Hello all,
recently i am using a S9706 colorsensor with my ESP32S3-DevkitC-1-N8R2.
When i only use one sensor, it's working perfectly. But when i try to read more than one sensor using the same CLK, GATE and RANGE lines for both sensors i get unreasonable data.
I searched on the net for sometime but i couldn't get any infos about this sensor.
So please, if someone has experince with such sensors can tell me if i have a change or should search for other sensors.
Thanks in forward.
awneil
September 25, 2023, 10:07am
2
There's a datasheet here:
It gives a link to the manufacturer's documentation page:
Show how you have them connected.
It doesn't look to me that these are intended for connecting in a "bus" configuration with multiple devices?
It looks like you will, at least , need a separate data line per sensor ?
Thank you for the answer.
I have already a separate data line for each sensor but they still deliver unreasonable data.
awneil
September 25, 2023, 10:21am
4
This is how i have them connected
And here is my code:
#include <S9706.h>
// Defining the pins needed for the color sensor
const int DataPin1 = 21;
const int DataPin2 = 36;
const int RangePin = 38;
const int ClockPin = 39;
const int GatePin = 40;
// Instance for RGB color sensor
S9706 colorsensor1(DataPin1, RangePin, ClockPin, GatePin);
S9706 colorsensor2(DataPin2, RangePin, ClockPin, GatePin);
// Some float variables to store the color infos
uint8_t f_r1, f_g1, f_b1;
uint8_t f_r2, f_g2, f_b2;
colorsensor1.begin();
colorsensor2.begin();
// read the color sensors
colorsensor1.update(S9706_MODE_HIGH, 100);
f_r1 = colorsensor1.getRed();
f_g1 = colorsensor1.getGreen();
f_b1 = colorsensor1.getBlue();
delay(100);
colorsensor2.update(S9706_MODE_HIGH, 100);
f_r2 = colorsensor2.getRed();
f_g2 = colorsensor2.getGreen();
f_b2 = colorsensor2.getBlue();
delay(100);
Serial.print("red1: ");
Serial.print(f_r1);
Serial.print(" green1: ");
Serial.print(f_g1);
Serial.print(" blue1: ");
Serial.println(f_b1);
Serial.print("red2: ");
Serial.print(f_r2);
Serial.print(" green2: ");
Serial.print(f_g2);
Serial.print(" blue2: ");
Serial.println(f_b2);
awneil
September 25, 2023, 11:12am
7
What's the purpose of the optoisolators?
Does it work without them?
Does each sensor individually work via its own isolator, with no other sensors present?
I think the problem is with the optoisolator.
Without the opto it looks like i am getting some good data.
awneil
September 25, 2023, 11:28am
9
What was the intention of opto-isolating just the data lines?
I thought i may isolate the sensors from the microcontroller
