ESP32S3-WROOM 1: Configuration issue
Hello,
I'm trying to configure the ESP32S3-WROOM 1 for a robot project that requires the use of a camera sensor.
I'm using ARDUINO UNO on macbook and I'm having lots of difficulties to map the microcontroller properly.
Here are the setting I use on Aruino IDE:
//. Selected Board ---> ESP32S3 Dev Module
// USB CDC On Boot ---> Enabled
// Flash Size ---> 8MB(64Mb)
// Partition Scheme ---> 8M with spiffs (3MB APP/1.5MB SPIFFS)
// PSRAM ---> OPI PSRAM
Driver installed: CH340 Driver for MAC.
When I upload the code, many times it fails with following description:
/Sketch uses 361085 bytes (10%) of program storage space. Maximum is 3342336 bytes.
Global variables use 23108 bytes (7%) of dynamic memory, leaving 304572 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.6
Serial port /dev/cu.usbmodem141101
Connecting...
Chip is ESP32-S3 (revision v0.2)
Features: WiFi, BLE
Crystal is 40MHz
MAC: dc:da:0c:48:69:4c
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
A fatal error occurred: No serial data received.
Failed uploading: uploading error: exit status 2
And I have to perform an hard reset (both boot + reset buttons pressed) and then it uploads the code.
Below the code :
#include "esp_camera.h"
#include "esp_system.h"
// Select camera model
//CAMERA_MODEL_M5STACK_PSRAM
//CAMERA_MODEL_WROVER_KIT
//#define CAMERA_MODEL_ESP_EYE --> WRONG MODEL
//#define CAMERA_MODEL_AI_THINKER
#define CAMERA_MODEL_ESP32S3_EYE
//Configurations
#if defined(CAMERA_MODEL_WROVER_KIT)
#define PWDN_GPIO_NUM  -1
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM  21
#define SIOD_GPIO_NUM  26
#define SIOC_GPIO_NUM  27
#define Y9_GPIO_NUM    35
#define Y8_GPIO_NUM    34
#define Y7_GPIO_NUM    39
#define Y6_GPIO_NUM    36
#define Y5_GPIO_NUM    19
#define Y4_GPIO_NUM    18
#define Y3_GPIO_NUM    5
#define Y2_GPIO_NUM    4
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM  23
#define PCLK_GPIO_NUM  22
#elif defined(CAMERA_MODEL_ESP_EYE)
#define XCLK_GPIO_NUM  4
#define SIOD_GPIO_NUM  18
#define SIOC_GPIO_NUM  23
#define Y9_GPIO_NUM    36
#define Y8_GPIO_NUM    37
#define Y7_GPIO_NUM    38
#define Y6_GPIO_NUM    39
#define Y5_GPIO_NUM    35
#define Y4_GPIO_NUM    14
#define Y3_GPIO_NUM    13
#define Y2_GPIO_NUM    34
#define VSYNC_GPIO_NUM 5
#define HREF_GPIO_NUM  27
#define PCLK_GPIO_NUM  25
#define LED_GPIO_NUM 22
#elif defined(CAMERA_MODEL_M5STACK_PSRAM)
#define RESET_GPIO_NUM 15
#define XCLK_GPIO_NUM  27
#define SIOD_GPIO_NUM  25
#define Y9_GPIO_NUM    19
#define Y8_GPIO_NUM    36
#define Y7_GPIO_NUM    18
#define Y5_GPIO_NUM    5
#define Y4_GPIO_NUM    34
#define Y3_GPIO_NUM    35
#define Y2_GPIO_NUM    32
#define VSYNC_GPIO_NUM 22
#define HREF_GPIO_NUM  26
#define PCLK_GPIO_NUM  21
#elif defined(CAMERA_MODEL_M5STACK_V2_PSRAM)
#define SIOD_GPIO_NUM  22
#elif defined(CAMERA_MODEL_M5STACK_WIDE)
#elif defined(CAMERA_MODEL_M5STACK_ESP32CAM)
