Hi there,
I am new to the artduino-world, but have some background on Atmels AVRs and Linux development.
I got some ESP32-WROVER-E (named DASDUINO ConnectPlus) boards and try to read a shelly 3em through WiFi. I used the BasicHTTPClient example to receive the response from the shelly and print out the reading to serial. I added code from the JSON example to beatify the reading.
After a short while, the ESP crashes and resets, printing the following:
09:14:41.429 -> [SETUP] WAIT 4...
09:14:42.437 -> [SETUP] WAIT 3...
09:14:43.464 -> [SETUP] WAIT 2...
09:14:44.442 -> [SETUP] WAIT 1...
09:14:48.498 -> Voltage : 235.11V
09:14:48.498 -> Current : 1.63A
09:14:49.535 -> Voltage : 235.11V
09:14:49.535 -> Current : 1.63A
09:14:50.576 -> Voltage : 235.42V
09:14:50.576 -> Current : 1.59A
09:14:51.723 -> Voltage : 235.27V
09:14:51.723 -> Current : 1.62A
09:14:52.792 -> Voltage : 235.25V
09:14:52.792 -> Current : 1.61A
09:14:52.792 -> Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
09:14:52.792 -> Core 1 register dump:
09:14:52.792 -> PC : 0x401667f4 PS : 0x00060a30 A0 : 0x800d56e2 A1 : 0x3ffc9be0
09:14:52.792 -> A2 : 0x3ffc9c6c A3 : 0x00000000 A4 : 0xffffffff A5 : 0x00000001
09:14:52.826 -> A6 : 0x00000000 A7 : 0x00000001 A8 : 0x00000000 A9 : 0x3ffc9bc0
09:14:52.826 -> A10 : 0x3ffd51f8 A11 : 0x00000000 A12 : 0x00000001 A13 : 0x0000ff00
09:14:52.826 -> A14 : 0x00ff0000 A15 : 0xff000000 SAR : 0x0000001f EXCCAUSE: 0x0000001c
09:14:52.826 -> EXCVADDR: 0x00000010 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xffffffff
09:14:52.826 ->
09:14:52.826 -> ELF file SHA256: 0000000000000000
09:14:52.857 ->
09:14:52.857 -> Backtrace: 0x401667f4:0x3ffc9be0 0x400d56df:0x3ffc9c00 0x400d575d:0x3ffc9c20 0x400d355a:0x3ffc9c40 0x400d9da9:0x3ffc9d20 0x4008b296:0x3ffc9d40
09:14:52.857 ->
09:14:52.857 -> Rebooting...
09:14:52.857 -> ets Jul 29 2019 12:21:46
09:14:52.857 ->
09:14:52.857 -> rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
09:14:52.857 -> configsip: 0, SPIWP:0xee
09:14:52.857 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
09:14:52.897 -> mode:DIO, clock div:2
09:14:52.897 -> load:0x3fff0018,len:4
09:14:52.897 -> load:0x3fff001c,len:1100
09:14:52.897 -> load:0x40078000,len:10900
09:14:52.897 -> load:0x40080400,len:6360
Here is my code:
* BasicHTTPClient.ino
* Created on: 24.05.2015
#include <Arduino.h>
#include <ArduinoJson.h>
#include <WiFi.h>
#include <WiFiMulti.h>
#include <HTTPClient.h>
#include "wifi-credentials.h"
#define USE_SERIAL Serial
WiFiMulti wifiMulti;
const char* ca = \
"-----BEGIN CERTIFICATE-----\n" \
"MIIEkjCCA3qgAwIBAgIQCgFBQgAAAVOFc2oLheynCDANBgkqhkiG9w0BAQsFADA/\n" \
"MSQwIgYDVQQKExtEaWdpdGFsIFNpZ25hdHVyZSBUcnVzdCBDby4xFzAVBgNVBAMT\n" \
"DkRTVCBSb290IENBIFgzMB4XDTE2MDMxNzE2NDA0NloXDTIxMDMxNzE2NDA0Nlow\n" \
"SjELMAkGA1UEBhMCVVMxFjAUBgNVBAoTDUxldCdzIEVuY3J5cHQxIzAhBgNVBAMT\n" \
"GkxldCdzIEVuY3J5cHQgQXV0aG9yaXR5IFgzMIIBIjANBgkqhkiG9w0BAQEFAAOC\n" \
"AQ8AMIIBCgKCAQEAnNMM8FrlLke3cl03g7NoYzDq1zUmGSXhvb418XCSL7e4S0EF\n" \
"q6meNQhY7LEqxGiHC6PjdeTm86dicbp5gWAf15Gan/PQeGdxyGkOlZHP/uaZ6WA8\n" \
"SMx+yk13EiSdRxta67nsHjcAHJyse6cF6s5K671B5TaYucv9bTyWaN8jKkKQDIZ0\n" \
