ESP32 Wroom - Serial Port
Hello
I am using Uart 2 on pins 16 and 17 of the ESP32 Wroom module
Setup consists of ......
Serial2.begin(115200, SERIAL_8N1, RXD2, TXD2);
Serial2.println("Hello World");
When the module is rebooted a 3 ramdon characters are printed prior to the string
Is there away to prevent this from happening ?
Any suggestions would be appreciated
Thank you
Start up glitches are common on serial ports. Why do you need to prevent it?
Where is serial2 printing to?
The ESP32 uses GPIO_1 and GPIO_3 to print to the serial monitor.
Serial1 is naturally assigned to GPIO_16 and GPIO_17. Mapping one Serial2 to Serial1 may not be the wisest use.
On an ESP32 I use serial this way
#include <HardwareSerial.h>
HardwareSerial SerialTFMini( 1 );
HardwareSerial SerialBrain( 2 );
////// serial(1) = pin27=RX green, pin26=TX white
////// serial(2) = pin16=RXgreen , pin17=TX white
voided setup()
  Serial.begin( SerialDataBits );
  SerialBrain.begin( SerialDataBits );
  SerialTFMini.begin(  SerialDataBits, SERIAL_8N1, 27, 26 );
There is a chance the connected device may do something strange if it receives bad sequence of characters....It would seem logical to eliminate if possible
What is the connected device? How does it interpret your, "Hello world"? :slight_smile:
Suppress Boot messages - ESP32 Forum
Under Arduino, I do not know if there is a solution.
