Hi guys,
i got a terrible issue where i am not able to find a solution for....
I want to read/write some sensor datas with the help of a customized struct datatyp to an FRAM chip. Writing can be done without any issues now and the data saving is validated - so this part is OK. But the reading part makes some issues to me:
If i started the project - reading was done exactly the same as writing in the other direction - you not say?!?
I tryed it with several lines of code - and it works fine!
Now for the final solution i cleaned the code up and i am now struggeling at a line, where i print the data for debbuing purpose. If i delete this line- the code is not runnable any more and the esp runs into restart routine!
I will post the code here of the reading purpose:
* Read Sensor Data from FRAM
PowerValues ConvertSensorDataFromFRam(uint16_t Pos){
/* Format to Read FRAM Data:
* 4Byte UNIX Time Stamp // 4Byte Current Data // 4Byte Power Data // 4 Byte Load Voltage Data // 4byte dT //4Byte Current Data // 4Byte Power Data // 4Byte dt
* Epoch Time wird nur in der ersten Iteration geschrieben! Dann wird nur mehr das dT verwendet aus current millis()!!!
PowerValues _data;
Serial.println("Creating Structur Element done!");
Serial.println(ESP.getFreeHeap());
for (uint8_t _i = 1; _i < 5; _i++) {
_data.timestamp.b[_i] = (byte)fram.read(Pos+_i);
_data.current.b[_i] = (byte)fram.read(Pos+_i+4);
_data.power.b[_i] = (byte)fram.read(Pos+_i+8);
_data.loadvoltage.b[_i] = (byte)fram.read(Pos+_i+12);
Serial.print("\n For Debugging------------------>>>>"); Serial.print(_data.timestamp.b[_i], HEX); Serial.print("\n"); //<<--- This is the line which makes the issue!!!
Serial.println(_i);
Serial.println(_data.current.f);
//Serial.println(_data.timestamp.ul);
return _data;
If I uncomment the line of the mentioned serial.print() routine in the Serial Output I become the following error message:
19:02:46.688 -> User exception (panic/abort/assert)
19:02:46.688 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
19:02:46.688 ->
19:02:46.688 -> Panic core_esp8266_main.cpp:215 loop_task
19:02:46.688 ->
I can not found the root cause of the deletion of this special line of code.How should this serial print command influences the code in such a way that it causes a restart of the ESP?
Maybe someone can help me here...
Great Regards!
Jojo
