Esp32cam always send photos to google drive
i want to make a security system using esp32cam with PIR sensor input
how the system work, When the PIR sensor detects motion, the esp32cam will give an output a photo and send the capture to Google Drive.
so, my problem is esp32cam always send capture to google drive even though the PIR sensor doesn't detect motion, the esp32cam still sends the capture to google drive
i want to esp32cam can to send capture only when motion is detected and not send capture to google drive when PIR sensor not detected a motion
how to solving this system?.......
this is the program code that i use
// Enter your WiFi ssid and password
const char* ssid     = "RidwanSoleh";   //your network SSID
const char* password = "ridwananaksoleh";   //your network password
int PIR = 2;
int pirState = LOW;
String myScript = "/macros/s/AKfycbyo1PHWBjoJ9nFj9GSqziQS1v93v3DloEwwOsYQlAeosZneFQyy/exec";    //Create your Google Apps Script and replace the "myScript" path.
String myLineNotifyToken = "myToken=**********";    //Line Notify Token. You can set the value of xxxxxxxxxx empty if you don't want to send picture to Linenotify.
String myFoldername = "&myFoldername=ESP32-CAM";
String myFilename = "&myFilename=ESP32-CAM.jpg";
String myImage = "&myFile=";
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include "Base64.h"
#include "esp_camera.h"
// WARNING!!! Make sure that you have either selected ESP32 Wrover Module,
//            or another board which has PSRAM enabled
//CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
  pinMode(PIR, INPUT);
  delay(10);
  WiFi.mode(WIFI_STA);
  Serial.println("");
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  long int StartTime=millis();
  while (WiFi.status() != WL_CONNECTED)
    if ((StartTime+10000) < millis()) break;
  Serial.println("");
  Serial.println("STAIP address: ");
  Serial.println("");
  if (WiFi.status() != WL_CONNECTED) {
    Serial.println("Reset");
    ledcAttachPin(4, 3);
    ledcSetup(3, 5000, 8);
    ledcWrite(3,10);
    delay(200);
    ledcWrite(3,0);
    delay(200);
    ledcDetachPin(3);
    ESP.restart();
  else {
    for (int i=0;i<5;i++) {
      ledcWrite(3,10);
      delay(200);
      ledcWrite(3,0);
      delay(200);
    ledcDetachPin(3);
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  //init with high specs to pre-allocate larger buffers
  if(psramFound()){
    config.frame_size = FRAMESIZE_UXGA;
    config.jpeg_quality = 10;  //0-63 lower number means higher quality
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 12;  //0-63 lower number means higher quality
    config.fb_count = 1;
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    ESP.restart();
  //drop down frame size for higher initial frame rate
  sensor_t * s = esp_camera_sensor_get();
  s->set_framesize(s, FRAMESIZE_VGA);  // UXGA|SXGA|XGA|SVGA|VGA|CIF|QVGA|HQVGA|QQVGA
  pirState = digitalRead(PIR);
  if (pirState == HIGH){
    Serial.println("motion Detected");
    SendCapturedImage();
String SendCapturedImage() {
  const char* myDomain = "script.google.com";
  String getAll="", getBody = "";
  camera_fb_t * fb = NULL;
  fb = esp_camera_fb_get();
  if(!fb) {
    Serial.println("Camera capture failed");
    ESP.restart();
    return "Camera capture failed";
  Serial.println("Connect to " + String(myDomain));
  WiFiClientSecure client_tcp;
  client_tcp.setInsecure();   //run version 1.0.5 or above
  if (client_tcp.connect(myDomain, 443)) {
    Serial.println("Connection successful");
    char *input = (char *)fb->buf;
    char output[base64_enc_len(3)];
    String imageFile = "data:image/jpeg;base64,";
    for (int i=0;i<fb->len;i++) {
      base64_encode(output, (input++), 3);
      if (i%3==0) imageFile += urlencode(String(output));
    String Data = myLineNotifyToken+myFoldername+myFilename+myImage;
    client_tcp.println("POST " + myScript + " HTTP/1.1");
    client_tcp.println("Host: " + String(myDomain));
    client_tcp.println("Content-Length: " + String(Data.length()+imageFile.length()));
    client_tcp.println("Content-Type: application/x-www-form-urlencoded");
    client_tcp.println("Connection: keep-alive");
    client_tcp.println();
    client_tcp.print(Data);
    int Index;
    for (Index = 0; Index < imageFile.length(); Index = Index+1000) {
      client_tcp.print(imageFile.substring(Index, Index+1000));
    esp_camera_fb_return(fb);
    int waitTime = 10000;   // timeout 10 seconds
    long startTime = millis();
    boolean state = false;
    while ((startTime + waitTime) > millis())
      Serial.print(".");
      delay(100);
      while (client_tcp.available())
          char c = client_tcp.read();
          if (state==true) getBody += String(c);
          if (c == '\n')
            if (getAll.length()==0) state=true;
            getAll = "";
          else if (c != '\r')
            getAll += String(c);
       if (getBody.length()>0) break;
    client_tcp.stop();
    Serial.println(getBody);
  else {
    getBody="Connected to " + String(myDomain) + " failed.";
    Serial.println("Connected to " + String(myDomain) + " failed.");
  return getBody;
String urlencode(String str)
    String encodedString="";
    char c;
    char code0;
    char code1;
    char code2;
    for (int i =0; i < str.length(); i++){
      c=str.charAt(i);
      if (c == ' '){
        encodedString+= '+';
      } else if (isalnum(c)){
        encodedString+=c;
      } else{
        code1=(c & 0xf)+'0';
        if ((c & 0xf) >9){
            code1=(c & 0xf) - 10 + 'A';
        c=(c>>4)&0xf;
        code0=c+'0';
        if (c > 9){
            code0=c - 10 + 'A';
        code2='\0';
        encodedString+='%';
        encodedString+=code0;
        encodedString+=code1;
        //encodedString+=code2;
      yield();
    return encodedString;
Does the PIR go low?
Serial.print( "Does it go low " );
Serial.print( pirState );