#define Y2_GPIO_NUM    17
#elif defined(CAMERA_MODEL_M5STACK_UNITCAM)
#elif defined(CAMERA_MODEL_M5STACK_CAMS3_UNIT)
#define RESET_GPIO_NUM 21
#define XCLK_GPIO_NUM  11
#define SIOD_GPIO_NUM  17
#define SIOC_GPIO_NUM  41
#define Y9_GPIO_NUM    13
#define Y8_GPIO_NUM    4
#define Y7_GPIO_NUM    10
#define Y6_GPIO_NUM    5
#define Y5_GPIO_NUM    7
#define Y4_GPIO_NUM    16
#define Y3_GPIO_NUM    15
#define Y2_GPIO_NUM    6
#define VSYNC_GPIO_NUM 42
#define HREF_GPIO_NUM  18
#define PCLK_GPIO_NUM  12
#define LED_GPIO_NUM 14
#elif defined(CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM  32
#define XCLK_GPIO_NUM  0
#define Y5_GPIO_NUM    21
#define Y4_GPIO_NUM    19
#define Y3_GPIO_NUM    18
#define Y2_GPIO_NUM    5
#define LED_GPIO_NUM   4
#elif defined(CAMERA_MODEL_TTGO_T_JOURNAL)
#define PWDN_GPIO_NUM  0
#elif defined(CAMERA_MODEL_XIAO_ESP32S3)
#define XCLK_GPIO_NUM  10
#define SIOD_GPIO_NUM  40
#define SIOC_GPIO_NUM  39
#define Y9_GPIO_NUM    48
#define Y8_GPIO_NUM    11
#define Y7_GPIO_NUM    12
#define Y6_GPIO_NUM    14
#define Y5_GPIO_NUM    16
#define Y3_GPIO_NUM    17
#define Y2_GPIO_NUM    15
#define VSYNC_GPIO_NUM 38
#define HREF_GPIO_NUM  47
#define PCLK_GPIO_NUM  13
#elif defined(CAMERA_MODEL_ESP32_CAM_BOARD)
#define USE_BOARD_HEADER 0
#define RESET_GPIO_NUM   33
#define Y8_GPIO_NUM 19
#define Y7_GPIO_NUM 21
#if USE_BOARD_HEADER
#define Y5_GPIO_NUM 13
#else
#endif
#else
#endif
#elif defined(CAMERA_MODEL_ESP32S3_CAM_LCD)
#define XCLK_GPIO_NUM  40
#define SIOC_GPIO_NUM  18
#define Y9_GPIO_NUM    39
#define Y8_GPIO_NUM    41
#define Y7_GPIO_NUM    42
#define Y6_GPIO_NUM    12
#define Y3_GPIO_NUM    47
#define Y2_GPIO_NUM    13
#define VSYNC_GPIO_NUM 21
#define HREF_GPIO_NUM  38
#define PCLK_GPIO_NUM  11
#elif defined(CAMERA_MODEL_ESP32S2_CAM_BOARD)
#define PWDN_GPIO_NUM    1
#define XCLK_GPIO_NUM    42
#define SIOD_GPIO_NUM    41
#define Y9_GPIO_NUM 16
#define Y8_GPIO_NUM 39
#define Y7_GPIO_NUM 40
#define Y6_GPIO_NUM 15
#define Y5_GPIO_NUM 12
#else
#endif
#define Y4_GPIO_NUM 5
#else
#define Y3_GPIO_NUM 12
#endif
#define Y2_GPIO_NUM    14
#define PCLK_GPIO_NUM  3
/*#elif defined(CAMERA_MODEL_ESP32S3_EYE)
#define XCLK_GPIO_NUM  15
#define SIOC_GPIO_NUM  5
#define Y2_GPIO_NUM 11
#define Y3_GPIO_NUM 9
#define Y4_GPIO_NUM 8
#define Y5_GPIO_NUM 10
#define Y8_GPIO_NUM 17
#define VSYNC_GPIO_NUM 6
#define HREF_GPIO_NUM  7
#define PCLK_GPIO_NUM  13*/
#define XCLK_GPIO_NUM    39
#define SIOD_GPIO_NUM    21
#define SIOC_GPIO_NUM    46
#define Y9_GPIO_NUM      40
#define Y8_GPIO_NUM      38
#define Y7_GPIO_NUM      37
#define Y6_GPIO_NUM      35
#define Y5_GPIO_NUM      33
#define Y4_GPIO_NUM      48
#define HREF_GPIO_NUM    41
#define PCLK_GPIO_NUM    36
#elif defined(CAMERA_MODEL_DFRobot_FireBeetle2_ESP32S3) || defined(CAMERA_MODEL_DFRobot_Romeo_ESP32S3)
#define XCLK_GPIO_NUM  45
#define Y8_GPIO_NUM    46
#define Y7_GPIO_NUM    8
