Hi, i'm trying to use this code, but the logs show me : failed capture.
To see if the camera works i ran the example -> esp32 camera -> webserver and it works perfectly. So i'm not sure why it doesn't work in this one.
Does anyone know why?
ESP32-CAM Directional Motion Detection (https://www.youtube.com/watch?v=NIbiG6at01g)
Learn more on Makers Mashup - https://youtube.com/MakersMashup
Licensed under the Attribution-ShareAlike 4.0 International (CC BY-SA 4.0)
http://creativecommons.org/licenses/by-sa/4.0/
PLEASE NOTE YOU WILL NEED TO ADD THE TaskSchedule and TinySTepper libarires to
run this code unaltered. Use TOOLS->Manage Libraries in the arduino IDE.
Also use the board manager and make sure you select ESP32 as an available
board. The one I used specifically was https://amzn.to/3m2dJrl
#include <TaskScheduler.h>
#include <TinyStepper_28BYJ_48.h>
#define CAMERA_MODEL_AI_THINKER // look in camera_pins.h to find the camera type you have
#include "camera_pins.h" // Must include this after setting
#include "esp_camera.h"
#include "FS.h" // SD Card ESP32
#include "SD_MMC.h" // SD Card ESP32
#define FRAME_SIZE FRAMESIZE_QVGA // Frambuffer size (matches resolution below)
#define WIDTH 320 // Resolution Width
#define HEIGHT 240 // Resolution height
#define BLOCK_SIZE 4 // Size of each sensor block on the display (reduced granularity for speed)
#define W (WIDTH / BLOCK_SIZE)
#define H (HEIGHT / BLOCK_SIZE)
#define BLOCK_DIFF_THRESHOLD 1.5
#define IMAGE_DIFF_THRESHOLD 0.1
#define DEBUG 0 // Good for making changes
#define INFO 1 // Good to see whats happening (turn off to save CPU)
#define VIEWPORT_PIXELS WIDTH/BLOCK_SIZE // 320/4 = 80 Positions to look at in left to right view plane [-------X------] X is where motion exists
#define STEPS_PER_DEGREE 6 // How many degrees per block to turn 11.37
#define STEPS_PER_SECOND 4096 // How fast the stepper turns
#define ACCELLERATION_STEPS_PER_SECOND 256 // How quickly the movement accellerates
#define FLASH_PIN 4 // Pin of ESP32 Flash (Led)
#define FLASH_MODE 0 // 0 = 0ff , 1 = flash, 2 = steady
uint16_t prev_frame[H][W] = { 0 };
uint16_t current_frame[H][W] = { 0 };
uint16_t empty_frame[H][W] = { 0 };
long motionView[VIEWPORT_PIXELS];
// stepper
const uint8_t MOTOR_IN1_PIN = 12;
const uint8_t MOTOR_IN2_PIN = 13;
const uint8_t MOTOR_IN3_PIN = 14;
const uint8_t MOTOR_IN4_PIN = 15;
int moveTo=0;
int currentPos=0;
TinyStepper_28BYJ_48 stepper;
// Scheduler
Scheduler tasks;
void moveSteppers();
Task tmvStepper (250, TASK_FOREVER, &moveSteppers, &tasks, true );
// === 1 =======================================
void moveSteppers() {
// Stepper Movement - Move by steps so we capture more motion frames.
if(currentPos>moveTo){
currentPos-=ceil((currentPos-moveTo)/2);
if(ceil((currentPos-moveTo)/2)==0) currentPos=moveTo;
}else if(currentPos<moveTo){
currentPos+=floor((moveTo-currentPos)/2);
if(floor((moveTo-currentPos)/2)==0) currentPos=moveTo;
}else {
currentPos=moveTo;
#if INFO
if(currentPos!=moveTo){
Serial.print("MOVETO: ");
Serial.print(moveTo);
Serial.print(" CURRENT: ");
Serial.println(currentPos);
#endif
stepper.moveToPositionInSteps(currentPos);
long viewPortToRegion(long mv[]){
int maxVal=0;
int region=0;
int tmpVal=0;
char str_tmp[9];
// Fill each char arry with the 8 bits of the 10 regions
for(int i=0;i<10;i++){
for(int j=0;j<8;j++){
str_tmp[j]=(mv[((i*8)+j)]==1) ? '1' : '0';
// Serial.println(((i*8)+j));
#if INFO
Serial.print("Block: ");
Serial.print(i);
Serial.print(" STR=");
Serial.print(str_tmp);
Serial.print(" Value: ");
tmpVal=readBinaryString(str_tmp);
Serial.println(tmpVal);
#endif
if(tmpVal>maxVal){
maxVal<=tmpVal; // Set new uppper mark
region=i; // Which viewport has the most movement.
