ESP8266 128x32 Oled i2c problem
Hello i bought a ESP8266 with a 128x32 oled I tried everything to figure this problem out but some odd reason the i can not get the i2c to run. The oled does show up on i2c by using the i2c scanner. But if i put any other i2c device and scan nothing comes up but the oled 0x3C This is the board. I don't know what to do not even sure who made it. I been trying and trying but no luck can someone please help me?
joseph
Just a update. I found a gpio scanner online and it told me to put i2c pins on D6 and D7 pins this is the link here. So i put the i put SDA on D6and SCL on D7 that found it with the address of Scanning (SDA : SCL) - GPIO12 : GPIO13 - I2C device found at address 0x76 ! I don’t know how to map to them pins I’m trying to add the bme280 to this device. here is the sketch below.
// Create BME280 object
BME280_I2C bme; // I2C using address 0x77
// or BME280_I2C bme(0x76); // I2C using address 0x76
Serial.println("Bosch BME280 Pressure - Humidity - Temp Sensor | cactus.io");
if (!bme.begin()) {
Serial.println("Could not find a valid BME280 sensor, check wiring!");
while (1);
bme.setTempCal(-1);// Temp was reading high so subtract 1 degree
Serial.println("Pressure\tHumdity\t\tTemp\ttTemp");
bme.readSensor();
Serial.print(bme.getPressure_MB()); Serial.print(" mb\t"); // Pressure in millibars
Serial.print(bme.getHumidity()); Serial.print(" %\t\t");
Serial.print(bme.getTemperature_C()); Serial.print(" *C\t");
Serial.print(bme.getTemperature_F()); Serial.println(" *F");
// Add a 2 second delay.
delay(2000); //just here to slow down the output.
Can someone please help me?
