ESP8266 and mesh acces point (NEST WIFI)
Hello
I've change my Wifi setup from a single access point to a Mesh Access Point (NEST WIFI 3 points)
Since then my nodemcu and my wemos d1 mini have a LOT of difficulties to connect the wifi.
It takes at least 3 minutes to connect and it lost the connexion after 6 or 7 minutes
I use the ESP8266Wifi libraries and I tried all ESP8266Wifi example in arduino IDE, same result
If i put my iPhone AP connexion it works very well.
I think that it as difficulties because the scan reports 3 networks with the same name (my 3 hardware AP)
Does any one know how to fix it ?
Thank you
Multinet
If your nest nodes do have the same hostname, then do they also have the same IP address? Do an IP scan to determine if they have different IP addresses then use the IP address instead of the hostname.