"Z8h/pZq4UmEUEz9l6YKHy9v6Dlb2honzhT+Xhq+w3Brvaw2VFn3EK6BlspkENnWA\n" \
"a6xK8xuQSXgvopZPKiAlKQTGdMDQMc2PMTiVFrqoM7hD8bEfwzB/onkxEz0tNvjj\n" \
"/PIzark5McWvxI0NHWQWM6r6hCm21AvA2H3DkwIDAQABo4IBfTCCAXkwEgYDVR0T\n" \
"AQH/BAgwBgEB/wIBADAOBgNVHQ8BAf8EBAMCAYYwfwYIKwYBBQUHAQEEczBxMDIG\n" \
"CCsGAQUFBzABhiZodHRwOi8vaXNyZy50cnVzdGlkLm9jc3AuaWRlbnRydXN0LmNv\n" \
"bTA7BggrBgEFBQcwAoYvaHR0cDovL2FwcHMuaWRlbnRydXN0LmNvbS9yb290cy9k\n" \
"c3Ryb290Y2F4My5wN2MwHwYDVR0jBBgwFoAUxKexpHsscfrb4UuQdf/EFWCFiRAw\n" \
"VAYDVR0gBE0wSzAIBgZngQwBAgEwPwYLKwYBBAGC3xMBAQEwMDAuBggrBgEFBQcC\n" \
"ARYiaHR0cDovL2Nwcy5yb290LXgxLmxldHNlbmNyeXB0Lm9yZzA8BgNVHR8ENTAz\n" \
"MDGgL6AthitodHRwOi8vY3JsLmlkZW50cnVzdC5jb20vRFNUUk9PVENBWDNDUkwu\n" \
"Y3JsMB0GA1UdDgQWBBSoSmpjBH3duubRObemRWXv86jsoTANBgkqhkiG9w0BAQsF\n" \
"AAOCAQEA3TPXEfNjWDjdGBX7CVW+dla5cEilaUcne8IkCJLxWh9KEik3JHRRHGJo\n" \
"uM2VcGfl96S8TihRzZvoroed6ti6WqEBmtzw3Wodatg+VyOeph4EYpr/1wXKtx8/\n" \
"wApIvJSwtmVi4MFU5aMqrSDE6ea73Mj2tcMyo5jMd6jmeWUHK8so/joWUoHOUgwu\n" \
"X4Po1QYz+3dszkDqMp4fklxBwXRsW10KXzPMTZ+sOPAveyxindmjkW8lGy+QsRlG\n" \
"PfZ+G6Z6h7mjem0Y+iWlkYcV4PIWL1iwBi8saCbGS5jN2p8M+X+Q7UNKEkROb3N6\n" \
"KOqkqm57TH2H3eDJAkSnh6/DNFu0Qg==\n" \
"-----END CERTIFICATE-----\n";
float power;
float voltage;
float current;
float total_power;
void readJson(String json){
// Allocate the JSON document
JsonDocument doc;
// Deserialize the JSON document
DeserializationError error = deserializeJson(doc, json);
// Test if parsing succeeds
if (error) {
USE_SERIAL.print(F("deserializeJson() failed: "));
USE_SERIAL.println(error.f_str());
return;
power = doc["power"];
voltage = doc["voltage"];
current= doc["current"];
USE_SERIAL.print("Voltage ");
USE_SERIAL.print(": ");
USE_SERIAL.print(voltage);
USE_SERIAL.println("V");
USE_SERIAL.print("Current ");
USE_SERIAL.print(current);
USE_SERIAL.println("A");
USE_SERIAL.begin(115200);
for(uint8_t t = 4; t > 0; t--) {
USE_SERIAL.printf("[SETUP] WAIT %d...\n", t);
USE_SERIAL.flush();
wifiMulti.addAP(ssid, password);
// wait for WiFi connection
if((wifiMulti.run() == WL_CONNECTED)) {
HTTPClient http;
//USE_SERIAL.print("[HTTP] begin...\n");
// configure traged server and url
//http.begin("https://www.howsmyssl.com/a/check", ca); //HTTPS
http.begin("http://192.168.178.30/emeter/0"); //HTTP
//USE_SERIAL.print("[HTTP] GET...\n");
// start connection and send HTTP header
int httpCode = http.GET();
// httpCode will be negative on error
if(httpCode > 0) {
// HTTP header has been send and Server response header has been handled
//USE_SERIAL.printf("[HTTP] GET... code: %d\n", httpCode);
// file found at server
if(httpCode == HTTP_CODE_OK) {
String payload = http.getString();
readJson(payload);
//USE_SERIAL.println(payload);
USE_SERIAL.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
http.end();
USE_SERIAL.flush();
What is the problem? I didn't expect the examples to cause errors so quickly. If I strip down the code, the crashes need more time to occur, but they do.
If anyone can help me,that would be nice. I didn't want to use another raspberrypi for such a simple task. Thanks.
