ESP8266 + Arduino serial read problem
Hello, super-friends!
I'm encountering a problem when trying to send single bytes from my esp 8266 to arduino over hardware or software serial.
The project is as follows : a webserver hosted on my esp retrieves data from the user (numerical values 0-255), converts to byte then sends over serial to arduino, which is meant to receive the data and adjust parameters on some programming for LEDs accordingly.
what happens: everything on the esp appears to work correctly, the output received through the serial monitor displays what it is supposed to display. however.....
once i try to send the data to my arduino, i hit problems.
The arduino will display two bytes received through serial, however the bytes received are almost always "255" or a random number between 100 and 255. If i set Serial.availiable()>1 to >0, it will display "255" ad infinitum
simple Arduino recieve code:
 Serial.println("arduino online");
 Serial.println("");
   Serial.println("looping");
 while(Serial.available()<1)
    Serial.println("serial not yet recieved");
 Serial.println("serial recieved");
 byte b1=Serial.read();
 byte b2=Serial.read();
 Serial.println(b1);
 Serial.println(b2);
ESP code (pardon all the commented out print statements and using brightness through all the message handling, quite experimental code)
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
String form =                // String form to sent to the client-browser
  "<p>"
  "<center>"
  "<h1>Sorry for the inconvenience, but you may only update one value at a time </h1>"
  "<form action='msg1'><p> brightness (0-255) <input type='text' name='msg1' size=50 autofocus> <input type='submit' value='Submit'></form>"
  "<form action='msg2'><p> red max    (0-255) <input type='text' name='msg2' size=50 autofocus> <input type='submit' value='Submit'></form>"
  "<form action='msg3'><p> green max  (0-255) <input type='text' name='msg3' size=50 autofocus> <input type='submit' value='Submit'></form>"
  "<form action='msg4'><p> blue max   (0-255) <input type='text' name='msg4' size=50 autofocus> <input type='submit' value='Submit'></form>"
  "<form action='msg5'><p> red min    (0-255) <input type='text' name='msg5' size=50 autofocus> <input type='submit' value='Submit'></form>"
  "<form action='msg6'><p> green min  (0-255) <input type='text' name='msg6' size=50 autofocus> <input type='submit' value='Submit'></form>"
  "<form action='msg7'><p> blue min   (0-255) <input type='text' name='msg7' size=50 autofocus> <input type='submit' value='Submit'></form>"
  "<form action='msg8'><p> Iteration Delay(milliseconds)<input type='text' name='msg8' size=50 autofocus> <input type='submit' value='Submit'></form>"
  "</center>";
ESP8266WebServer server(80); //initiate webserver via esp8266webserver.h
#define SSID "SHAH-CLOUD"
#define PWORD "1234567890"
int brightness = 255;
int rMax = 255;
int bMax = 255;
int gMax = 255;
int bMin = 255;
int rMin = 255;
int gMin = 255;
  //Serial.print("  Welcome to LED Control ");
  //Serial.print("Configuring AP");
  WiFi.mode(WIFI_AP_STA);
  IPAddress ip(1,2,3,4);
  IPAddress gateway(1,2,3,1);
  IPAddress subnet(255,255,255,0);
  WiFi.softAPConfig(ip, gateway, subnet);
       //start the accesspoint
  WiFi.softAP(SSID, PWORD);
  //Serial.print("AP Configured");
  // Set up the endpoints for HTTP server,  Endpoints can be written as inline functions:
  //Serial.print("Configuring server");
  server.on("/", []()
    server.send(200, "text/html", form);
  server.on("/msg1", handle_msg1);                 // And as regular external functions:
   server.on("/msg2", handle_msg2);
   server.on("/msg3", handle_msg3);
   server.on("/msg4", handle_msg4);
   server.on("/msg5", handle_msg5);
   server.on("/msg6", handle_msg6);
   server.on("/msg7", handle_msg7);
   server.on("/msg8", handle_msg8);
  server.begin();                                // Start the server
//Serial.print("server configured & started");
  server.handleClient();
void handle_msg1() {
server.send(200, "text/html", form);                    // Send same page so they can send another msg
String msg = server.arg("msg1");
  ////Serial.println(msg);
  brightness = msg.toInt();
 //Serial.println("");
  Serial.write( byte(1)); //writes the form number being submitted
    Serial.write( byte(brightness));
  //Serial.println(val);
void handle_msg2() {
String msg = server.arg("msg2");
  ////Serial.println(msg2);
  //Serial.print("");
  Serial.write(byte(2)); //writes the form number being submitted
  //Serial.print("");
  //Serial.print("");
  //Serial.print(val);
void handle_msg3() {
String msg = server.arg("msg3");
  Serial.write(byte(3)); //writes the form number being submitted
void handle_msg4() {
String msg = server.arg("msg4");
  Serial.write(byte(4)); //writes the form number being submitted
void handle_msg5() {
String msg = server.arg("msg5");
  Serial.write(byte(5)); //writes the form number being submitted
void handle_msg6() {
String msg = server.arg("msg6");
  Serial.write(byte(6)); //writes the form number being submitted
void handle_msg7() {
String msg = server.arg("msg7");
  Serial.write(byte(7)); //writes the form number being submitted
void handle_msg8() {
String msg = server.arg("msg8");
  Serial.write(byte(8)); //writes the form number being submitted
I'm excluding my wiring diagram, as that appears to not be the issue. i will note that the esp tx is directly connected to the arduino rx, as my understanding is that i don't need a logic-level shift in this direction.
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data.
...R
