Hi Everyone,
I am building a Project to control a pool pump. (ESP32 Wroom32)
There are specific conditions when the pool pump must engage and disengage.
Everything works 100% but I have a DHT22 Sensor that is Acting up Randomly when The Relay Switches off, then the DHT22 Sensor "freezes". (Startup is fine).
I have other Temp sensors on as well to Monitor the Pool Temp and Roof Temp DS18B20 Waterproof Sensors, they continue to read normal when the relay switches off.
I have tried 2x Libraries for the DHT22 Sensor, the one Displays NaN the Other-Current One Freezes.
The DHT22 Sensor Values does nothing to the Operation, but I would like to display the Indoor temp and humid on the screen. (without having to restart the esp32 everyday)
I have tried to install a different DHT22 Sensor as well (Same issues)
I am powering Everything on the ESP32 with 3.3V and the Relay with 5V.
The Power supply Module takes in 9V and then Splits it into 3.3 and 5V Rails that can be used.
Connected to ESP32 is:
3x 5mmLED's (3.3V)
1x Pushbutton (3.3V)
1x 3.5" TFT Display (3.3V)
1x DHT22 Sensor (3.3V)
2x DS18B20 Sensors (3.3V)
1x DS3231 RTC Module (3.3V)
1x 30amp TongLing Relay (This Handles 220V To Switch On the PoolPump) (5V)
Code is as Follows:
#include <Arduino.h>
#include <TFT_eSPI.h>
#include <SPI.h>
#include <RTClib.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <DHT22.h>
#include "font.h"
#include "powerIcon.h"
#include "pumpIcon.h"
#include "bypassIcon.h"
#define ONE_WIRE_BUS 25 // DS18B20 Temp Sensors
#define POWER_LED 32
#define POOL_PUMP_LED 33
#define BYPASS_LED 27
#define BYPASS_BTN 5
#define RELAY_PIN 14
// Setup a oneWire instance to communicate with any OneWire devices &
// Pass oneWire reference to Dallas Temperature.
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature tempSensors(&oneWire);
// DS18B20 Temp Sensor Addresses.
uint8_t roofSensor[8] = { 0x28, 0xD3, 0x02, 0x48, 0xF6, 0xD2, 0x3C, 0x74 };
uint8_t poolSensor[8] = { 0x28, 0xFF, 0x64, 0x1E, 0x0E, 0x78, 0x25, 0x43 };
// ############################ TFT Display Constructor and Sprite Constructor ####################
// 480 x 320 TFT Display
TFT_eSPI tft = TFT_eSPI();
TFT_eSprite sprite = TFT_eSprite(&tft);
// ############################ RTC Instance for DS3231 RTC #######################################
RTC_DS3231 rtc;
// ############################ Humidity / Temp Sensor (DHT22) ####################################
DHT22 dht (19);
// ############################ Project Variables #################################################
bool byPassON = false; // Bypass On/Off Value
float roofTemp = 0.00; // DS18B20 Roof Temp
float lapaTemp = 0.00; // Store Lapa Temp DHT22 Sensor
float lapaHumid = 0.00; // Store Lapa Humid DHT22 Sensor
const float activationTemp = 25.00; // Adjust this Temp to activate the pool pump (mimimum temp)
const int timeIntervals[4] = {0, 15, 30, 45}; // 15min Intervals to activate pool pump
int bypassLedState = LOW; // Store the Bypass LED State (As it changes)
unsigned long blinkLastMillis = 0; // Store last Millis to blink LED every 1 Sec
// Call this function to setup the date and time for the fist time.
