ESP8266 - 9V Battery Wiring
I've just had the ESP8266 unit delivered and reading a few bits of information found that it shouldn't be powered from my Uno as it isn't able to give the full power rating. I know some people have but I'd rather play it safe and not risk either of them.
Does anyone have a simple wiring diagram on how to set this up using a standard 9V battery?
I have plenty of resistors, a few disc capacitors (others on order) and some 5V voltage regulators.
Hoping I can get away with that.
Any help most appreciated.
Thought I better include the capacitors I have at the moment as attached.
I have the L7805CV voltage regulator, will all these capacitors be too small for that?
A 9V battery is even weaker than the Arduino 5V pin.
OK then what about if I pull another lead from the computer USB port at 5V?
Will also need to look at an alternative power supply as I was hoping to run some items away from a PC / Laptop.
The ESP8266 requires 3.3V! Do not connect it directly to a 5V arduino.
You could use a 3.3V regulator to power it from the Arduino's 5V pin. The 3.3V pin on the Arduino is not capable of much current. You will need level shifters is using a 5V Arduino.
If you get a 3.3V Arduino you will have power and signals that work with the ESP8266 directly. If you don't need a lot of computing power or peripherals you can write code directly for the ESP8266 and not use the Arduino.
Would it be possible to use another USB socket from the PC and just knock the voltage down with a resistor? Thinking short term so at least I can get and test it.
Still need to think of an external power source away from the PC.
Langy: Would it be possible to use another USB socket from the PC and just knock the voltage down with a resistor?
No. A resistor is not a voltage regulator. A resistor voltage divider only works for VERY small loads (many thousands of Ohms), like an input pin.
I've seen a lot of posts like this where the on board 3.3v supply is used. Instructions
shrug all I can say is the Arduino Uno should not be able to supply enough power to an ESP8266, based on the specs for the two devices.
ESP can take up to ~200ma when it's transmitting, while the 3.3v regulator on the uno is rated at 50.
Maybe the regulators are spec'ed conservatively and you can get away with it under some circumstances... but I wouldn't expect it to function reliably, and with how dodgy the ESP's are said to be, I'd want to take such "silly" causes of problems out of the picture as soon as I could.
Yes when I read that the UNO can cater for 50ma I was very skeptical about sticking it on. I've only just got the UNO and certainly don't want to go blow it up just yet.
I've ordered a couple of 3.3v regulators today so more waiting as all the parcels get delivered from eBay. I guess that I will have to use the capacitors again either side of the regulator.
What sort of life span would you expect from a 9V rechargeable battery on this? I'm initially just looking to use one for testing and programming to see how to use it. Does anyone have a recommendation as the cheapest and best way to power this?
These devices take around 200mA unless you put them into sleep / powerdown mode.
If you use a linear regulator e.g. like a LM1117T it will draw 200mA + the regulation current e.g. 10mA from your 9V battery.
From what I recall, the normal NiCad or NiMh rechargable 9V battery is 300mAH, which would give you around 1.5 hours of use, and I suspect in reality only 1 hour of use
You would be better off using a mobile phone battery as they are 3.7V Max, ( http://en.wikipedia.org/wiki/Lithium_polymer_battery ) which I think is just about within the range for the chip
Someone has a blog where they do this
http://translate.googleusercontent.com/translate_c?depth=1&hl=en&prev=search&rurl=translate.google.com.au&sl=de&u=http://thomaspfeifer.net/esp8266_wlan_seriell_modul_at_kommandos.htm&usg=ALkJrhg3XrLK8eYfqvd5VPrRBVwe39AfJA
I use a mobile phone battery and one of these http://www.ebay.com.au/itm/5V-Mini-USB-1A-Lithium-Battery-Charging-Lipo-Charger-Module-for-Arduino-A866-/171208528535?pt=AU_B_I_Electrical_Test_Equipment&hash=item27dcd2d297 for most of my 3.3V projects, however I have not tested on the ESP8266
If I can get at least an hour out of a 9V battery then that would be fine for testing.
I’ve also been reading where people have had to put voltage dividers on either ther RX to TX connections.
Would be nice if someone did a proper tutorial on one of these.
Langy: If I can get at least an hour out of a 9V battery then that would be fine for testing. I've also been reading where people have had to put voltage dividers on either ther RX to TX connections. Would be nice if someone did a proper tutorial on one of these.
The 3.3V ESP8266 outputs will generally work fine with 5V Arduino inputs. Since the ESP8266 inputs are not 5V-safe you should use some form of level shifting if you want to attach them to a 5V Arduino output. Two 1K resistors in series will divide the 5V output down to 2.5V which should work fine on 3.3V inputs. You can also use three 1K resistors in series. Use the tap nearer the 5V output to get a 3.3V signal. DON'T try to use a voltage divider to supply power to the ESP8266. That trick only works on very light loads like input pins.
