I have a NodeMCU board (with ESP8266). I'm using DS18B20, 2 of them in parallel on 3 wires. They are connected to 3V3, GND and D3. There's a resistor between 3V and the data line. All standard and I've used it several times before with Arduino and 5V.
It all works perfectly if the NodeMCU is connected to usb, and powered that way. I want it powered from the 5V inside some equipment. When I connect that to VIN and GND (and remove the usb) everything else is fine but the DS18B20 read -127. The 5V is from a "VIN" pin, for an missing optional extra on a pcb. It shows 5V on my cheap multi-meter.
The resistor was 4K7, but somewhere I saw recommendation to use 3K3 on 3V. Tried that, no better.
I'd be happy to have a temperature reading only every minute. If I can trade off speed for reliability that would be good.
Everything else: The NodeMCU loads the program with OTA, BME280 is reading correctly, values sent by UDP arriving, OTA demo web-site switches GPIO pin on/off.
Any help appreciated.