// January 21, 2014 at 3am you would call:
//rtc.begin();
//rtc.adjust(DateTime(2024, 4, 27, 17, 25, 0));
rtc.begin();
tempSensors.begin();
pinMode(POWER_LED, OUTPUT);
pinMode(POOL_PUMP_LED, OUTPUT);
pinMode(RELAY_PIN, OUTPUT);
pinMode(BYPASS_LED, OUTPUT);
pinMode(BYPASS_BTN, INPUT_PULLUP);
digitalWrite(POWER_LED, HIGH);
tft.init();
tft.setRotation(3);
tft.fillScreen(TFT_BLACK);
tft.setTextColor(TFT_WHITE, TFT_BLACK);
tft.drawString("POOL PUMP CONTROLLER", 5, 5, 4);
tft.drawString("Version | V1.0", 385, 300, 2);
tft.drawLine(0, 30, 480, 30, TFT_WHITE);
tft.setFreeFont(&Open_Sans_Bold_30);
tft.drawString("POOL TEMP C",60 ,130);
tft.drawString("LAPA TEMP C",60 ,170);
tft.drawString("ROOF TEMP C",60 ,210);
tft.drawString("HUMIDITY %",60 ,270);
tft.drawCircle(375, 130, 3, TFT_WHITE);
tft.drawCircle(375, 173, 3, TFT_WHITE);
tft.drawCircle(375, 210, 3, TFT_WHITE);
sprite.createSprite(24, 24);
sprite.setSwapBytes(true);
sprite.pushImage(0, 0, 24, 24, power);
sprite.pushSprite(450, 3, TFT_BLACK);
displayMain();
togglePoolPump();
toggleBypass();
// Display All Main Temp Data
void displayMain(){
tempSensors.requestTemperatures(); // Read Temp Data from DS18B20 Sensors
lapaTemp = dht.getTemperature(); // Read Temp and Humidity Data from DHT22 Sensor
lapaHumid = dht.getHumidity(); //
// Display time clock on the display.
DateTime t = rtc.now();
tft.setTextColor(TFT_GREENYELLOW, TFT_BLACK);
tft.drawString(String(t.timestamp(DateTime::TIMESTAMP_TIME)),120, 50, 7);
// display Temp Data on the Display
float realPoolTemp = tempSensors.getTempC(poolSensor) - 1.00; // deduct 1 degree from pool tmp.
float realRoofTemp = tempSensors.getTempC(roofSensor) - 1.00; // deduct 1 degree from roof tmp.
tft.drawString(String(realPoolTemp),260 ,130);
tft.drawString(String(lapaTemp),260 ,170);
tft.drawString(String(realRoofTemp),260 ,210);
tft.drawString(String(lapaHumid),260 ,270);
// Activate / Deactivate Pool Pump Relay
void togglePoolPump(){
for(int i = 0; i < 4; i++){
if(timeIntervals[i] == t.minute()){
roofTemp = tempSensors.getTempC(roofSensor) - 1.00;
if((t.hour() > 10) && (t.hour() < 15) && (roofTemp > activationTemp) ){
digitalWrite(POOL_PUMP_LED, HIGH);
digitalWrite(RELAY_PIN, HIGH);
sprite.createSprite(24, 24); // Display Pool Pump Icon
sprite.pushImage(0, 0, 24, 24, pump);
sprite.pushSprite(420, 3, TFT_BLACK);
else{
digitalWrite(POOL_PUMP_LED, LOW);
digitalWrite(RELAY_PIN, LOW);
tft.fillRect(380, 3, 70, 24, TFT_BLACK);
// Activate / Deactivate Bypass
void toggleBypass(){
if (!digitalRead(BYPASS_BTN)) { // Bypass ACTIVATE (Button Press) (HOLD)
byPassON = true;
while (byPassON) {
displayMain(); // Display TEMP
blinkBypassLED(); // Display Bypass Indicator Blink LED
digitalWrite(POOL_PUMP_LED, HIGH); // Pool Pump ON !
digitalWrite(RELAY_PIN, HIGH); // Relay ON !
sprite.createSprite(24, 24); // Display Bypass Icon
sprite.pushImage(0, 0, 24, 24, bypass);
sprite.pushSprite(390, 3, TFT_BLACK);
if (!digitalRead(BYPASS_BTN)) { // Bypass DEACTIVATE (Button Press) (HOLD)
byPassON = false;
digitalWrite(BYPASS_LED, LOW);
// Bypass Indicator LED (Blink - LED)
void blinkBypassLED(){
unsigned long bypassBlinkMillis = millis();
if(bypassBlinkMillis - blinkLastMillis >= 1000){
blinkLastMillis = bypassBlinkMillis;
if(bypassLedState == LOW){
bypassLedState = HIGH;
}else {
digitalWrite(BYPASS_LED, bypassLedState);
