ESP8266 and AM1008W
Hello, I am new to programming and I have tried to connect an AM1008w sensor with an ESP8266, the problem is that when the sensor values are printed, it only gives 0, as shown below:
I would appreciate any help you could give me, since I have no idea if it is because the esp8266 cannot read the data or some other fault, the code I use is like this:
#include <am1008w_k_i2c.h>
AM1008W_K_I2C am1008w_k_i2c;
  am1008w_k_i2c.begin();
void loop(){
  Serial.print("Co2 : ");
  Serial.println(am1008w_k_i2c.get_co2());
  Serial.print("VOC : ");
  Serial.println(am1008w_k_i2c.get_voc());
  Serial.print("Humidity : ");
  Serial.println(am1008w_k_i2c.get_humidity());
  Serial.print("Temperature : ");
  Serial.println(am1008w_k_i2c.get_temperature());
  Serial.println("GRIMM");
  Serial.print("PM1.0 : ");
  Serial.println(am1008w_k_i2c.get_pm1p0());
  Serial.print("PM2.5 : ");
  Serial.println(am1008w_k_i2c.get_pm2p5());
  Serial.print("PM10 : ");
  Serial.println(am1008w_k_i2c.get_pm10());
  Serial.println("TSI");
  Serial.print("VOC Now R / Ref. R (%) : ");
  Serial.println(am1008w_k_i2c.get_voc_now_r_ref_r());
  Serial.print("VOC Ref. R Value : ");
  Serial.println(am1008w_k_i2c.get_voc_ref_r());
  Serial.print("VOC Now R Value : ");
  Serial.println(am1008w_k_i2c.get_voc_now_r());
  Serial.println("");
delay(9000);
Thanks again for any help you can give me.
try running File>Examples>AM1008w-K-I2C>AM1008w-K-I2C_Test it may give you more information
provide a circuit diagram of the your system? what pullup resistors are you using?
Cross posting warning
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Thread closed.
