ESP32-WROOM and Mocute Controller
The following manages to get the Mocute Bluetooth controller working with an ESP32-WROOM-32D module and the NimBLE library.
The code is still being worked on as of 6/14/2024 but a demo of the action buttons.
I found some ESP32 BLE example code from HERE. I think it was originally for communicating with an Xbox 360 controller, so you can use that as well (with minor changes)
The Code (unfinished). Once everything is working correctly I will clean up the code and make proper methods for ease of use.
NOTE: You must hold the A button when powering on the controller, otherwise the ESP32 module will not connect to it.
// Reference: https://github.com/h2zero/NimBLE-Arduino/blob/master/examples/NimBLE_Client/NimBLE_Client.ino
// Reference: https://github.com/asukiaaa/esp32-client-for-xbox-controller-with-nim-ble/blob/master/src/main.cpp
Mocute Controller (Index) | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10| 11| 12| 13| 14|
L Stick                   | xx| xx| yy| yy|   |   |   |   |   |   |   |   |   |   |   |
R Stick                   |   |   |   |   | xx| xx| yy| yy|   |   |   |   |   |   |   |
L2/LT Button              |   |   |   |   |   |   |   |   | FF| 03|   |   |   |   |   |
R2/RT Button              |   |   |   |   |   |   |   |   |   |   | FF| 03|   |   |   |
DPad                      |   |   |   |   |   |   |   |   |   |   |   |   | X |   |   |
Action Buttons            |   |   |   |   |   |   |   |   |   |   |   |   |   | X |   |
Joystick Hat Buttons      |   |   |   |   |   |   |   |   |   |   |   |   |   |   | X |
Action Buttons:
A       0x01
B       0x02
X       0x04
Y       0x08
L1/LB   0x10
R1/RB   0x20
Select  0x40
Start   0x80
L2/LT   0x03FF (See chart)
R2/RT   0x03FF (See chart)
L3/LHat 0x01
R3/RHat 0x02
DPad Default 0x09
Up    0x01
Right 0x03
Down  0x05
Left  0x07
UR    0x02
UL    0x08
DR    0x04
DL    0x06
#include <Arduino.h>
#include <NimBLEDevice.h>
void scanEndedCB(NimBLEScanResults results);
static NimBLEAdvertisedDevice* advDevice;
bool scanning = false;
bool connected = false;
static uint32_t scanTime = 0; /** 0 = scan forever */
static NimBLEAddress targetDeviceAddress("d4:14:a7:ca:40:0d");
static NimBLEUUID uuidServiceHid("1812");
class ClientCallbacks : public NimBLEClientCallbacks {
  void onConnect(NimBLEClient* pClient) {
    Serial.println("Connected");
    connected = true;
    // pClient->updateConnParams(120,120,0,60);
  void onDisconnect(NimBLEClient* pClient) {
    Serial.print(pClient->getPeerAddress().toString().c_str());
    Serial.println(" Disconnected");
    connected = false;
  /** Called when the peripheral requests a change to the connection parameters.
   *  Return true to accept and apply them or false to reject and keep
   *  the currently used parameters. Default will return true.
