toying around with this idea..
https://forum.arduino.cc/t/esp32-xqueue-how-to-copy-struct-memory-efficiently/1393342
#define BLOCK_SIZE 512
#define SD_QUEUE_SIZE 16 // maybe only 8
typedef struct {
uint8_t command;
uint16_t len;
uint8_t* block;
} SdBlock;
QueueHandle_t SdQ;
uint8_t SomeData[100];
SdQ = xQueueCreate(SD_QUEUE_SIZE, sizeof(SdBlock));
if ( SdQ != NULL )
xTaskCreate( vSdTask, "SD", 1000, NULL, 2, NULL );
/* The queue could not be created. */
Serial.println("queue create failed..");
Serial.println("Ready..");
if (Serial.available()) {
switch (Serial.read()) {
case '0': OpenFile("file.txt"); break;
case '1': CloseFile(); break;
case '2': WriteBlock((uint8_t*)&SomeData, sizeof(SomeData)); break;
yield();
static void vSdTask( void *pvParameters )
char CurrFileName[14];
SdBlock RecBlock;
BaseType_t xStatus;
const TickType_t xTicksToWait = pdMS_TO_TICKS( 100 );
for ( ;; )
xStatus = xQueueReceive( SdQ, &RecBlock, xTicksToWait );
if ( xStatus == pdPASS )
switch (RecBlock.command) {
case 0: //open file
if (RecBlock.len < 14) {
strcpy(CurrFileName, (char*)RecBlock.block);
Serial.print("Opening File:"); Serial.println(CurrFileName);
break;
case 1: //close file
Serial.println("Closing File"); Serial.println(CurrFileName);
break;
case 2: //write block
Serial.print("Writing block size:");
Serial.println(RecBlock.len);
break;
if (RecBlock.len > 0) {
free(RecBlock.block);
RecBlock.len = 0;
vTaskDelay(1);
yield();
bool OpenFile(char* filename) {
BaseType_t qStatus;
SdBlock qBlock;
bool ret = true;
if (strlen(filename) > 0) {
qBlock.block = (uint8_t*)malloc(strlen(filename) + 1);
strcpy((char*)qBlock.block, filename);
qBlock.command = 0;
qBlock.len = strlen(filename);
qStatus = xQueueSend(SdQ, &qBlock, xTicksToWait);
if (qStatus != pdPASS) {
Serial.println("OF:Send to Q failed..");
free(qBlock.block);
ret = false;
} else ret = false;
return ret;
bool CloseFile() {
BaseType_t qStatus;
SdBlock qBlock;
bool ret = true;
qBlock.command = 1;
qBlock.len = 0;
Serial.println("CF:Send to Q failed..");
ret = false;
return ret;
bool WriteBlock(uint8_t* buf, uint16_t len) {
BaseType_t qStatus;
SdBlock qBlock;
bool ret = true;
if (len > 0) {
qBlock.block = (uint8_t*)malloc(len);
memcpy (qBlock.block, buf, len);
qBlock.len = len;
qBlock.command = 2;
Serial.println("WB:Send to Q failed..");
if (len > 0) free(qBlock.block);
ret = false;
return ret;
fun stuff.. ~q
