ESP32 WROOM32E touch interrupt problem
Having issues with touch interrupts on WROOM 32E, problem does not appear on devkit with WROOM 32D.
Using arduino ide v2.3.4 for programing, using the provided example for touch interrupt with pins T4 and T5.
Both touch pins are working and trigger interrupt when touched. However when one pin is touched twice in a row and then the other pin is touched, there is an incorrect triggering of the first pin as well. For example if pins touched are T4, T4, and then T5 (with appropriate delay) the output will be:
ESP32 Touch Interrupt Test
Touch 1 detected
Touch 1 detected
Touch 1 detected
Touch 2 detected
This problem did not occur on older esp32 modules including devkits i have with WROOM 32 and WROOM 32D modules but the issue shows up on my new custom hardware with WROOM 32E. I have tried out several boards with WROOM 32E including two brand new devkits purchased from amazon with WROOM 32E modules and the problem persists.
I also tried using the iram_attr on the interrupts and tried declaring all involved variables as volatile, static and also static volatile just to see if it had any effect and nothing changed. Baseline touchread value is approximately 50 on my board and with pin touched it is approx 15 so threshold is set to 30. Confirmed it is not a cross triggering problem as the touchread value for each pin does not vary significantly when the other pin is touched.
Not sure what is going on here... i was able to upload the touch interrupt example that is included in the ESP IDF framework using ESP IDE and the problem was not present, so it appears to be a problem with arduino IDE. If someone with access to a devkit with WROOM 32E could try this and confirm the problem it would be very helpful.
Code used:
int threshold = 30;
unsigned long lastTouch1Time = 0;
unsigned long lastTouch2Time = 0;
bool touch1detected = false;
bool touch2detected = false;
void gotTouch1() {
if (millis() - lastTouch1Time > 300) {
touch1detected = true;
lastTouch1Time = millis();
void gotTouch2() {
if (millis() - lastTouch2Time > 300) {
touch2detected = true;
lastTouch2Time = millis();
delay(2000); // Stabilization delay
Serial.println("ESP32 Touch Interrupt Test");
touchAttachInterrupt(T4, gotTouch1, threshold);
touchAttachInterrupt(T5, gotTouch2, threshold);
if (touch1detected) {
Serial.println("Touch 1 detected");
if (touch2detected) {
Serial.println("Touch 2 detected");
