ESP8266,ARDUINO->PHP->SQL
Dear all
with the help of this forum i managed to send data to my sql database (https://forum.arduino.cc/index.php?topic=464586.0) using an ethernet shield. Im now trying to do the same thing using a esp8266 esp-01 module. At this point im just trying to send a data string to my php and i know I`m missing something. Here is the code:
#include "SoftwareSerial.h"
String ssid ="Rafina";
String password="4112703241";
SoftwareSerial esp(2, 3);// RX, TX
String server = "192.168.42.21"; // www.example.com
String uri = "/writeSql.php?";// our example is /esppost.php
String cmd = "AT+CWJAP=\"" +ssid+"\",\"" + password + "\"";
String temp= "100";
String hum= "100";
String data = "temp1=" + temp + "&hum1=" + hum;// data sent must be under this form //name1=value1&name2=value2.
String postRequest = "GET " + uri + data + " HTTP/1.1 \r\n" + "Host: 192.168.42.21 \r\n" + "Content-Type: application/x-www-form-urlencoded \r\n" + "Connection: close \r\n";
esp.begin(9600);
void loop () {
esp.println("AT+RST");
Serial.println("AT+RST");
esp.println(cmd);
Serial.println(cmd);
delay(4000);
esp.println("AT+CIPSTART=\"TCP\",\"" + server + "\",80");//start a TCP connection.
Serial.println("AT+CIPSTART=\"TCP\",\"" + server + "\",80");
esp.println("AT+CIPSEND=");
Serial.println("AT+CIPSEND=");
esp.print(postRequest);
Serial.print(postRequest);
esp.println(" HTTP/1.1");
Serial.println(" HTTP/1.1");
esp.println("Host: 192.168.42.21" );
Serial.println("Host: 192.168.42.21" );
esp.println("Content-Type: application/x-www-form-urlencoded" );
Serial.println("Content-Type: application/x-www-form-urlencoded" );
esp.println( "Connection: close" );
esp.print("AT+CIPCLOSE");
Serial.println("AT+CIPCLOSE");
delay(100000);
It does not work! What is missing?
Hi all,
I`m trying to send data to my php script and then to my sql database using the AT commands on the serial monitor. I have managed to send data using my Ethernet shield, as described here, https://forum.arduino.cc/index.php?topic=464586.0 , and now I'm trying to adapt the code on my esp8266.
So this is the Ethernet shield code that I want to alter:
if (client.connect(server,80)) { // REPLACE WITH YOUR SERVER ADDRESS
    Serial.println("Connected");
 client.print("GET /writeSql.php?");
    Serial.print("GET /writeSql.php?");
    client.print("temp1=");
    Serial.print("temp1=");
    client.print(t);
    Serial.print(t);
    client.print("&hum1=");
    Serial.print("&hum1=");
    client.print(h);
    Serial.print(h);
    client.println(" HTTP/1.1");
    client.println("Host: 192.168.42.21" );
    client.println("Content-Type: application/x-www-form-urlencoded" );
    client.println( "Connection: close" );
    Serial.println( "Connection: close" );
    client.println();
    client.println();
  client.stop();  // DISCONNECT FROM THE SERVER
  Serial.println("Client Stop");
and this is what commands I use on the ESP8266 serial monitor:
AT+RST
OK
4,CLOSED
H!�΅Ρ!§�
1όF
�)�ξζΉ* •(H~� C΅¥µThinker Technology Co. Ltd.
ready
AT+GMR
AT version:0.21.0.0
SDK version:0.9.5
OK
AT+CWMODE=1
OK
AT+CWJAP="Rafina","4112703241"
OK
AT+CIPMUX=0
OK
AT+CIFSR
+CIFSR:STAIP,"192.168.42.164"
+CIFSR:STAMAC,"18:fe:34:a0:c0:27"
OK
AT+CIPSTART="TCP","192.168.42.21",80
CONNECT
OK
AT+CIPSEND=134
OK
> GET /writeSql.php?temp1=100&hum1=100 HTTP/1.1  Host: 192.168.42.21  Content-Type: application/x-www-form-urlencoded  Connection: close
busy s...
SEND OK
AT+CIPSTATUS
STATUS:3
+CIPSTATUS:0,"TCP","192.168.42.21",80,0
OK
AT+CIPCLOSE
CLOSED
OK
Unfortunately no data are send to my sql. Is something missing? Thank you all!!
@bitaris, please do not cross-post. Mess cleansed.
