ESP32-wroom-38 pin board selection
Hello..
I am using ESP32 wroom - 38 pin.
Which board should I select for this microcontroller in Arduino IDE?
I moved your topic to an appropriate forum category @amar02kne.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
you should select esp32 dev module board
Hi @amar02kne. Select Tools > Board > esp32 > ESP32 Dev Module from the Arduino IDE menus. There are several other menus under the IDE's Tools menu that you can use to make additional configurations for the board, but the default values should be fine to get started with so simply selecting Tools > Board > esp32 > ESP32 Dev Module will be sufficient to get started.
If you don't see an "esp32 item under the Tools > Board, install support for the ESP32 boards by following the instructions here:
https://docs.espressif.com/projects/arduino-esp32/en/latest/installing.html#installing-using-arduino-ide
hello @ptillisch can you help me in my project
I see you are already receiving assistance from the other forum helpers over on your topic:
