ESP32E Crashes
I have found a special application for my ESP12E module, an MIT program for an internet clock that is amazing. I would like to try it so that I connect all the wires. I connected my 0.96'' OLED 128x64 display and have modified the Adafruit_SSD1306.h in the proper resolution for my display and, finally, ran the program. I have been enthusiastic because all the setup for the clock is configured from an internet browser. I saw that for the first time... all previous programs demanded to put all this variables into a code. If I want to change my location (WiFi router), I have to reprogram it.
The problem is that I run the code and setup the WIFI, I make all the necessary adjustments that I want for the clock and I see the right time for my location(Country) in the display OLED. That happiness stays only for a few seconds because the ESP12E crashes and goes back to web server for the clock configurations. I push the "RUN" button in the webpage and it shows the time again for 5 seconds, when it crashes again
I post it here to find nice people to help me fix the problem because I love this code.
I have attached a photo of my ESP12E and OLED, and finally a copy of the report of serial port showing the crash. Without your help it would take me weeks of debugging to find the problem and my age let alone my work and family won't let me.
Serial Port Report.txt (3.3 KB)
Why does the Title say ESP32 when the problem seems to be about an ESP12 ?
...R
What does the stack trace tell you?
Without seeing your code, there's not much we can say.
Pieter
Try using using the U8g2lib.h library for the display, Adafruit libraries tend to generate Guru Meditation errors with an ESP32. When you upload the code, set the ESP32 debug level to Debug instead of none. With the ESP32 hooked to the Arduino IDE and serial monitor open you should see the error message. Then you can copy the error message and paste it here so we can see.
Frankly, if the error is a Guru Meditation, use the U8g2lib.h library for the display.
Reading the attached file (no picture BTW), it is an ESP12E, not an ESP32 :
Panic C:\Users\stamy\OneDrive\Documents\ArduinoData\packages*esp8266*\hardware*esp8266*\2.5.2\cores*esp8266*\core_esp8266_main.cpp:103 __yield
The crash cause is given here:
rst cause:2, boot mode:(3,6)
Searching for this text on Google, I found this thread, which provides several explainations for the problem : power issue, bad IDE parameter choice, etc.
Here is a link to a page explaining the reset causes: cause 2 is linked to the reset pin
This link explains the boot modes. In the bootup message 'boot mode:(x,y)' three low bits of x are {MTDO == GPIO15, GPIO0, GPIO2}. x=3 is related to SPI flash boot (if I understand well).
7 SDIO HighSpeed V2 IO Uart1 Booting
6 SDIO LowSpeed V1 IO Uart1 Booting
5 SDIO HighSpeed V1 IO Uart1 Booting
4 SDIO LowSpeed V2 IO Uart1 Booting
3 FLASH BOOT
2 Jump Boot
1 UART Boot
0 Remapping
It seems the 'y' value is not relevant.
So, if you have something connected to either one of these pins (GPIO 0, 2 and 15) this may interact with the flash mode and reboot the ESP.
