I do not know ESP-NOW, but I use UDP since many years (also for broadcast to synchronize a lot of network members).
There is only one trap (what I detected with ESP32, may be others with ESP8266): If the time between the sent messages is near milliseconds (or less), the messages may be concatenated because there is some delay before sending.
It is also very easy to handle because the ESP8266 WiFi library provides a typical socket interface, as you may know from networking with Windows and Linux.
Good luck ...
Thank you for the link @groundFungus .
I understand what is meant with "easy set up and use".
And I have seen, it is a direct transmission on a very low level.
That may be a good solution for simple transfer of a few bytes as @StefanL38 wants to have.
For me it would not fit, because it seems to run only with ESPs. Wonder if you can use a DUE (or other Arduinos) with WiFi-Shield or even transfer data to Your Smartphone or Notebook/PC, which is nearly the same interface when using sockets. Of course You need a router (access point) with UDP and a mixture of devices like arduinos, computers, tablets and smartphones.
