I have developed a couple of widgets with the AHT10 T/RH sensor and the Wemo D mini EPS8266 module. One wakes up every 15 or so minutes and connects to the WiFi and a TCP server and pushes the data, then goes back to sleep. It works fine. There is another with the sensor + I2C LED screen and is intended to be powered 24/7, taking a reading every second or so. I would like this second unit to push the data to the TCP server every 900 measurement loops (~15 minutes). I am finding a problem with the second system.
I've included the test code (with only the sensor and the WiFi/TCP sections) with a 10 measurement loop to 1 TCP push. Everything works fine the first time around. The non-TCP data goes out the serial port, the data gets pushed to the TCP server, but the next time around the code breaks at "Wire.write(AHT10_MEAS); " line 140 and trips the HW WDT. For some reason the appears the I2C functions are getting stepped on when the TCP functions have been called. I've been a lot of digging and existing the WiFi client properly and tried what I have found, but have found the solution yet. Any thought are apricated and I would really like to know what I'm missing because there are other devices I have in mind the require these to capabilities to play nice.
Regards,
KS
Testing code:
#include <Wire.h>
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
extern "C" { //Files for WPA2 Enterprise networks
#include "user_interface.h"
#include "wpa2_enterprise.h"
char tp[40]; //General use array for messages
uint32_t _rawDataBuffer[6]; //Sensor data array
uint32_t hum; //humidity bit count
uint32_t tem; //temperature bit count
//AHT10 Stuff
#define led_addr 0x3C
#define AHT10_addr 0x38
#define AHT10_INIT 0xE1
#define AHT10_RESET 0xBA
#define AHT10_MEAS 0xAC
#define AHT10_NORMAL_CMD 0xA8 //normal cycle mode command, no info in datasheet!!!
#define AHT10_INIT_NORMAL_MODE 0x00 //enable normal mode
#define AHT10_INIT_CYCLE_MODE 0x20 //enable cycle mode
#define AHT10_INIT_CMD_MODE 0x40 //enable command mode
#define AHT10_INIT_CAL_ENABLE 0x08 //load factory calibration coeff
#define AHT10_DATA_MEASURMENT_CMD 0x33 //no info in datasheet!!! my guess it is DAC resolution, saw someone send 0x00 instead
#define AHT10_DATA_NOP 0x00 //no info in datasheet!!!
#define AHT10_FORCE_READ_DATA true //force to read data
#define AHT10_USE_READ_DATA false //force to use data from previous read
#define AHT10_ERROR 0xFF //returns 255, if communication error is occurred
#define AHT10_MEASURMENT_DELAY 80 //at least 75 milliseconds
#define AHT10_POWER_ON_DELAY 40 //at least 20..40 milliseconds
#define AHT10_CMD_DELAY 350 //at least 300 milliseconds, no info in datasheet!!!
#define AHT10_SOFT_RESET_DELAY 20 //less than 20 millisecondsn
#define deno 0X100000
//Default calibration values for the AHT10
float mt = 200.0; //200 default
float bt = -50.0; //-50 default
float mh = 100.0; //100 default
float bh = 0.0; //0 Default
//WiFi burst variables
// SSID to connect to
char* ssid = <ssid_name>;
// Username for authentification
char* username = <uid>;
// Password for authentication
char* password = <passkey>;
int checkin = 10;
IPAddress staticIP("xxx.xxx.xxx.xxx");
IPAddress dns("xxx.xxx.xxx.xxx");
IPAddress gateway("xxx.xxx.xxx.xxx");
IPAddress subnet("xxx.xxx.xxx.xxx");
Wire.begin();
Serial.println("Setup");
Serial.println("Sensor setup");
//Init Code
Wire.beginTransmission(AHT10_addr);
Wire.write(AHT10_NORMAL_CMD);
Wire.write(AHT10_DATA_NOP);
if(Wire.endTransmission(true) !=0){
Serial.println("Init Failed");
return;
Serial.println("Init Success");
delay(AHT10_CMD_DELAY);
//Mode Code
Wire.write(AHT10_INIT);
