Esp32d wroon problem to make my car move all direction
here is my wiring
then my code where i cant get the best result i need the car to go all directions with both motors on i calculated the wheels for more effective turns but dont see where iam wrong using pWM channels
could someone help please
#include <BluetoothSerial.h>
BluetoothSerial btSerial;
#define BT_NAME " vision" // Set bluetooth name
const int pinEnA = 2;
const int pinIn1 = 0;
const int pinIn2 = 4;
const int pinEnB = 18;
const int pinIn3 = 22;
const int pinIn4 = 23;
#define MAX_motorforward 1
#define MAX_motorlateral 3.14
#define PWM_FREQUENCY   1000
#define PWM_RESOLUTION  8
#define PWM_CHANNEL 0
boolean btConnected = false;
char key, previousKey;
float motorforward, motorlateral;
long previousMillis = 0;
int timeout = 1000;
  pinMode(pinEnA,OUTPUT);
  pinMode(pinEnB,OUTPUT);
  pinMode(pinIn1,OUTPUT);
  pinMode(pinIn2,OUTPUT);
  pinMode(pinIn3,OUTPUT);
  pinMode(pinIn4,OUTPUT);
   digitalWrite(pinEnA,HIGH);
  digitalWrite(pinEnB,HIGH);
  //Parar motor Esquerda;
  digitalWrite(pinIn1,HIGH);
  digitalWrite(pinIn2,HIGH);
  //Parar motor Direita;
  digitalWrite(pinIn3,HIGH);
  digitalWrite(pinIn4,HIGH);
 ledcSetup(PWM_CHANNEL, PWM_FREQUENCY, PWM_RESOLUTION);
  ledcAttachPin(pinEnA,PWM_CHANNEL);
  ledcAttachPin(pinEnB, PWM_CHANNEL);
  btSerial.begin(BT_NAME);
  Serial.println("ESP32 Bluetooth Mobile Robot");
 control();
  delay(300);
// Move the DC motor forward at maximum speed
  Serial.println("Moving forward");
  digitalWrite(pinIn1, HIGH);
  digitalWrite(pinIn2, LOW);
  digitalWrite(pinIn3, HIGH);
  digitalWrite(pinIn4, LOW);
  delay(2000);
  // Stop the DC motor
  Serial.println("Motor stopped");
  digitalWrite(pinIn1, LOW);
  digitalWrite(pinIn3, LOW);
  // Move the DC motor right at maximum speed
  Serial.println("Moving right");
  digitalWrite(pinIn2, HIGH);
  delay(2000);
   // Move the DC motor left at maximum speed
  Serial.println("Moving left");
  digitalWrite(pinIn4, HIGH);
  delay(2000);
   // Move the DC motor backwards at maximum speed
  Serial.println("Moving backwards");
  delay(2000);
  delay(2000);
  // Move DC motor forward with increasing speed
if (btSerial.available()) {
    previousMillis = millis();
    char inChar = (char)btSerial.read();
    if (btConnected == false) {
      btConnected = true;
    //  digitalWrite(BUILTIN_LED, LOW); // Turn on led
      Serial.println("Bluetooth connected.");
 if (inChar >= '0' && inChar <= '9') {
      key = inChar;
      if (key != previousKey) {
        switch (key) {
          case '0':
            Serial.println("Robot stop.");
           motorforward =0;
             motorlateral =0;
          case '1':
            Serial.println("Robot move forward.");
             motorforward = 0.1;
             motorlateral = 0;
          case '2':
            Serial.println("Robot move backward.");
          motorforward = -0.1;
             motorlateral = 0;
          case '3':
            Serial.println("Robot turn left.");
            motorforward = 0.1;
             motorlateral = 0.314;
          case '4':
            Serial.println("Robot turn right.");
           motorforward = 0.1;
             motorlateral =-0.314;
         motorforward = constrain(  motorforward, -MAX_motorforward,MAX_motorforward);
        motorlateral = constrain( motorlateral, -MAX_motorlateral, MAX_motorlateral);
   control(  motorforward,motorlateral);
        previousKey = key;
if (millis() - previousMillis > timeout &&
      btConnected == true) {
    Serial.println("Bluetooth disconnected.");
  control(0,0);
   // digitalWrite(BUILTIN_LED, HIGH); // Turn off led
