Esp8266 and Alexa with Sinricpro
Hello everybody,
I'm trying to link my esp8266 with Alexa and I'm facing few problems, this is my code I found
 Version 0.1 - Feb 10 2018
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#include <WebSocketsClient.h> //  https://github.com/kakopappa/sinric/wiki/How-to-add-dependency-libraries
#include <ArduinoJson.h> // https://github.com/kakopappa/sinric/wiki/How-to-add-dependency-libraries
ESP8266WiFiMulti WiFiMulti;
WebSocketsClient webSocket;
WiFiClient client;
#define MyApiKey "aa9a9754-8874-4f80-95fc-b8c2a86e9365" // TODO: Change to your sinric API Key. Your API Key is displayed on sinric.com dashboard
#define MySSID "rete_da_pesca" // TODO: Change to your Wifi network SSID
#define MyWifiPassword "tjKBnkrVAIVJPnFA1vtVzNwd" // TODO: Change to your Wifi network password
#define API_ENDPOINT "http://sinric.pro"
#define HEARTBEAT_INTERVAL 300000 // 5 Minutes
uint64_t heartbeatTimestamp = 0;
bool isConnected = false;
void turnOn(String deviceId) {
  if (deviceId == "603a7b389c7d260a60ba091f") // Device ID of first device
    Serial.print("Turn on device id: ");
    Serial.println(deviceId);
  else if (deviceId == "603a7b389c7d260a60ba091f") // Device ID of second device
  else {
    Serial.print("Turn on for unknown device id: ");
void turnOff(String deviceId) {
     Serial.print("Turn off Device ID: ");
  else {
     Serial.print("Turn off for unknown device id: ");
void webSocketEvent(WStype_t type, uint8_t * payload, size_t length) {
  switch(type) {
    case WStype_DISCONNECTED:
      Serial.printf("[WSc] Webservice disconnected from sinric.com!\n");
    case WStype_CONNECTED: {
      isConnected = true;
      Serial.printf("[WSc] Service connected to sinric.com at url: %s\n", payload);
      Serial.printf("Waiting for commands from sinric.com ...\n");
    case WStype_TEXT: {
        Serial.printf("[WSc] get text: %s\n", payload);
        // Example payloads
        // For Light device type
        // {"deviceId": xxxx, "action": "setPowerState", value: "ON"} // https://developer.amazon.com/docs/device-apis/alexa-powercontroller.html
        // {"deviceId": xxxx, "action": "AdjustBrightness", value: 3} // https://developer.amazon.com/docs/device-apis/alexa-brightnesscontroller.html
        // {"deviceId": xxxx, "action": "setBrightness", value: 42} // https://developer.amazon.com/docs/device-apis/alexa-brightnesscontroller.html
        // {"deviceId": xxxx, "action": "SetColor", value: {"hue": 350.5,  "saturation": 0.7138, "brightness": 0.6501}} // https://developer.amazon.com/docs/device-apis/alexa-colorcontroller.html
        // {"deviceId": xxxx, "action": "DecreaseColorTemperature"} // https://developer.amazon.com/docs/device-apis/alexa-colortemperaturecontroller.html
        // {"deviceId": xxxx, "action": "IncreaseColorTemperature"} // https://developer.amazon.com/docs/device-apis/alexa-colortemperaturecontroller.html
        // {"deviceId": xxxx, "action": "SetColorTemperature", value: 2200} // https://developer.amazon.com/docs/device-apis/alexa-colortemperaturecontroller.html
#if ARDUINOJSON_VERSION_MAJOR == 5
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject((char*)payload);
#endif
#if ARDUINOJSON_VERSION_MAJOR == 6
        DynamicJsonDocument json(1024);
        deserializeJson(json, (char*) payload);
#endif
        String deviceId = json ["deviceId"];
        String action = json ["action"];
        if(action == "setPowerState") { // Switch or Light
            String value = json ["value"];
            if(value == "ON") {
                turnOn(deviceId);
                turnOff(deviceId);
        else if(action == "SetColor") {
            // Alexa, set the device name to red
            // get text: {"deviceId":"xxxx","action":"SetColor","value":{"hue":0,"saturation":1,"brightness":1}}
            String hue = json ["value"]["hue"];
            String saturation = json ["value"]["saturation"];
            String brightness = json ["value"]["brightness"];
            Serial.println("[WSc] hue: " + hue);
            Serial.println("[WSc] saturation: " + saturation);
            Serial.println("[WSc] brightness: " + brightness);
        else if(action == "SetBrightness") {
        else if(action == "AdjustBrightness") {
        else if (action == "test") {
            Serial.println("[WSc] received test command from sinric.com");
    case WStype_BIN:
      Serial.printf("[WSc] get binary length: %u\n", length);
    default: break;
  WiFiMulti.addAP(MySSID, MyWifiPassword);
  Serial.print("Connecting to Wifi: ");
  Serial.println(MySSID);
  // Waiting for Wifi connect
  while(WiFiMulti.run() != WL_CONNECTED) {
    Serial.print(".");
  if(WiFiMulti.run() == WL_CONNECTED) {
    Serial.println("");
    Serial.print("WiFi connected. ");
    Serial.print("IP address: ");
  // server address, port and URL
  webSocket.begin("iot.sinric.com", 80, "/");
  // event handler
  webSocket.onEvent(webSocketEvent);
  webSocket.setAuthorization("apikey", MyApiKey);
  // try again every 5000ms if connection has failed
  webSocket.setReconnectInterval(5000);   // If you see 'class WebSocketsClient' has no member named 'setReconnectInterval' error update arduinoWebSockets
  webSocket.loop();
  if(isConnected) {
      uint64_t now = millis();
      // Send heartbeat in order to avoid disconnections during ISP resetting IPs over night. Thanks @MacSass
      if((now - heartbeatTimestamp) > HEARTBEAT_INTERVAL) {
          heartbeatTimestamp = now;
          webSocket.sendTXT("H");
  • I cannot connect to http://sinric.pro at all, all the tutorials I find over the Internet are about the old version sinric.com, what is supposed to put in the #define API_ENDPOINT line?
  • I'd like to control one of the two GPIO pin I have, putting it HIGH and LOW with Alexa, and then, using one of the digital pins of Arduino, turn on the led, this should not be very complicated, but I cannot figure out twhich part of the above code should be changed..
  • I would like to start from something very easy, i.e. turn on a led by saying to Alexa "turn on the led", but all the tutorial I find are about much more complicated projects with much more complicated board with a lot of pins(chronotermostats, PIR lightining and so on), can someone suggest me a site where I can find very simple project to begin to discover my module which has only two GPIO pin accessible (GPIO0 and GPIO2)?
Thanks a lot for your suggestions...
Hello,
You should be using the SDK provided by sinric.pro which eases up lot on your part, including API host etc. Check out their GitHub repo GitHub - sinricpro/esp8266-esp32-sdk: Library for https://sinric.pro - simple way to connect your device to Alexa, Google Home, SmartThings and cloud
I found out in their SDK the default API host mentioned as "ws.sinric.pro"
chall3ng3r:
Hello,
You should be using the SDK provided by sinric.pro which eases up lot on your part, including API host etc. Check out their GitHub repo GitHub - sinricpro/esp8266-esp32-sdk: Library for https://sinric.pro - simple way to connect your device to Alexa, Google Home, SmartThings and cloud five nights at freddy's
Thanks, I'll have a look.