  bool onConnParamsUpdateRequest(NimBLEClient* pClient,
                                 const ble_gap_upd_params* params) {
    Serial.print("onConnParamsUpdateRequest");
    if (params->itvl_min < 24) { /** 1.25ms units */
      return false;
    } else if (params->itvl_max > 40) { /** 1.25ms units */
      return false;
    } else if (params->latency > 2) { /** Number of intervals allowed to skip */
      return false;
    } else if (params->supervision_timeout > 100) { /** 10ms units */
      return false;
    return true;
  /********************* Security handled here **********************
  ****** Note: these are the same return values as defaults ********/
  uint32_t onPassKeyRequest() {
    Serial.println("Client Passkey Request");
    /** return the passkey to send to the server */
    return 0;
  bool onConfirmPIN(uint32_t pass_key) {
    Serial.print("The passkey YES/NO number: ");
    Serial.println(pass_key);
    /** Return false if passkeys don't match. */
    return true;
  /** Pairing process complete, we can check the results in ble_gap_conn_desc */
  void onAuthenticationComplete(ble_gap_conn_desc* desc) {
    Serial.println("onAuthenticationComplete");
    if (!desc->sec_state.encrypted) {
      Serial.println("Encrypt connection failed - disconnecting");
      /** Find the client with the connection handle provided in desc */
      NimBLEDevice::getClientByID(desc->conn_handle)->disconnect();
      return;
/** Define a class to handle the callbacks when advertisments are received */
class AdvertisedDeviceCallbacks : public NimBLEAdvertisedDeviceCallbacks {
  void onResult(NimBLEAdvertisedDevice* advertisedDevice) {
    Serial.print("Advertised Device found: ");
    Serial.println(advertisedDevice->toString().c_str());
    Serial.printf("name:%s, address:%s\n", advertisedDevice->getName().c_str(),
                  advertisedDevice->getAddress().toString().c_str());
    Serial.printf("uuidService:%s\n",
                  advertisedDevice->haveServiceUUID()
                    ? advertisedDevice->getServiceUUID().toString().c_str()
                    : "none");
    if (advertisedDevice->getAddress().equals(targetDeviceAddress)) {
      Serial.println("Found Our Service");
      /** stop scan before connecting */
      NimBLEDevice::getScan()->stop();
      /** Save the device reference in a global for the client to use*/
      advDevice = advertisedDevice;
unsigned long printInterval = 100UL;
bool checkButton(uint8_t* data, byte index, byte mask, byte length = 15) {
  if (index > length) return false;
  return data[index] & mask;
void pollButtons(uint8_t* data) {
  // DPAD
  switch (data[12]) {
    case 1: Serial.println("Up Pressed"); break;
    case 2: Serial.println("Up Right Pressed"); break;
    case 3: Serial.println("Right Pressed"); break;
    case 4: Serial.println("Down Right Pressed"); break;
    case 5: Serial.println("Down Pressed"); break;
    case 6: Serial.println("Down Left Pressed"); break;
    case 7: Serial.println("Left Pressed"); break;
    case 8: Serial.println("Up Left Pressed"); break;
    case 9: break;
  // Action Buttons
  if (checkButton(data, 13, 0x01)) {
    Serial.println("A Pressed");
  if (checkButton(data, 13, 0x02)) {
    Serial.println("B Pressed");
  if (checkButton(data, 13, 0x04)) {
    Serial.println("X Pressed");
  if (checkButton(data, 13, 0x08)) {
    Serial.println("Y Pressed");
  if (checkButton(data, 13, 0x10)) {
    Serial.println("L1 Pressed");
  if (checkButton(data, 13, 0x20)) {
    Serial.println("R1 Pressed");
  if (checkButton(data, 13, 0x40)) {
    Serial.println("Select Pressed");
  if (checkButton(data, 13, 0x80)) {
    Serial.println("Start Pressed");
  if (checkButton(data, 8, 0xFF)) {
    Serial.println("L2 Pressed");
  if (checkButton(data, 10, 0xFF)) {
    Serial.println("R2 Pressed");
  if (checkButton(data, 14, 0x01)) {
    Serial.println("L3 Pressed");
  if (checkButton(data, 14, 0x02)) {
    Serial.println("R3 Pressed");
/** Notification / Indication receiving handler callback */
void notifyCB(NimBLERemoteCharacteristic* pRemoteCharacteristic, uint8_t* pData,
              size_t length, bool isNotify) {
  static bool isPrinting = false;
  static unsigned long printedAt = 0;
  if (isPrinting || millis() - printedAt < printInterval) return;
  isPrinting = true;
  std::string str = (isNotify == true) ? "Notification" : "Indication";
  str += " from ";
  /** NimBLEAddress and NimBLEUUID have std::string operators */
  str += std::string(
    pRemoteCharacteristic->getRemoteService()->getClient()->getPeerAddress());
