I have a USB FTDI device, how can I use it using the GPIO19 (USB_D-) and GPIO20 (USB_D+) ports which are the USB ports on the ESP32S3 for USBserial/JTAG?
what is the specific USB FTDI device, e.g. a ttl-232r-3v3
also which ESP32-S3 dev kit are you using?
Hy Horace, yes a common FTDI ttl-232 5v i put there um USB-OTG mode, and try CDC mode to, but no success, the model is ESP32-SE-WROOM-1
to clarify - the ESP32-S3-DevKitC-1 has two USB ports
- COM - used to communicate with PC host for programming and Serial Monitor communications
- USB - supports USB OTG host and device
you wish to connect the FTDI TTL-232-5V to the USB port to provide serial communication to an external device
the USB port acts as a OTG host and you will write a USB device driver to drive the FTDI-232-5V
any particular reason to use the FTDI-232-5V for serial communications?
why not use one of the ESP32 hardware serial ports Serial1 or Seial2
e.g. program using Serial1 on pins 16 and 17
// ESP32 Serial1 test - for loopback test connect pins 16 and 17
#define RXD1 16
#define TXD1 17
// initialize both serial ports:
//Serial1.begin(115200, SERIAL_8N1, RXD1, TXD1);
Serial1.begin(38400, SERIAL_8N1, RXD1, TXD1);
Serial.println("\n\nESP32 serial1 test Rx pin 16 Tx pin 17");
Serial.write(" for loopback test connect pin 16 to pin 17\n");
// read from port 1, send to port 0:
if (Serial1.available()) {
int inByte = Serial1.read();
Serial.write(inByte);
// read from port 0, send to port 1:
if (Serial.available()) {
int inByte = Serial.read();
//Serial.write(inByte);
Serial1.write(inByte);
if I connect pins 16 and 17 of the ESP32-S3 it forms a loopback
a test run gives - I entered "test 1234567890" and "test abcdef" on the keyboard and serial monitor displays
test 1234567890
test abcdef
remember the ESP32 uses 3.3V logic - if connectng to a device which uses 5V logic use a potential divider or level converter to convert the 5V levels to 3.3V
Hi Horace, sorry for the delay, my problem is a little more complex than the free choice between ports... following:
I have an ESP32-S3 on a PCB (for specific use), using port 18 (RX), 17 (TX) as indicated in the official pinouts, simply the RX does not return data, at the same time a logic analyzer shows me that between the external device and the SP32-S3 serial are indeed transferring data, but through the ESP32-S3 I cannot read or manipulate the data, I have tried all possible ways. Everything indicates that there is a problem with this external interface.
External interface [TTL] <--> [TTL] ESP32-S3
This interface also has an FTDI USB TTL version, my idea is to test if this way I can solve this problem, through this change of ports,
I bought a market standard ESP32-S3 MCU, everything works normally, reaffirming that my first piece of hardware has indeed some issues.
