Setting up a ESP32Cam in https mode keep getting stuck on it's final step. In http mode all is working as it should. When building the https sketch (below) i am not getting the needed return messages: 'Connection opened' and 'Websocket Connected'
Testing it on a mac, having installed openssl, nodejs, npm correctly, getting everything running without errors. Connecting a CP2102 to the ESP32Cam. What am i missing?
#include "esp_camera.h"
#include <WiFi.h>
#include <ArduinoWebsockets.h>
#define CAMERA_MODEL_AI_THINKER
#include "camera_pins.h"
const char* ssid = "homey";
const char* password = "1234";
const char* websocket_server_host = "wss://192.168.2.3";
const uint16_t websocket_server_port = 433;
using namespace websockets;
WebsocketsClient client;
bool isWebSocketConnected;
void onEventsCallback(WebsocketsEvent event, String data){
if(event == WebsocketsEvent::ConnectionOpened){
Serial.println("Connection Opened");
isWebSocketConnected = true;
}else if(event == WebsocketsEvent::ConnectionClosed){
Serial.println("Connection Closed");
isWebSocketConnected = false;
webSocketConnect();
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 10000000;
config.pixel_format = PIXFORMAT_JPEG;
config.frame_size = FRAMESIZE_VGA;
config.jpeg_quality = 40;
config.fb_count = 2;
// camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
client.onEvent(onEventsCallback);
webSocketConnect();
void webSocketConnect(){
while(!client.connect(websocket_server_host)){
Serial.print(".");
Serial.println("Websocket Connected!");
if(client.available()){
client.poll();
if(!isWebSocketConnected) return;
camera_fb_t *fb = esp_camera_fb_get();
if(!fb){
Serial.println("Camera capture failed");
esp_camera_fb_return(fb);
return;
if(fb->format != PIXFORMAT_JPEG){
Serial.println("Non-JPEG data not implemented");
return;
fb->buf[12] = 0x01; //FIRST CAM
// fb->buf[12] = 0x02; //SECOND CAM
// fb->buf[12] = 0x03; //3th CAM
client.sendBinary((const char*) fb->buf, fb->len);
@bananaboat , your topic has been moved to a section of the forum where it hopefully get a better exposure.
Are you receiving any events? I recommend you log any unhandled events.
Shouldn't you set 'isWebSocketConnected' to 'true' in here somewhere?
It says in the 4th block
I have been testing this throughout and it seems to be a ws / wss protocol issue.
Testing the none https version WITHOUT ws worked! WITH the ws protocol on the other hand did not.
The none https version code:
#include <WiFi.h>
//part8
const char* ssid = "hello";
// const char* websocket_server_host = "ws://192.168.2.3"; // does NOT get WebSocket connection
const char* websocket_server_host = "192.168.2.3"; // DOES get websocket connection!
const uint16_t websocket_server_port = 8888;
webSocketConnect();
// camera init
return;
Serial.print(".");
Serial.println("");
webSocketConnect();
while(!client.connect(websocket_server_host, websocket_server_port, "/")){
Serial.print(".");
client.poll();
if(!fb){
return;
return;
Other failed tests with https are:
const uint16_t websocket_server_port = 443;
while(!client.connect(websocket_server_host, websocket_server_port, "")){
const char* websocket_server_host = "192.168.2.3:443";
// const uint16_t websocket_server_port = 443;
const char* websocket_server_host = "https://192.168.2.3";
system
Closed
September 11, 2021, 10:15am
#6