  str += ": Service = " + std::string(pRemoteCharacteristic->getRemoteService()->getUUID());
  str += ", Characteristic = " + std::string(pRemoteCharacteristic->getUUID());
  // str += ", Value = " + std::string((char*)pData, length);
  Serial.println(str.c_str());
  Serial.print("Length: ");
  Serial.println(length);
  Serial.print("value: ");
  for (int i = 0; i < length; ++i) {
    Serial.printf(" %02x", pData[i]);
  Serial.println("");
  pollButtons(pData);
  Serial.println("");
  printedAt = millis();
  isPrinting = false;
void scanEndedCB(NimBLEScanResults results) {
  Serial.println("Scan Ended");
  scanning = false;
static ClientCallbacks clientCB;
void charaPrintId(NimBLERemoteCharacteristic* pChara) {
  Serial.printf("s:%s c:%s h:%d",
                pChara->getRemoteService()->getUUID().toString().c_str(),
                pChara->getUUID().toString().c_str(), pChara->getHandle());
void printValue(std::__cxx11::string str) {
  Serial.printf("str: %s\n", str.c_str());
  Serial.printf("hex:");
  for (auto v : str) {
    Serial.printf(" %02x", v);
  Serial.println("");
void charaRead(NimBLERemoteCharacteristic* pChara) {
  if (pChara->canRead()) {
    charaPrintId(pChara);
    Serial.println(" canRead");
    auto str = pChara->readValue();
    if (str.size() == 0) {
    printValue(str);
void charaSubscribeNotification(NimBLERemoteCharacteristic* pChara) {
  if (pChara->canNotify()) {
    Serial.println(" canNotify ");
    if (pChara->subscribe(true, notifyCB, true)) {
      Serial.println("set notifyCb");
      // return true;
      Serial.println("failed to subscribe");
bool afterConnect(NimBLEClient* pClient) {
  for (auto pService : *pClient->getServices(true)) {
    auto sUuid = pService->getUUID();
    if (!sUuid.equals(uuidServiceHid)) {
      continue;  // skip
    Serial.println(pService->toString().c_str());
    for (auto pChara : *pService->getCharacteristics(true)) {
      charaRead(pChara);
      charaSubscribeNotification(pChara);
  return true;
/** Handles the provisioning of clients and connects / interfaces with the
 * server */
bool connectToServer(NimBLEAdvertisedDevice* advDevice) {
  NimBLEClient* pClient = nullptr;
  /** Check if we have a client we should reuse first **/
  if (NimBLEDevice::getClientListSize()) {
    pClient = NimBLEDevice::getClientByPeerAddress(advDevice->getAddress());
    if (pClient) {
      pClient->connect();
  /** No client to reuse? Create a new one. */
  if (!pClient) {
    if (NimBLEDevice::getClientListSize() >= NIMBLE_MAX_CONNECTIONS) {
      Serial.println("Max clients reached - no more connections available");
      return false;
    pClient = NimBLEDevice::createClient();
    Serial.println("New client created");
    pClient->setClientCallbacks(&clientCB, false);
    pClient->setConnectionParams(12, 12, 0, 51);
    pClient->setConnectTimeout(5);
    pClient->connect(advDevice, false);
  int retryCount = 5;
  while (!pClient->isConnected()) {
    if (retryCount <= 0) {
      return false;
      Serial.println("try connection again " + String(millis()));
    pClient->disconnect();
    // Serial.println(pClient->toString().c_str());
    pClient->connect(true);
    --retryCount;
  Serial.print("Connected to: ");
  Serial.println(pClient->getPeerAddress().toString().c_str());
  Serial.print("RSSI: ");
  Serial.println(pClient->getRssi());
  pClient->discoverAttributes();
  bool result = afterConnect(pClient);
  if (!result) {
    return result;
  Serial.println("Done with this device!");
  return true;
  Serial.println("Starting NimBLE Client");
  /** Initialize NimBLE, no device name spcified as we are not advertising */
  NimBLEDevice::init("");
  NimBLEDevice::setOwnAddrType(BLE_OWN_ADDR_RANDOM);
  NimBLEDevice::setSecurityAuth(true, true, true);
  NimBLEDevice::setPower(ESP_PWR_LVL_P9); /** +9db */
void startScan() {
  scanning = true;
  auto pScan = NimBLEDevice::getScan();
  pScan->setAdvertisedDeviceCallbacks(new AdvertisedDeviceCallbacks());
  pScan->setInterval(45);
  pScan->setWindow(15);
  Serial.println("Start scan");
  pScan->start(scanTime, scanEndedCB);
  if (!connected) {
    if (!scanning && advDevice == nullptr) {
      startScan();
    if (advDevice != nullptr) {
      if (connectToServer(advDevice)) {
        Serial.println("Success! we should now be getting notifications");
        Serial.println("Failed to connect");
      advDevice = nullptr;
  // Serial.println("scanning:" + String(scanning) + " connected:" + String(connected) + " advDevice is nullptr:" + String(advDevice == nullptr));
  delay(2000);
