Hello,
The buzz() function shown below works fine when executed on an Arduino but fails when it’s executed on an ESP8266-12. It causes a memory overflow and, therefore, a crush.
I cannot understand why. Can someone pls help me understand where the error is?
TIA
#include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
byte buzzPin = 4; // pin 2 fails as well
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
//reset saved settings
//wifiManager.resetSettings();
//set custom ip for portal
//wifiManager.setAPConfig(IPAddress(10,0,1,1), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
//fetches ssid and pass from eeprom and tries to connect
//if it does not connect it starts an access point with the specified name
//here "AutoConnectAP"
//and goes into a blocking loop awaiting configuration
wifiManager.autoConnect("AutoConnectAP");
//or use this for auto generated name ESP + ChipID
//wifiManager.autoConnect();
//if you get here you have connected to the WiFi
Serial.println("connected...yeey :)");
buzz(buzzPin, 2000, 2000);
void buzz(byte pin, uint16_t frequency, uint16_t duration)
{ // input parameters: Arduino pin number, frequency in Hz, duration in milliseconds
unsigned long startTime = millis();
unsigned long halfPeriod = 1000000L / frequency / 2;
pinMode(buzzPin, OUTPUT);
while (millis() - startTime < duration)
digitalWrite(buzzPin, HIGH);
delayMicroseconds(halfPeriod);
digitalWrite(buzzPin, LOW);
pinMode(buzzPin, INPUT);