void control(float forward, float lateral ){
  float  wheelL, wheelR, l = 0.13, r = 0.03;
  wheelR = ((forward / r) + (lateral * l) / (2 * r)) * 60;
  wheelL = ((forward / r) - (lateral * l) / (2 * r)) * 60;
  Serial.print("Roda Direita:");
  Serial.println(wheelR);
  Serial.print("Roda Esquerda:");
  Serial.println(wheelL);
 wheelR =constrain( wheelR, -255,255);
 wheelL =constrain(  wheelL , -255,255);
  if (wheelR >= 0) {
 //float speedR = map(wheelR, 0, 255, 255, 0);
     ledcWrite(pinIn1_PWM_CHANNEL, wheelR);
     ledcWrite(pinIn1_PWM_CHANNEL, 0);
  else {
//float speedR = map(wheelR, -255, 0, 0, 255);
  ledcWrite(pinIn1_PWM_CHANNEL, abs(wheelR));
  if (wheelL >= 0) {
    //float speedL = map(wheelL, 0, 255, 255, 0);
    ledcWrite(pinIn1_PWM_CHANNEL, wheelL);
  else {
 //float speedL = map(wheelL, -255, 0, 0, 255);
     ledcWrite(pinIn1_PWM_CHANNEL, abs(wheelL));
You've got the end of a block comment in the middle of setup - does that even compile?
not like that it doesnt but its a small problem it does compile without it
your code does not compile because the function asks for arguments (line 218) and they are not provided in the call (line 70).
here its the improvement i got today i have now got 3 direction but only one does not work
this one now compiles
check please
int timeout = 1000;
      btConnected = true;
      key = inChar;
        switch (key) {
          case '0':
           motorforward =0;
             motorlateral =0;
          case '1':
             motorforward = 0.15;
             motorlateral = 0;
             forward();
          case '2':
            Serial.println("Robot move backwards.");
          motorforward = -0.15;
             motorlateral = 0;
             backwards();
          case '3':
            motorforward = 0;
             motorlateral = 1.5;
             left();
          case '4':
           motorforward = 0;
             motorlateral =-1.5;
             right();
        previousKey = key;
  control(0,0);
void control(float forward,float lateral){
   wheelR = constrain(  wheelR, -255,255);
   wheelL = constrain( wheelL, -255, 255);
   if (wheelR >= 0) {
    ledcWrite(PWM_CHANNEL, wheelR);
  else {
    ledcWrite(PWM_CHANNEL, abs(wheelR));
  if (wheelL >= 0) {
    ledcWrite(PWM_CHANNEL, wheelL);
  else {
    ledcWrite(PWM_CHANNEL, abs(wheelL));
void forward (){
  void right (){
void left (){
void backwards (){
  delay(2000);
now compiled.
Questions:
  1. Is this line printing on the serial monitor? "Serial.println("Bluetooth connected.");
  2. Do any of these lines print something to the serial monitor?
    or
    Serial.println("Robot moves forward.");
    or
    Serial.println("Robot moves backwards.");
    or
    or
  3. Do any of these lines print something to the serial monitor?
    Serial.print("Right Wheel:");
    Serial.print("Left Wheel:");
  4. Does the car move in any direction?
1-yes it does and connects normally
2-yes forward shows the value as well as backwards the rest its just info
3- left wheel and right wheels just info the wheelL and wheelR print the values calculated using the parameter from the switch case to the control() function the switch case
4-car moves 3 directions but doesnt move backwards also the pwm is negative using the function abs should be positive but on thr plotter monitor its shows negative
the l298 buzzes when i press the buttons to control 1 2 3 4 as i have written on the code where the switch case is at but button 2 backwards doesnt work
im also seeing plotter monitor and the pwm is negative there eventhough i got the abs function there