#define Y6_GPIO_NUM    7
#define Y5_GPIO_NUM    4
#define Y4_GPIO_NUM    41
#define Y3_GPIO_NUM    40
#define Y2_GPIO_NUM    39
#define HREF_GPIO_NUM  42
#define PCLK_GPIO_NUM  5
#else
#error "Camera model not selected"
#endif
  // Set logging level to verbose for detailed debugging information
    esp_log_level_set("*", ESP_LOG_VERBOSE);
  camera_config_t config;
  // Camera pin configuration for ESP32-S3
    config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sccb_sda = SIOD_GPIO_NUM;
  config.pin_sccb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.frame_size = FRAMESIZE_UXGA;
  config.pixel_format = PIXFORMAT_JPEG;
  config.pixel_format = PIXFORMAT_RGB565;
  config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
  config.fb_location = CAMERA_FB_IN_PSRAM;
  config.jpeg_quality = 12;
  config.fb_count = 1;
  // Initialize the camera
  if (esp_camera_init(&config) != ESP_OK) {
    Serial.println("Camera init failed");
    return;
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
  Serial.print("Camera init failed with error 0x");
  Serial.println(err, HEX);
  return;
  Serial.println("Camera initialized");
  sensor_t * s = esp_camera_sensor_get();
  Serial.print("Camera model PID: ");
  Serial.println(s->id.PID, HEX);
My camera model shoul be #define CAMERA_MODEL_ESP32S3_EYE (I have tried others but nothing get printed in the serial monitor).
The problem is that, with the actual cfg, the micro keeps resetting (below serial monitor output):
/ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x8 (TG1WDT_SYS_RST),boot:0xb (SPI_FAST_FLASH_BOOT)
Saved PC:0x40377441
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3818,len:0x508
load:0x403c9700,len:0x4
load:0x403c9704,len:0xad0
load:0x403cc700,len:0x29e4
entry 0x403c9880
Also, in the code there are three different cfg for CAMERA_MODEL_ESP32S3_EYE (this is what I found online) but all of them give me the same output reported above.
Please help.
Got an S3 cam..
settings..
those defines look wrong, the ones commented out look correct..
never had to press the buttons on loading code, so not sure what that is all about..
empty loop, add a delay(1000); to it..
thinking the bad defines is causing the reboot..
have you tried a simple sketch, print something..
can try lowering upload speed or different cable..
if you're in a usb hub, try a direct connection..
good luck.. ~q
So, I'm able to read on the serial monitor but it doesn't say anything about the camera initialization.
The settings are correct in Arduino. I think what's wrong is the cfg I'm using to map the PIN.
This is the datasheet of my micro. Could you help with that? Which cfg should I use according to the code I posted?
Thank you.
like I mentioned in the last post..
looks like it matches..
you have these commented out twice in the code you posted..
they look correct and work for my esp32s3 cam..
good luck.. ~q