Wire.write(AHT10_INIT_CYCLE_MODE|AHT10_INIT_CAL_ENABLE);
Serial.println("Mode Failed");
return;
Serial.println("Mode Success");
//Setup WiFi
WiFi.config(staticIP, dns, gateway, subnet);
WiFi.begin();
wifi_set_opmode(STATION_MODE);
struct station_config wifi_config;
memset(&wifi_config, 0, sizeof(wifi_config));
strcpy((char*)wifi_config.ssid, ssid);
wifi_station_set_config(&wifi_config);
wifi_station_clear_cert_key();
wifi_station_clear_enterprise_ca_cert();
wifi_station_set_wpa2_enterprise_auth(1);
wifi_station_set_enterprise_identity((uint8*)username, strlen(username));
wifi_station_set_enterprise_username((uint8*)username, strlen(username));
wifi_station_set_enterprise_password((uint8*)password, strlen(password));
wifi_station_connect();
// Wait for connection
delay(1);
Serial.print("Waiting for connection");
int tries = 0;
tries++;
delay(250);
Serial.print(".");
if(tries>40){
Serial.println("\nNetwork connection failed");
WiFi.mode(WIFI_OFF); //Shut off the radio
ESP.deepSleep(60e6); //go to sleep for this many micro-seconds return;
WiFi.setOutputPower(20.5);
Serial.println("");
Serial.print("Connected, IP address: ");
delay(1000); //Delay for 1 secound a loop
Wire.requestFrom(AHT10_addr, 1);
if (Wire.available() != 1){
Serial.println(AHT10_ERROR); //check rxBuffer & error handler, collision on I2C bus
else{
Wire.beginTransmission(AHT10_addr); //Start I2C meassage
Serial.println("begin"); //Debug output
Wire.write(AHT10_MEAS); //send measurment command //code breaks here on second pass thru
Serial.println("MEAS"); //Debug output
Wire.write(AHT10_DATA_MEASURMENT_CMD); //send measurment parameter
Serial.println("DATA"); //Debug output
Wire.write(AHT10_DATA_NOP); //NOP
Serial.println("NOP"); //Debug output
if (Wire.endTransmission(true) != 0){ //Error out IF
_rawDataBuffer[0] = AHT10_ERROR;
Wire.requestFrom(AHT10_addr, 6, true); //Get the 6 data registor
if (Wire.available() != 6) //If there are not 6 valid returns
_rawDataBuffer[0] = AHT10_ERROR; //Place 0xFF in 1st buffer valvue
else{ //or fill the buffer values
for (uint8_t i = 0; i < 6 ; i++)
_rawDataBuffer[i] = Wire.read();
//if the buffer 0 not 0xff, do the bitwise combining
if(_rawDataBuffer[0] != AHT10_ERROR){
hum = _rawDataBuffer[1]<<8;
hum |= _rawDataBuffer[2];
hum <<=4;
hum |= _rawDataBuffer[3]>>4;
tem = _rawDataBuffer[3] &0XF;
tem <<=8;
tem |=_rawDataBuffer[4];
tem<<=8;
tem |=_rawDataBuffer[5];
//If checking is greater than 0
if(checkin >0){
checkin--; //decrement it
else{ //else push data to TCP server
if(WiFi.status() == WL_CONNECTED){ //if the wifi is connected
Serial.println("Connected"); //Debug output
uint8_t mac[6]; //Mac Address array
WiFi.macAddress(mac); //Get mac address
char* serverIP = "xxx.xxx.xxx.xxx"; //TCP serve ip
WiFiClient client; //Define tcp client
if(client.connect(serverIP,900)){ //Connec to server
Serial.print("Client Stat: "); //Debug output
Serial.println(client.status()); //Debug output
//Move data to tp array
sprintf(tp,"%d\t%.2f\t%.2f\t%d\t%.2f\t%.2f\t%02X:%02X:%02X:%02X:%02X:%02X\n",tem,mt,bt,hum,mh,bh,mac[0],mac[1],mac[2],mac[3],mac[4],mac[5]);
client.println(tp); //Send TCP array
//client.stop(); //(may not need) Server breaks the connection after detecting line break
// while(client.status() != CLOSED){ (may not need) wait for client connection ti close
// delay(10);
checkin = 10; //reset counter
else{ //if Wifi not connected
Serial.println("Not Connceted"); //Debug output
float h = (float)hum*mh/0x100000+bh; //Do the math
float t = (float)tem*mt/0x100000+bt;
sprintf(tp,"%.2f\t%.2f", h, t); //move values to tp array
Serial.println(tp); //Send calculate values out serial port
