ESP32 WROOM not connect to port
Hi
I have this board:
When connected the red LED is on
When connected to IDE it reports no port
I have pressed BOOT + EN, then released EN but no port shows.
Any tip?
Can it be delivered without operating system?
run the Windows device manager, expand Ports (COM & LPT) - unplug/plugin the ESP USB cable - does a COM port disappear/appear?
type a different USB port
try a different USB cable (some cables are power only - no data)
Thanks!
Exact tip, driver was not updated to the new WROOM generation.
Now all work
Which driver does it use? Is it CP 2102? Please check if you have done the board installation properly.
Yes cp2102, works perfect!
OK. Can be a bad cable too.
Use a good data cable and check Installing ESP32 in Arduino IDE (Windows, Mac OS X, Linux)
