
while(payload[j+7] != ','){
if (payload[j+7] != '"')
type += payload[j+7];
j++;
//Serial.println("weather type: " + type);
http.end();
if(ritenta == 10){
ritenta = 0;
} else
ritenta++;
setIcon("nointernet");
type = "nointernet";
desc = "no internet";
The problem is that he continually thinks that there are coming data, why?
