ESP32C3 Super Mini Wifi Error
// Load Wi-Fi library
#include <WiFi.h>
// Replace with your network credentials
const char* ssid = "";
const char
password = "
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
// Auxiliary variables to store the current output state
String output12State = "off";
String output14State = "off";
// Assign output variables to GPIO pins
const int output12 = 12;
const int output14 = 14;
// Current time
unsigned long currentTime = millis();
// Previous time
unsigned long previousTime = 0;
// Define timeout time in milliseconds (example: 2000ms = 2s)
const long timeoutTime = 2000;
// Initialize the output variables as outputs
pinMode(output12, OUTPUT);
pinMode(output14, OUTPUT);
// Set outputs to LOW
digitalWrite(output12, LOW);
digitalWrite(output14, LOW);
// Connect to Wi-Fi network with SSID and password
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
// Print local IP address and start web server
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
server.begin();
void loop(){
WiFiClient client = server.available(); // Listen for incoming clients
if (client) { // If a new client connects,
previousTime = currentTime;
Serial.println("New Client."); // print a message out in the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected() && currentTime - previousTime <= timeoutTime) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
header += c;
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println("Connection: close");
client.println();
// turns the GPIOs on and off
if (header.indexOf("GET /12/on") >= 0) {
Serial.println("GPIO 12 on");
output12State = "on";
digitalWrite(output12, HIGH);
} else if (header.indexOf("GET /12/off") >= 0) {
Serial.println("GPIO 12 off");
} else if (header.indexOf("GET /14/on") >= 0) {
Serial.println("GPIO 14 on");
output14State = "on";
digitalWrite(output14, HIGH);
} else if (header.indexOf("GET /14/off") >= 0) {
Serial.println("GPIO 14 off");
// Display the HTML web page
client.println("");
client.println("<meta name="viewport" content="width=device-width, initial-scale=1">");
client.println("<link rel="icon" href="data:,">");
// CSS to style the on/off buttons
// Feel free to change the background-color and font-size attributes to fit your preferences
client.println("html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
client.println(".button { background-color: #4CAF50; border: none; color: white; padding: 16px 40px;");
client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
client.println(".button2 {background-color: #555555;}");
// Web Page Heading
client.println("
ESP32 Web Server
// Display current state, and ON/OFF buttons for GPIO 12
client.println("
GPIO 12 - State " + output12State + "
// If the output12State is off, it displays the ON button
if (output12State=="off") {
client.println("
<a href="/12/on"><button class="button">ON
client.println("
<a href="/12/off"><button class="button button2">OFF
// Display current state, and ON/OFF buttons for GPIO 14
client.println("
GPIO 14 - State " + output14State + "
// If the output14State is off, it displays the ON button
if (output14State=="off") {
client.println("
<a href="/14/on"><button class="button">ON
client.println("
<a href="/14/off"><button class="button button2">OFF
client.println("");
// The HTTP response ends with another blank line
client.println();
// Break out of the while loop
} else { // if you got a newline, then clear currentLine
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("Client disconnected.");
Serial.println("");
IM taking some error messages.My card is esp32c3 super mini
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Please post your full sketch, using code tags when you do
Posting your code using code tags prevents parts of it being interpreted as HTML coding and makes it easier to copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
It is also helpful to post error messages in code tags as it makes it easier to scroll through them and copy them for examination