Serial.print("Most activity in block region:");
Serial.println(region);
return region;
uint32_t Freq = 0;
Freq = getCpuFrequencyMhz();
Serial.print("CPU Freq = ");
Serial.print(Freq);
Serial.println(" MHz");
Freq = getXtalFrequencyMhz();
Serial.print("XTAL Freq = ");
Serial.print(Freq);
Freq = getApbFrequency();
Serial.print("APB Freq = ");
Serial.print(Freq);
Serial.println(" Hz");
Serial.println("Begin Setup...");
for(uint16_t i=0;i<VIEWPORT_PIXELS;i++){
motionView[i]=0; // Setup Pixel Array
pinMode (FLASH_PIN, OUTPUT);
// Serial.println(setup_camera(FRAME_SIZE, PIXFORMAT_JPEG) ? "OK" : "ERR INIT");
Serial.println(setup_camera(FRAME_SIZE,PIXFORMAT_GRAYSCALE) ? "OK" : "ERR INIT");
stepper.connectToPins(MOTOR_IN1_PIN, MOTOR_IN2_PIN, MOTOR_IN3_PIN, MOTOR_IN4_PIN);
stepper.setSpeedInStepsPerSecond(STEPS_PER_SECOND);
stepper.setAccelerationInStepsPerSecondPerSecond(ACCELLERATION_STEPS_PER_SECOND);
// on startup move the full field of view.
stepper.moveToPositionInSteps(0);
stepper.moveToPositionInSteps(STEPS_PER_DEGREE*10);
Serial.println("End Setup...");
tasks.startNow();
if(FLASH_MODE==2)
digitalWrite(FLASH_PIN, HIGH);
if (!capture_still()) {
#if INFO
Serial.println("Failed capture");
#endif
return;
if (motion_detect()) {
#if INFO
Serial.println("Motion detected");
#endif
update_frame();
tasks.execute();
* Capture image and do down-sampling
bool capture_still() {
if(FLASH_MODE==1)
camera_fb_t *frame_buffer = esp_camera_fb_get();
if(FLASH_MODE==1)
digitalWrite(FLASH_PIN, LOW);
if (!frame_buffer)
return false;
// set all 0s in current frame
memcpy( empty_frame, current_frame, sizeof(empty_frame)); // FAST! Memcopy vs iterations so much faster.
// down-sample image in blocks
for (uint32_t i = 0; i < WIDTH * HEIGHT; i++) {
const uint16_t x = i % WIDTH;
const uint16_t y = floor(i / WIDTH);
const uint8_t block_x = floor(x / BLOCK_SIZE);
const uint8_t block_y = floor(y / BLOCK_SIZE);
const uint8_t pixel = frame_buffer->buf[i];
const uint16_t current = current_frame[block_y][block_x];
// average pixels in block (accumulate)
current_frame[block_y][block_x] += pixel;
// average pixels in block (rescale)
for (int y = 0; y < H; y++)
for (int x = 0; x < W; x++)
current_frame[y][x] /= BLOCK_SIZE * BLOCK_SIZE;
#if DEBUG
Serial.println("Current frame:");
print_frame(current_frame);
Serial.println("---------------");
#endif
return true;
* Compute the number of different blocks
* If there are enough, then motion happened
bool motion_detect() {
uint16_t changes = 0;
int lastBlock=0;
const uint16_t blocks = (WIDTH * HEIGHT) / (BLOCK_SIZE * BLOCK_SIZE);
for (uint16_t y = 0; y < H; y++) {
for (uint16_t x = 0; x < W; x++) {
float current = current_frame[y][x];
float prev = prev_frame[y][x];
float delta = abs(current - prev) / prev;
// Fill only those areas that meet the threashold.
if (delta >= BLOCK_DIFF_THRESHOLD) {
#if DEBUG
Serial.println(delta);
Serial.print("diff\t");
Serial.print(y);
Serial.print('\t');
Serial.println(x);
#endif
motionView[x]=1;
changes++;
if(changes==0) return false; // don't need to go any further
// Change screen data into linear (left to right) expression of data.
moveTo=((10-viewPortToRegion(motionView))*10)*STEPS_PER_DEGREE;
// Display updates for informational purposes.
#if INFO
Serial.print(":::");
#endif
// Clear viewport to zero for next detection phase
#if INFO
Serial.print(motionView[i]);
#endif
motionView[i]=0;
#if INFO
Serial.println(":::");
Serial.print("Changed ");
Serial.print(changes);
Serial.print(" out of ");
Serial.println(blocks);
Serial.print("MoveTo:");
Serial.println(moveTo);
#endif
return (1.0 * changes / blocks) > IMAGE_DIFF_THRESHOLD;
* Copy current frame to previous
void update_frame() {
memcpy( prev_frame, current_frame, sizeof(prev_frame)); // FAST! Memcopy vs iterations so much faster.
* For serial debugging
* @param frame
void print_frame(uint16_t frame[H][W]) {
for (int y = 0; y < H; y++) {
for (int x = 0; x < W; x++) {
Serial.print(frame[y][x]);
Serial.print('\t');
* Camera configuration values
bool setup_camera(framesize_t frameSize,pixformat_t PIXEL_FORMAT) {
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXEL_FORMAT;
config.frame_size = frameSize;
config.jpeg_quality = 12;
config.fb_count = 1;
esp_camera_deinit();
bool ok = esp_camera_init(&config) == ESP_OK;
sensor_t *sensor = esp_camera_sensor_get();
sensor->set_framesize(sensor, frameSize);
return ok;
int readBinaryString(char *s) {
int result = 0;
while(*s) {
result <<= 1;
if(*s++ == '1') result |= 1;
return result;
void captureSnapshotToSD(){
