Hello guys, im new here.
I want to build a few wall lights using the ESP32, WS2812B and a power supply.
Im using Homespan for HomeKit.
It works well so far but there is just a thing that I would love to have.
When I switch on the light, I would love that the Led´s turns on smoothly like a soft transition. Same for Color changes or switching off the light.
Does anyone have an idea?
Here the Code that im using:
#if defined(CONFIG_IDF_TARGET_ESP32)
#define NEOPIXEL_RGB_PIN 26
#define NEOPIXEL_RGBW_PIN 32
#define DOTSTAR_DATA_PIN 33
#define DOTSTAR_CLOCK_PIN 27
#define DEVICE_SUFFIX ""
#elif defined(CONFIG_IDF_TARGET_ESP32S2)
#define NEOPIXEL_RGB_PIN 17
#define NEOPIXEL_RGBW_PIN 38
#define DOTSTAR_CLOCK_PIN 7
#define DEVICE_SUFFIX "-S2"
#elif defined(CONFIG_IDF_TARGET_ESP32C3)
#define NEOPIXEL_RGB_PIN 0
#define DOTSTAR_DATA_PIN 7
#define DEVICE_SUFFIX "-C3"
#endif
#include "HomeSpan.h"
struct NeoPixel_RGB : Service::LightBulb { // Addressable single-wire RGB LED Strand (e.g. NeoPixel)
Characteristic::On power{0,true};
Characteristic::Hue H{0,true};
Characteristic::Saturation S{0,true};
Characteristic::Brightness V{100,true};
Pixel *pixel;
int nPixels;
NeoPixel_RGB(uint8_t pin, int nPixels) : Service::LightBulb(){
V.setRange(5,100,1); // sets the range of the Brightness to be from a min of 5%, to a max of 100%, in steps of 1%
pixel=new Pixel(pin); // creates Pixel RGB LED on specified pin
nPixels=37;
this->nPixels=nPixels; // save number of Pixels in this LED Strand
update(); // manually call update() to set pixel with restored initial values
boolean update() override {
int p=power.getNewVal();
float h=H.getNewVal<float>(); // range = [0,360]
float s=S.getNewVal<float>(); // range = [0,100]
float v=V.getNewVal<float>(); // range = [0,100]
Pixel::Color color;
pixel->set(color.HSV(h*p, s*p, v*p),nPixels); // sets all nPixels to the same HSV color
return(true);
homeSpan.begin(Category::Lighting,"Pixel LEDS" DEVICE_SUFFIX);
SPAN_ACCESSORY(); // create Bridge (note this sketch uses the SPAN_ACCESSORY() macro, introduced in v1.5.1 --- see the HomeSpan API Reference for details on this convenience macro)
SPAN_ACCESSORY("Neo RGB");
new NeoPixel_RGB(NEOPIXEL_RGB_PIN,8); // create 8-LED NeoPixel RGB Strand with full color control
homeSpan.poll();
Thank you and best regards
